Warning message
Wireless controller
Nov 3rd, 2013
We have a wireless controller setup in our environment with a few APs out. We have it setup to where once a user connects to the SSID, it's "supposed" to redirect them to a lobby ambassador login page. The issue we're having here is that the page doesn't even come up at all. It connects perfectly fine to the broadcasted SSID. Any ideas on why the page doesn't come up? under the WLANs we have it under the layer 3 tab with the web policy tab checked, and the authenication radio selected. any ideas?
Overall Rating: 4 (1 ratings)
Eric Moyers Wed, 11/06/2013 - 07:01
  • Silver, 250 points or more
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
It would help us figure out your issue if we knew the make and model of your Wireless Controller and AP's. Since all of our Small Business AP's do not work with a controller, it is possible that we will need you to ask this questions in another section of this forum, but it will be easier to point you to the right one once I know what we are working with.
Eric Moyers    .:|:.:|:.
Cisco Small Business US STAC Advanced Support Engineer
CCNA, CCNA-Wireless
866-606-1866
Mon - Fri 09:00 - 18:00 (UTC - 05:00)
*Please rate the Post so other will know when an answer has been found.
Stephen Rodriguez Wed, 11/06/2013 - 07:08
  • Purple, 4500 points or more
is the user opening a browser?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Sandeep Choudhary Wed, 11/06/2013 - 07:25
  • Cisco Designated VIP,
    2017 Wireless
HI Thino,
Please once again check the config on WLC about redirection:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a0080bf7d89.shtml
Ensure that the Scripting option is not blocked on the client browser as the customized web page on the WLC is basically an HTML script. On IE 6.0, this is disabled by default for security purposes.
Note: The Pop Up blocker needs to be disabled on the browser if you have configured any Pop Up messages for the user.
Note: If you browse to an https site, redirection does not work. Refer to Cisco bug ID CSCar04580 (registered customers only) for more information.
thinoaphay Wed, 11/06/2013 - 09:10
I found out the issue. Checked the virtual machine we had the VM installed on, and promiscuous mode was on "reject" on the network NIC. Needs to be enabled in order for the controller can pass through.
Leo Laohoo Wed, 11/06/2013 - 14:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Tell users NOT to use Google Chrome.
Florin Barhala Thu, 11/07/2013 - 00:55
  • Bronze, 100 points or more
Why is this so, Leo? Can you detail a bit?
Scott Fella Thu, 11/07/2013 - 04:57
  • Hall of Fame,
    2017 Wireless
Leo is probably referring to this:
https://supportforums.cisco.com/thread/2237455
Leo Laohoo Thu, 11/07/2013 - 14:25
  • Hall of Fame,
    2017 LAN, Wireless
Hi Florin,
As Scott has pointed it out, it's because of this bug:  https://supportforums.cisco.com/thread/2237455
