VPN comes up briefly then goes down
I'm testing out VPN with my Cisco 1801 router which uses a separate ADSL modem on FA1 to connect to the Internet. This port is assigned to VLAN 80.
I set up the modem to forward all ports to the Cisco and the Cisco is connected to the rest of my LAN on FA2
Whenever I try to use my Android phone to connect to the VPN, it tries for a while then just goes back to disconnected state.
The phone works with other VPN services I have tried.
I am using the same credentials I use to login to the router, but have also tried the chap credentials defined in the virtual template.
When I enable debugging of VPN events, I get the following output which seems to show that the connection comes up
VPDN Received L2TUN socket message <xCRQ - Session Incoming>
VPDN uid:2 L2TUN socket session accept requested
VPDN uid:2 Setting up dataplane for L2-L2, no idb
VPDN Received L2TUN socket message <xCCN - Session Connected>
VPDN uid:2 VPDN session up
VPDN uid:2 disconnect (AAA) IETF: 17/user-error Ascend: 26/PPP CHAP Fail
VPDN uid:2 vpdn shutdown session, result=2, error=6, vendor_err=0, syslog_error_code=8, syslog_key_type=1
VPDN Received L2TUN socket message <CDN - Session Disconnected>
Here is part of the config I am using...
vpdn enable
vpdn-group homevpn
! Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
l2tp tunnel timeout no-session 15
interface Virtual-Template1
ip unnumbered FastEthernet1
ip nat inside
ip virtual-reassembly in
peer default ip address pool VPN-pool
no keepalive
ppp encrypt mppe auto passive
ppp authentication chap eap ms-chap ms-chap-v2 pap
ppp chap hostname vpntest
ppp chap password 7 ****
ip local pool VPN-pool 192.168.1.10 192.168.1.15
Thanks for any help1
2 Accepted Solutions
The reason is that with CHAP the router gets a response that is based on the hash of the password. To validate that, the router needs the cleartext-password and can't use the one that is configured with "username ... secret".
Another option is to authenticate with PAP where you can store users with hashed passwords. You just have to choose if you want cleartext passwords in transit (PAP) or on the router (CHAP).
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
First: You configured a PPTP-VPN while EzVPN uses IPSec. But PPTP is not considered secure any more, so IPSec is the way to go (or SSL-VPN with AnyConnect). On the router you can configure an EzVPN-server and use the Shrew-client to connect to this server.
Here are example for the EzVPN-server. Go directly to Example 3:
http://nat0.net/ezvpn-server-on-ios-in-three-different-flavous/
9 Replies 9
The problem was that I was using an account that was using a secret password
I created another account and used
username a_user password a_password
I can now connect to my VPN using this account
Thank you for that Karsten.
I have another problem now though as although I can use my mobile phone to connect to the VPN using the 3G network, when I go to work and use their Wifi or use my work desktop and configure a VPN adapter connection in Windows, I cannot connect to my VPN.
My work must be blocking certain required ports on their firewall.
However, I do use a VPN connection from my work desktop for other services by using the Shrewsoft VPN client software.
In the details of the connection I can see that my client PC is being auto configured using ike config pull.
Also, the authentication method is Mutual PSK + XAuth
So, can I create a VPN configuration on my Cisco router that uses these protocols?
EZVPN seems to use some of these protocols so do you think this may be my best way forward?
Thanks again.
Thank you for your help.
I'll give that a try.
Cheers.
When I use your example 3 configuration from the link, I then use my Android mobile using VpnCilla client which is known to work, but I cannot connect.
I get these debug messages:
ISAKMP:(0):Proposed key length does not match policy
ISAKMP:(0):atts are not acceptable. Next payload is 3
ISAKMP:(0):Hash algorithm offered does not match policy!
In the client I have tried entering the clear text key of cisco, the crypto keyring preshared key, and also the isakmp client configuration key, but no luck.
Any ideas?
I just realized that that was not the example I wanted to post ... But doesn't matter. First, from example 3 you dont need the keyring commands, just delete them.
crypto isakmp profile ISAKMP-PROFILE
  no keyring EZVPN-KEYRING
no crypto keyring EZVPN-KEYRING
Then, I don't know VPNcilla, but can you control the Phase1-parameters in the client? Then set them to the following:
  • AES 128
  • SHA-1
  • DH-Group2
  • Pre-Shared-Key
  • Lifetime 86400s
If you can also specify the Phase2-parameters, use
  • AES 128
  • SHA-1
The error message points to parameters that are different on both ends.
Hi Karsten
I'm now using the Shrew Soft VPN client on my Windows PC at work. I've configured the client as recommended and the VPN connects but I cannot ping the router on its private address and I cannot connect to the console using SSH.
When I go to command line and run ipconfig, the VPN adapter has got the IP address I defined in the settings below, but it has no gateway settings assigned.
I have not configured DHCP for the VPN, but can I set the gateway details manually like I set the IP address?
Also, a while after connection, Shrew Soft VPN client reports failed security associations as shown below:
One other thing, I did not use the split tunnel access list from your config as I did not understand why it should be used and it does not appear in Cisco's documentation for configuring EZVPN.
Below is the complete Shrew Soft VPN client configuration.
Thanks for all your help so far.
General
hostname:
Port: 500
Local Host
Address Method: Use a virtual adapter and assigned address
MTU: 1380
Address:
Client
NAT Traversal: enabled
NAT Traversal Port: 4500
Keep-alive packet rate: 15 secs
IKE Fragmentation: enable
Maximum packet size: 540 Bytes
Other Options
Dead Peer Detection: enabled
ISAKMP Failure Notifications: enabled
Name Resolution
All disabled
Authetication
Method: Mutual PSK
Local Identity
Identification Type: IP Address
Use a discovered local host address: enabled
Remote Identity
Use a discovered remote host address: enabled
Credentials
Pre Shared Key: cisco
Phase 1
Exchange Type: aggressive
DH Exchange: group 2
Cipher Algorithm: auto
Hash Algorithm: auto
Key Life Time limt: 86400 Secs
Phase 2
Transform Algorithm: auto
HMAC Algorithm: auto
PFS Exchange: auto
Compress Algorithm: disabled
Key Life Time limit: 3600 secs
Policy
Policy Generation Level: auto
Obtain Topology Automatically or Tunnel All: enabled
Just an update, I figured out how to get my VPN working a few weeks back....and here is the relevant config in case anyone else wants to set this up.
aaa authentication login default local
aaa authentication login authen local
aaa authorization network default none
aaa authorization network author local
aaa session-id common
username vpnconnect secret your_password
! VPN client connects using one of these policies where compatible in order of encryption strength
crypto isakmp policy 1
encr aes 256
hash sha256
authentication pre-share
group 2
crypto isakmp policy 2
encr aes
group 2
crypto isakmp policy 3
encr 3des
group 2
crypto isakmp client configuration group VPN-CONNECT
key 6 your_key
dns 8.8.8.8
pool VPNPOOL
max-users 1
   match identity group VPN-CONNECT
   client authentication list authen
   isakmp authorization list author
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set TSET esp-3des esp-sha-hmac
crypto ipsec profile IPSEC-PROFILE
set transform-set TSET
interface Virtual-Template1 type tunnel
ip unnumbered your_internet_gateway_interface
tunnel mode ipsec ipv4
tunnel protection ipsec profile IPSEC-PROFILE
ip local pool VPNPOOL 192.168.1.54
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface your_internet_gateway_interface overload
access-list 10 remark Stop VPN traffic from being NATed
access-list 10 deny   192.168.1.54
And you set up your VPN client software as per the following sceen grab.
The only issue I have now is how to get split tunnelling working, as when I connect my PC to the VPN, I can no longer get on the Internet from that PC.
Any ideas?
