Warning message
RA IPSEC - enable hairpinning but restricting access to web
Answered Question
Nov 5th, 2013
ASA5520     8.2(5)30
Greetings,
I have an IPSEC RA policy that's set up to tunnel all traffic (no split-tunnel) through the ASA (terminates on the outside interface).  I need to be able to allow thesesame VPN users to access one web page (hairpinning) on the outside interface.
Here are the current settings:
group-policy L-Admins internal
group-policy L_Admins attributes
wins-server value 172.16.0.33 172.16.0.9
dns-server value 172.16.0.33 172.16.0.9
vpn-idle-timeout 60
vpn-session-timeout 480
vpn-filter value l-admin-filter
     access-list l-admin-test-filter extended permit ip 172.30.4.0 255.255.255.252 host 172.16.0.33
     access-list l-admin-test-filter extended permit ip 172.30.4.0 255.255.255.252 host 172.16.0.9
     access-list l-admin-test-filter extended permit ip 172.30.4.0 255.255.252.252 host 172.16.1.4
     access-list l-admin-test-filter extended permit ip 172.30.4.0 255.255.252.252 host 172.16.1.2
     access-list l-admin-test-filter extended permit ip 172.30.4.0 255.255.252.252 10.24.0.0 255.252.0.0
     access-list l-admin-test-filter extended permit ip 172.30.4.0 255.255.252.252 host 172.16.0.233
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelall
default-domain value IHI.local
tunnel-group L_Admins type remote-access
tunnel-group L_Admins general-attributes
address-pool ili_global
authentication-server-group PhoneFactor
default-group-policy L_Admins
tunnel-group L_Admins ipsec-attributes
pre-shared-key *
Hairpinning is currently not enabled, so I assume I need to add:
same-security-traffic permit inter-interface
and (I assume)
ip local pool l_admins 172.30.4.1-172.30.4.2 mask 255.255.255.252
global (outside) 1 interface ***** PAT IP
nat (outside) 1 172.30.4.1-172.30.4.2 mask 255.255.255.252
But from here I don't know how to restrict access to a single external IP on the web over port 80.
Correct Answer by Jouni Forss about 3 years 9 months ago
The correct command to enable traffic enter and leave the same interface is
same-security-traffic permit intra-interface
The command you posted allows traffic between 2 different interfaces which have the same "security-level" value
With regards to the Dynamic PAT for Internet traffic
If you have this already
Then you will need the "nat" command for the VPN pool
nat (outside) 1 172.30.4.0 255.255.255.252
With regards to controlling the traffic towards Internet, shouldnt you be able to simply add that destination server IP address to the VPN Filter ACL you already have in use? I mean the ACL named "l-admin-test-filter".
For example
access-list l-admin-test-filter remark Allow external server connection
access-list l-admin-test-filter permit tcp 172.30.4.0 255.255.255.252 host eq 80
access-list l-admin-test-filter permit tcp 172.30.4.0 255.255.255.252 host eq 443
access-list l-admin-test-filter permit tcp 172.30.4.0 255.255.255.252 host eq 8080
- Jouni
Overall Rating: 5 (1 ratings)
Correct Answer
Jouni Forss Tue, 11/05/2013 - 06:48
For example
- Jouni
iholdings Tue, 11/05/2013 - 07:00
Hi Jouni,
Thanks so much for the prompt reply.  I will add the nat and acl statements and report back.
-Tom
iholdings Wed, 11/06/2013 - 08:05
Jouni-
Worked like a charm!!
Thanks fr your help
Jouni Forss Wed, 11/06/2013 - 08:07
Great to hear that its working as expected
- Jouni
Related Content
