I have a Problem with Romming Between SSIDs withing the same WLC but with deferent VLAN .
Nov 5th, 2013
HI All,
I have a Problem with Romming Between SSIDs withing the same WLC but with deferent VLAN . the WLC are providing the HQ and one of the Branches the Wireless services .
Am using all the available 9 SSIDs at the HQ , and am using only 4 of it at the Brnche.
The problem that i have are happening only at the Branch office as i cant room between the SSIDs within Diferent VLANs but i can do it with the one that pointing to the same VLAN. Once the client ( Laptop/Phone ) connected to one of the SSIDs. it imposiible to have him connected to the other ones with Different VLAN. meanwhile, It says its connected to the other SSID but its not getting IP from that pool.
here is the Show Run-Config from my WLC .. and the Problem happening between the SSID AMOBILE and ASTAFF. i have the Debug while am switching between the SSIDs if needed .
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.11.04 10:20:47 =~=~=~=~=~=~=~=~=~=~=~=
show run-config
Press Enter to continue...
System Inventory
NAME: "Chassis"   , DESCR: "Cisco 5500 Series Wireless LAN Controller"
PID: AIR-CT5508-K9, VID: V01, SN: FCW1535L01G
Burned-in MAC Address............................ 30:E4:DB:1B:99:80
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 12
Press Enter to continue or <ctrl-z> to abort
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.235.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... WLAN Controller 5508
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... 10.125.18.15
Last Reset....................................... Software reset
System Up Time................................... 41 days 5 hrs 14 mins 42 secs
System Timezone Location......................... (GMT -5:00) Eastern Time (US and Canada)
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
Configured Country............................... US - United States
--More or (q)uit current module or <ctrl-z> to abort
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +36 C
External Temperature............................. +20 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 10
Number of Active Clients......................... 61
AP Bundle Information
Primary AP Image  Size
ap3g1             5804
ap801             5192
ap802             5232
c1100             3096
c1130             4972
c1140             4992
c1200             3364
c1240             4812
c1250             5512
c1310             3136
c1520             6412
c3201             4324
c602i             3716
Secondary AP Image      Size
ap801             4964
c1100             3036
c1130             4884
c1140             4492
c1200             3316
c1240             4712
c1250             5064
c1310             3084
c1520             5244
c3201             4264
Switch Configuration
802.3x Flow Control Mode......................... Disable
FIPS prerequisite features....................... Disabled
secret obfuscation............................... Enabled
Strong Password Check Features:
       case-check ...........Enabled
       consecutive-check ....Enabled
       default-check .......Enabled
       username-check ......Enabled
Network Information
RF-Network Name............................. OGR
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Unicast
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
IGMP Query Interval......................... 20 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Enabled
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80
Web Auth Proxy Redirect ................... Disable
Fast SSID Change ........................... Enabled
AP Discovery - NAT IP Only ................. Enabled
IP/MAC Addr Binding Check .................. Enabled
Port Summary
           STP   Admin   Physical   Physical   Link   Link
Pr Type   Stat   Mode     Mode     Status   Status Trap    POE   SFPType
1 Normal Forw Enable Auto       1000 Full Up     Enable N/A     1000BaseTX
2 Normal Disa Enable Auto       Auto       Down   Enable N/A     Not Present
3 Normal Disa Enable Auto       Auto       Down   Enable N/A     Not Present
4 Normal Disa Enable Auto       Auto       Down   Enable N/A     Not Present
5 Normal Disa Enable Auto       Auto       Down   Enable N/A     Not Present
6 Normal Disa Enable Auto       Auto       Down   Enable N/A     Not Present
7 Normal Disa Enable Auto       Auto       Down   Enable N/A     Not Present
8 Normal Disa Enable Auto       Auto       Down   Enable N/A     Not Present
AP Summary
Number of APs.................................... 8
Global AP User Name.............................. Not Configured
Global AP Dot1x User Name........................ Not Configured
AP Name             Slots AP Model             Ethernet MAC       Location         Port Country Priority
KNOWLOGY_DC01       2     AIR-LAP1131AG-A-K9   00:1d:45:86:ed:4e KNOWLOGY_DC_Serv 1       US       1
KNOWLOGY_DC02       2     AIR-LAP1131AG-A-K9   00:21:d8:36:c5:c4 KNOWLOGY_DC_Serv 1       US       1
KN1252_AP01         2     AIR-LAP1252AG-A-K9   00:21:d8:ef:06:50 Knowlogy Confere 1       US       1
KN1252_AP02         2     AIR-LAP1252AG-A-K9   00:22:55:8e:2e:d4 Server Room Side 1       US       1
Anham_AP03           2     AIR-LAP1142N-A-K9     70:81:05:88:15:b5 default location 1       US       1
ANHAM_AP01          2     AIR-LAP1142N-A-K9     70:81:05:b0:e4:62 Small Conference 1       US       1
ANHAM_AP04           2     AIR-LAP1131AG-A-K9   00:1d:45:86:e1:b8   Conference room 1       US       1
ANHAM_AP02           2     AIR-LAP1142N-A-K9     70:81:05:96:7a:49         Copy Room 1       US       1
AP Tcp-Mss-Adjust Info
AP Name             TCP State MSS Size
KNOWLOGY_DC01       disabled   -
KNOWLOGY_DC02       disabled   -
KN1252_AP01         disabled   -
KN1252_AP02         disabled   -
Anham_AP03           disabled   -
ANHAM_AP01           disabled   -
ANHAM_AP04           disabled   -
ANHAM_AP02           disabled   -
AP Location
Total Number of AP Groups........................ 3
Site Name........................................ ANHAM8075
Site Description................................. ANHAM 8075 Location
WLAN ID         Interface         Network Admission Control         Radio Policy
1               knowlogy_ogr         Disabled                         None
6               knowlogy_ogr         Disabled                         None
9               knowlogy_ogr         Disabled                         None
7               knowlogy_ogr         Disabled                         None
Site Name........................................ Knowlogy_DC
Site Description................................. DC Center Access points
2               knowlogy_ogr         Disabled                         None
4               knowlogy_ogr         Disabled                         None
3               knowlogy_ogr         Disabled                         None
Site Name........................................ OGR
Site Description................................. 1934 OGR Office
8               knowlogy_ogr         Disabled                         None
Site Name........................................ default-group
Site Description................................. <none>
5               knowlogy_ogr         Disabled                         None
10             management           Disabled                         None
AP Config
Cisco AP Identifier.............................. 6
Cisco AP Name.................................... KNOWLOGY_DC01
Country code..................................... US - United States
Regulatory Domain allowed by Country............. 802.11bg:-A     802.11a:-A
AP Country code.................................. US - United States
AP Regulatory Domain............................. -A
Switch Port Number .............................. 1
MAC Address...................................... 00:1d:45:86:ed:4e
IP Address Configuration......................... DHCP
IP Address....................................... 10.22.1.100
Gateway IP Addr.................................. 10.22.1.1
NAT External IP Address.......................... None
CAPWAP Path MTU.................................. 1485
Telnet State..................................... Disabled
Ssh State........................................ Disabled
Cisco AP Location................................ KNOWLOGY_DC_ServerRoom
Cisco AP Group Name.............................. Knowlogy_DC
Primary Cisco Switch Name........................ wireless.knowlogy.com
Primary Cisco Switch IP Address.................. 10.125.18.15
Secondary Cisco Switch Name......................
Secondary Cisco Switch IP Address................ Not Configured
--More or (q)uit current module or <ctrl-z> to abortIP Address.................. 10.125.18.15
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... H-Reap
Public Safety ................................... Disabled
AP SubMode ...................................... Not Configured
Remote AP Debug ................................. Disabled
Logging trap severity level ..................... informational
Logging syslog facility ......................... kern
S/W Version .................................... 7.0.235.0
Boot Version ................................... 12.3.8.0
Mini IOS Version ................................ 3.0.51.0
Stats Reporting Period .......................... 180
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... Disabled
Power Type/Mode.................................. Power injector / Normal mode
Number Of Slots.................................. 2
AP Model......................................... AIR-LAP1131AG-A-K9
AP Image......................................... C1130-K9W8-M
IOS Version...................................... 12.4(23c)JA5
Reset Button..................................... Enabled
AP Serial Number................................. FTX1134T0QG
AP Certificate Type.............................. Manufacture Installed
H-REAP Vlan mode :............................... Enabled
      Native ID :..................................... 22
      WLAN 2 :........................................ 21
      WLAN 4 :........................................ 25
      WLAN 3 :........................................ 25
H-REAP Backup Auth Radius Servers :
Static Primary Radius Server.................... Disabled
Static Secondary Radius Server.................. Disabled
Group Primary Radius Server..................... Disabled
Group Secondary Radius Server................... Disabled
AP User Mode..................................... AUTOMATIC
AP User Name..................................... Not Configured
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system logging host..................... 255.255.255.255
AP Up Time....................................... 48 days, 20 h 19 m 18 s
AP LWAPP Up Time................................. 40 days, 13 h 58 m 18 s
Join Date and Time............................... Tue Sep 24 21:24:33 2013
Join Taken Time.................................. 0 days, 00 h 10 m 47 s
Attributes for Slot 0
    Radio Type................................... RADIO_TYPE_80211b
   Administrative State ........................ ADMIN_ENABLED
   Operation State ............................. UP
   Radio Role .................................. ACCESS
   CellId ...................................... 0
   Station Configuration
     Configuration ............................. AUTOMATIC
     Number Of WLANs ........................... 3
     Medium Occupancy Limit .................... 100
     CFP Period ................................ 4
     CFP MaxDuration ........................... 60
     BSSID ..................................... 00:1d:71:09:8f:90
     Operation Rate Set
       1000 Kilo Bits........................... MANDATORY
       2000 Kilo Bits........................... MANDATORY
       5500 Kilo Bits........................... MANDATORY
       11000 Kilo Bits.......................... MANDATORY
     Beacon Period ............................. 100
     Fragmentation Threshold ................... 2346
     Multi Domain Capability Implemented ....... TRUE
     Multi Domain Capability Enabled ........... TRUE
     Country String ............................ US
     First Chan Num ............................ 1
     Number Of Channels ........................ 11
   MAC Operation Parameters
     Packet Retry Limit ........................ 64
   Tx Power
     Num Of Supported Power Levels ............. 8
     Tx Power Level 1 .......................... 20 dBm
     Tx Power Level 2 .......................... 17 dBm
     Tx Power Level 3 .......................... 14 dBm
     Tx Power Level 4 .......................... 11 dBm
     Tx Power Level 5 .......................... 8 dBm
     Tx Power Level 6 .......................... 5 dBm
     Tx Power Level 7 .......................... 2 dBm
     Tx Power Level 8 .......................... -1 dBm
     Tx Power Configuration .................... AUTOMATIC
     Current Tx Power Level .................... 1
   Phy DSSS parameters
     Current Channel ........................... 11
     Extension Channel ......................... NONE
     Channel Width.............................. 20 Mhz
     Allowed Channel List....................... 1,2,3,4,5,6,7,8,9,10,11
     Current CCA Mode .......................... 0
     ED Threshold .............................. -50
     Antenna Type............................... INTERNAL_ANTENNA
     Internal Antenna Gain (in .5 dBi units).... 8
     Diversity.................................. DIVERSITY_ENABLED
   Performance Profile Parameters
     Interference threshold..................... 10 %
     Noise threshold............................ -70 dBm
     RF utilization threshold................... 80 %
     Data-rate threshold........................ 1000000 bps
     Client threshold........................... 12 clients
     Coverage SNR threshold..................... 12 dB
     Coverage exception level................... 25 %
     Client minimum exception level............. 3 clients
   Rogue Containment Information
   Containment Count............................ 0
   CleanAir Management Information
       CleanAir Capable......................... No
Primary Cisco Switch Secondary Cisco Switch Name......................
Attributes for Slot 1
   Radio Type................................... RADIO_TYPE_80211a
   Radio Subband................................ RADIO_SUBBAND_ALL
     Operation Rate Set
       6000 Kilo Bits........................... MANDATORY
       9000 Kilo Bits........................... SUPPORTED
       12000 Kilo Bits.......................... MANDATORY
       18000 Kilo Bits.......................... SUPPORTED
       24000 Kilo Bits.......................... MANDATORY
      36000 Kilo Bits.......................... SUPPORTED
       48000 Kilo Bits.......................... SUPPORTED
       54000 Kilo Bits.......................... SUPPORTED
     First Chan Num ............................ 36
     Number Of Channels ........................ 20
   Tx Power
     Num Of Supported Power Levels ............. 7
     Tx Power Level 1 .......................... 15 dBm
     Tx Power Level 2 .......................... 14 dBm
     Tx Power Level 3 .......................... 11 dBm
     Tx Power Level 4 .......................... 8 dBm
     Tx Power Level 5 .......................... 5 dBm
     Tx Power Level 6 .......................... 2 dBm
     Tx Power Level 7 .......................... -1 dBm
   Phy OFDM parameters
     Current Channel ........................... 44
     Allowed Channel List....................... 36,40,44,48,52,56,60,64,100,
       ......................................... 104,108,112,116,132,136,140,
       ......................................... 149,153,157,161
     TI Threshold .............................. -50
     Coverage SNR threshold..................... 16 dB
Cisco AP Identifier.............................. 3
Cisco AP Name.................................... KNOWLOGY_DC02
MAC Address...................................... 00:21:d8:36:c5:c4
IP Address....................................... 10.22.1.101
Primary Cisco Switch IP Address.................. Not Configured
PoE Pre-Standard Switch.......................... Enabled
AP Serial Number................................. FTX1230T24F
AP Up Time....................................... 48 days, 20 h 24 m 41 s
Join Date and Time............................... Tue Sep 24 21:24:35 2013
Join Taken Time.................................. 0 days, 00 h 10 m 48 s
     BSSID ..................................... 00:22:55:a5:0c:30
     Operation Rate Set
   Tx Power
   Phy DSSS parameters
     Operation Rate Set
   Tx Power
   Phy OFDM parameters
     Current Channel ........................... 36
Cisco AP Identifier.............................. 5
Cisco AP Name.................................... KN1252_AP01
MAC Address...................................... 00:21:d8:ef:06:50
IP Address....................................... 10.125.18.101
IP NetMask....................................... 255.255.255.0
Gateway IP Addr.................................. 10.125.18.1
Telnet State..................................... Enabled
Cisco AP Location................................ Knowlogy Conference Rooms Side
Cisco AP Group Name.............................. OGR
Boot Version ................................... 12.4.10.0
Power Type/Mode.................................. PoE/Medium Power (15.4 W)
AP Model......................................... AIR-LAP1252AG-A-K9
AP Image......................................... C1250-K9W8-M
AP Serial Number................................. FTX122990L5
      Native ID :..................................... 118
      WLAN 1 :........................................ 111
      WLAN 2 :........................................ 111
      WLAN 4 :........................................ 112
      WLAN 6 :........................................ 112
      WLAN 7 :........................................ 111
      WLAN 9 :........................................ 112
      WLAN 8 :........................................ 112
AP Up Time....................................... 26 days, 00 h 24 m 39 s
AP LWAPP Up Time................................. 26 days, 00 h 23 m 48 s
Join Date and Time............................... Wed Oct 9 10:59:07 2013
Join Taken Time.................................. 0 days, 00 h 00 m 50 s
   Radio Type................................... RADIO_TYPE_80211n-2.4
     Number Of WLANs ........................... 7
     BSSID ..................................... 00:22:55:df:a5:90
     Operation Rate Set
     MCS Set
       MCS 0.................................... SUPPORTED
       MCS 1.................................... SUPPORTED
       MCS 2.................................... SUPPORTED
       MCS 3.................................... SUPPORTED
       MCS 4.................................... SUPPORTED
       MCS 5.................................... SUPPORTED
       MCS 6.................................... SUPPORTED
       MCS 7.................................... SUPPORTED
       MCS 8.................................... SUPPORTED
        MCS 9.................................... SUPPORTED
       MCS 10................................... SUPPORTED
       MCS 11................................... SUPPORTED
       MCS 12................................... SUPPORTED
       MCS 13................................... SUPPORTED
       MCS 14................................... SUPPORTED
       MCS 15................................... SUPPORTED
   Tx Power
   Phy DSSS parameters
     Legacy Tx Beamforming Configuration ....... AUTOMATIC
     Legacy Tx Beamforming ..................... DISABLED
     Antenna Type............................... EXTERNAL_ANTENNA
     External Antenna Gain (in .5 dBi units).... 0
     802.11n Antennas
         A....................................... ENABLED
         B....................................... ENABLED
         C....................................... ENABLED
   Radio Type................................... RADIO_TYPE_80211n-5
     Operation Rate Set
     MCS Set
     Number Of Channels ........................ 21
   Tx Power
     Tx Power Level 1 .......................... 17 dBm
   Phy OFDM parameters
     Current Channel ........................... 153
       ......................................... 149,153,157,161,165
     802.11n Antennas
Cisco AP Identifier.............................. 11
Cisco AP Name.................................... KN1252_AP02
MAC Address...................................... 00:22:55:8e:2e:d4
IP Address....................................... 10.125.18.102
Cisco AP Location................................ Server Room Side
AP Serial Number................................. FTX122990S5
AP Up Time....................................... 26 days, 00 h 24 m 41 s
AP LWAPP Up Time................................. 26 days, 00 h 23 m 50 s
Join Date and Time............................... Wed Oct 9 10:59:08 2013
     BSSID ..................................... 00:22:55:df:9e:70
     Operation Rate Set
     MCS Set
   Tx Power
   Phy DSSS parameters
     802.11n Antennas
     Operation Rate Set
     MCS Set
   Tx Power
     Num Of Supported Power Levels ............. 6
     Tx Power Level 1 .......................... 14 dBm
     Tx Power Level 2 .......................... 11 dBm
     Tx Power Level 3 .......................... 8 dBm
     Tx Power Level 4 .......................... 5 dBm
     Tx Power Level 5 .......................... 2 dBm
     Tx Power Level 6 .......................... -1 dBm
   Phy OFDM parameters
     802.11n Antennas
Cisco AP Identifier.............................. 0
Cisco AP Name.................................... Anham_AP03
MAC Address...................................... 70:81:05:88:15:b5
IP Address....................................... 10.121.18.107
Gateway IP Addr.................................. 10.121.18.1
Cisco AP Location................................ default location
Cisco AP Group Name.............................. ANHAM8075
Boot Version ................................... 12.4.23.1
AP Model......................................... AIR-LAP1142N-A-K9
AP Image......................................... C1140-K9W8-M
AP Serial Number................................. FTX1535E2D9
      Native ID :..................................... 420
      WLAN 1 :........................................ 411
      WLAN 6 :........................................ 412
      WLAN 9 :........................................ 412
      WLAN 7 :........................................ 411
AP Up Time....................................... 4 days, 20 h 56 m 43 s
AP LWAPP Up Time................................. 4 days, 20 h 55 m 50 s
Join Date and Time............................... Wed Oct 30 14:27:11 2013
Join Taken Time.................................. 0 days, 00 h 00 m 52 s
     Number Of WLANs ........................... 4
     BSSID ..................................... 00:08:30:5d:c1:90
     Operation Rate Set
     MCS Set
   Tx Power
   Phy DSSS parameters
     802.11n Antennas
     Operation Rate Set
     MCS Set
   Tx Power
   Phy OFDM parameters
     Current Channel ........................... 40
     802.11n Antennas
Cisco AP Identifier.............................. 2
Cisco AP Name.................................... ANHAM_AP01
MAC Address...................................... 70:81:05:b0:e4:62
IP Address....................................... 10.121.18.105
Ssh State........................................ Enabled
Cisco AP Location................................ Small Conference Room
AP Serial Number................................. FTX1535E2D6
AP Up Time....................................... 4 days, 20 h 56 m 35 s
AP LWAPP Up Time................................. 4 days, 20 h 55 m 42 s
Join Date and Time............................... Wed Oct 30 14:27:22 2013
     BSSID ..................................... 00:08:30:e4:0d:b0
     Operation Rate Set
     MCS Set
   Tx Power
   Phy DSSS parameters
     802.11n Antennas
     Operation Rate Set
     MCS Set
   Tx Power
   Phy OFDM parameters
     Current Channel ........................... 149
     802.11n Antennas
Cisco AP Identifier.............................. 4
Cisco AP Name.................................... ANHAM_AP04
MAC Address...................................... 00:1d:45:86:e1:b8
IP Address....................................... 10.121.18.108
Cisco AP Location................................ Conference room
Stats Reporting Period .......................... 360
AP Serial Number................................. FTX1134T0SA
AP Up Time....................................... 4 days, 20 h 56 m 07 s
AP LWAPP Up Time................................. 4 days, 20 h 55 m 12 s
Join Date and Time............................... Wed Oct 30 14:27:54 2013
Join Taken Time.................................. 0 days, 00 h 00 m 54 s
     BSSID ..................................... 00:1d:71:09:32:b0
     Operation Rate Set
   Tx Power
   Phy DSSS parameters
     Current Channel ........................... 6
     Operation Rate Set
   Tx Power
     Tx Power Level 2 .......................... 15 dBm
   Phy OFDM parameters
     Current Channel ........................... 64
Cisco AP Identifier.............................. 8
Cisco AP Name.................................... ANHAM_AP02
MAC Address...................................... 70:81:05:96:7a:49
IP Address....................................... 10.121.18.106
Cisco AP Location................................ Copy Room
AP Serial Number................................. FTX1535K2LB
AP Up Time....................................... 4 days, 19 h 26 m 23 s
AP LWAPP Up Time................................. 4 days, 19 h 25 m 30 s
Join Date and Time............................... Wed Oct 30 15:57:39 2013
     BSSID ..................................... 00:08:30:d7:72:90
     Operation Rate Set
     MCS Set
   Tx Power
   Phy DSSS parameters
     802.11n Antennas
     Operation Rate Set
     MCS Set
   Tx Power
   Phy OFDM parameters
     Current Channel ........................... 48
     802.11n Antennas
AP Airewave Director Configuration
AP Name.......................................... KNOWLOGY_DC01
Slot ID........................................ 0
Radio Type..................................... RADIO_TYPE_80211b/g
Sub-band Type.................................. All
Noise Information
   Noise Profile................................ PASSED
   Channel 1.................................... -78 dBm
   Channel 2.................................... -86 dBm
   Channel 3.................................... -87 dBm
   Channel 4.................................... -86 dBm
   Channel 5.................................... -90 dBm
   Channel 6.................................... -87 dBm
   Channel 7.................................... -87 dBm
   Channel 8.................................... -92 dBm
   Channel 9.................................... -90 dBm
   Channel 10................................... -92 dBm
   Channel 11................................... -94 dBm
Interference Information
   Interference Profile......................... FAILED
   Channel 1.................................... -68 dBm @ 6 % busy
   Channel 2.................................... -80 dBm @ 6 % busy
   Channel 3.................................... -70 dBm @ 21 % busy
   Channel 4.................................... -128 dBm @ 0 % busy
   Channel 5.................................... -64 dBm @ 4 % busy
   Channel 6.................................... -64 dBm @ 3 % busy
   Channel 7.................................... -64 dBm @ 4 % busy
   Channel 8.................................... -82 dBm @ 3 % busy
   Channel 9.................................... -128 dBm @ 0 % busy
   Channel 10................................... -71 dBm @ 2 % busy
   Channel 11................................... -69 dBm @ 13 % busy
Load Information
   Load Profile................................. PASSED
   Receive Utilization.......................... 0 %
   Transmit Utilization......................... 2 %
   Channel Utilization.......................... 34 %
   Attached Clients............................. 0 clients
Coverage Information
   Coverage Profile............................. PASSED
   Failed Clients............................... 1 clients
Client Signal Strengths
   RSSI -100 dbm................................ 0 clients
   RSSI -92 dbm................................ 0 clients
  RSSI -84 dbm................................ 1 clients
   RSSI -76 dbm................................ 0 clients
   RSSI -68 dbm................................ 0 clients
   RSSI -60 dbm................................ 0 clients
   RSSI -52 dbm................................ 0 clients
Client Signal To Noise Ratios
   SNR   0 dB.................................. 0 clients
   SNR   5 dB.................................. 0 clients
   SNR   10 dB.................................. 0 clients
   SNR   15 dB.................................. 1 clients
   SNR   20 dB.................................. 0 clients
   SNR   25 dB.................................. 0 clients
   SNR   30 dB.................................. 0 clients
   SNR   35 dB.................................. 0 clients
   SNR   40 dB.................................. 0 clients
   SNR   45 dB.................................. 0 clients
Nearby APs
   AP 00:22:55:a5:0c:30 slot 0.................. -14 dBm on   1 (10.125.18.15)
Radar Information
Channel Assignment Information
   Current Channel Average Energy............... unknown
   Previous Channel Average Energy.............. unknown
   Channel Change Count......................... 0
   Last Channel Change Time..................... Tue Sep 24 21:24:33 2013
   Recommended Best Channel..................... 11
RF Parameter Recommendations
   Power Level.................................. 1
   RTS/CTS Threshold............................ 2347
   Fragmentation Threshold...................... 2346
   Antenna Pattern.............................. 0
Persistent Interference Devices
Class Type                 Channel DC (%%) RSSI (dBm) Last Update Time
All third party trademarks are the property of their respective owners.
Slot ID........................................ 1
Radio Type..................................... RADIO_TYPE_80211a
Noise Information
   Channel 36................................... -96 dBm
   Channel 40................................... -89 dBm
   Channel 44................................... -94 dBm
   Channel 48................................... -96 dBm
   Channel 52................................... -98 dBm
   Channel 56................................... -93 dBm
   Channel 60................................... -95 dBm
   Channel 64................................... -93 dBm
   Channel 100.................................. -94 dBm
   Channel 104.................................. -94 dBm
   Channel 108.................................. -94 dBm
   Channel 112.................................. -94 dBm
   Channel 116.................................. -95 dBm
   Channel 132.................................. -94 dBm
   Channel 136.................................. -94 dBm
   Channel 140.................................. -94 dBm
   Channel 149.................................. -95 dBm
   Channel 153.................................. -95 dBm
   Channel 157.................................. -93 dBm
   Channel 161.................................. -94 dBm
   Interference Profile......................... PASSED
   Channel 36................................... -128 dBm @ 0 % busy
   Channel 40................................... -128 dBm @ 0 % busy
   Channel 44................................... -128 dBm @ 0 % busy
   Channel 48................................... -128 dBm @  0 % busy
   Channel 52................................... -128 dBm @ 0 % busy
   Channel 56................................... -128 dBm @ 0 % busy
   Channel 60................................... -128 dBm @ 0 % busy
   Channel 64................................... -128 dBm @ 0 % busy
   Channel 100.................................. -128 dBm @ 0 % busy
   Channel 104.................................. -128 dBm @ 0 % busy
   Channel 108.................................. -128 dBm @ 0 % busy
   Channel 112.................................. -128 dBm @ 0 % busy
   Channel 116.................................. -128 dBm @ 0 % busy
   Channel 132.................................. -128 dBm @ 0 % busy
   Channel 136.................................. -128 dBm @ 0 % busy
   Channel 140.................................. -128 dBm @ 0 % busy
   Channel 149.................................. -128 dBm @ 0 % busy
   Channel 153.................................. -128 dBm @ 0 % busy
   Channel 157.................................. -128 dBm @ 0 % busy
   Channel 161.................................. -128 dBm @ 0 % busy
   Rogue Histogram (20/40_ABOVE/40_BELOW)
   Channel 36................................... 1/ 0/ 0
   Channel 40................................... 0/ 0/ 1
   Channel 44................................... 0/ 1/ 0
   Channel 48................................... 0/ 0/ 0
   Channel 52................................... 0/ 0/ 0
   Channel 56................................... 0/ 0/ 0
   Channel 60................................... 0/ 0/ 0
    Channel 64................................... 0/ 0/ 0
   Channel 100.................................. 0/ 0/ 0
   Channel 104.................................. 0/ 0/ 0
   Channel 108.................................. 0/ 0/ 0
   Channel 112.................................. 0/ 0/ 0
   Channel 116.................................. 0/ 0/ 0
   Channel 132.................................. 0/ 0/ 0
   Channel 136.................................. 0/ 0/ 0
   Channel 140.................................. 0/ 0/ 0
   Channel 149.................................. 0/ 0/ 0
   Channel 153.................................. 0/ 0/ 1
   Channel 157.................................. 0/ 1/ 0
   Channel 161.................................. 0/ 0/ 0
Load Information
   Transmit Utilization......................... 0 %
   Channel Utilization.......................... 0 %
   Failed Clients............................... 0 clients
   RSSI -84 dbm................................ 0 clients
   RSSI -68 dbm................................ 1 clients
   SNR   15 dB.................................. 0 clients
   SNR   30 dB.................................. 1 clients
Nearby APs
   AP 00:22:55:a5:0c:30 slot 1.................. -29 dBm on 36 (10.125.18.15)
Radar Information
   Current Channel Average Energy............... -86 dBm
   Previous Channel Average Energy.............. -65 dBm
   Channel Change Count......................... 1
   Last Channel Change Time..................... Wed Sep 25 12:21:14 2013
   Recommended Best Channel..................... 44
AP Name.......................................... KNOWLOGY_DC02
Noise Information
   Channel 1.................................... -94 dBm
   Channel 2.................................... -77 dBm
   Channel 3.................................... -90 dBm
   Channel 4.................................... -89 dBm
   Channel 5.................................... -84 dBm
   Channel 6.................................... -88 dBm
   Channel 7.................................... -89 dBm
   Channel 9.................................... -92 dBm
   Channel 10................................... -88 dBm
   Channel 11................................... -90 dBm
   Channel 1.................................... -60 dBm @ 7 % busy
   Channel 2.................................... -78 dBm @ 1 % busy
   Channel 3.................................... -70 dBm @ 31 % busy
   Channel 4.................................... -76 dBm @ 1 % busy
   Channel 5.................................... -128 dBm @ 0 % busy
   Channel 6.................................... -69 dBm @ 14 % busy
   Channel 7.................................... -60 dBm @ 9 % busy
   Channel 8.................................... -64 dBm @ 1 % busy
   Channel 10................................... -73 dBm @ 2 % busy
   Channel 11................................... -71 dBm @ 11 % busy
Load Information
   Transmit Utilization......................... 3 %
   Channel Utilization.......................... 22 %
Nearby APs
   AP 00:1d:71:09:8f:90 slot 0..................  -10 dBm on 11 (10.125.18.15)
Radar Information
   Last Channel Change Time..................... Tue Sep 24 21:24:34 2013
Noise Information
   Channel 36................................... -92 dBm
   Channel 40................................... -93 dBm
   Channel 44................................... -95 dBm
   Channel 48................................... -93 dBm
   Channel 52................................... -92 dBm
   Channel 56................................... -95 dBm
   Channel 64................................... -95 dBm
   Channel 100.................................. -93 dBm
   Channel 112.................................. -93 dBm
   Channel 116.................................. -92 dBm
   Channel 132.................................. -91 dBm
   Channel 136.................................. -93 dBm
   Channel 140.................................. -87 dBm
   Channel 153.................................. -94 dBm
   Channel 157.................................. -86 dBm
   Channel 161.................................. -93 dBm
   Channel 36................................... 0/ 0/ 0
   Channel 44................................... 1/ 1/ 0
   Channel 149.................................. 0/ 1/ 0
Load Information
Nearby APs
   AP 00:1d:71:09:8f:90 slot 1.................. -32 dBm on 44 (10.125.18.15)
Radar Information
   Recommended Best Channel..................... 36
AP Name.......................................... KN1252_AP01
Noise Information
   Channel 1.................................... -97 dBm
   Channel 2.................................... -95 dBm
   Channel 3.................................... -95 dBm
   Channel 4.................................... -95 dBm
   Channel 5.................................... -96 dBm
   Channel 6.................................... -97 dBm
   Channel 7.................................... -97 dBm
   Channel 8.................................... -95 dBm
   Channel 9.................................... -97 dBm
   Channel 10................................... -98 dBm
   Channel 11................................... -96 dBm
   Channel 1.................................... -128 dBm @ 0 % busy
   Channel 2.................................... -128 dBm @ 0 % busy
   Channel 3.................................... -84 dBm @ 1 % busy
   Channel 4.................................... -81 dBm @ 2 % busy
   Channel 6.................................... -73 dBm @ 2 % busy
   Channel 7.................................... -71 dBm @ 1 % busy
   Channel 8.................................... -128 dBm @ 0 % busy
   Channel 10................................... -70 dBm @ 2 % busy
   Channel 11................................... -76 dBm @ 6 % busy
Load Information
   Transmit Utilization......................... 14 %
   Channel Utilization.......................... 27 %
   RSSI -68 dbm................................ 2 clients
   RSSI -60 dbm................................ 2 clients
   RSSI -52 dbm................................ 2 clients
   SNR   30 dB.................................. 2 clients
   SNR   35 dB.................................. 1 clients
   SNR   40 dB.................................. 2 clients
   SNR   45 dB.................................. 1 clients
Nearby APs
   AP 00:22:55:df:9e:70 slot 0.................. -79 dBm on   1 (10.125.18.15)
Radar Information
   Current Channel Average Energy............... -80 dBm
   Previous Channel Average Energy.............. -61 dBm
   Channel Change Count......................... 2
   Last Channel Change Time..................... Wed Oct 23 12:58:29 2013
Noise Information
   Channel 36................................... -97 dBm
   Channel 40................................... -97 dBm
   Channel 44................................... -97 dBm
   Channel 48................................... -97 dBm
   Channel 56................................... -98 dBm
   Channel 60................................... -99 dBm
   Channel 64................................... -98 dBm
   Channel 100.................................. -97 dBm
   Channel 104.................................. -98 dBm
   Channel 108.................................. -97 dBm
   Channel 112.................................. -99 dBm
   Channel 116.................................. -99 dBm
   Channel 132.................................. -97 dBm
   Channel 136.................................. -97 dBm
   Channel 140.................................. -98 dBm
   Channel 149.................................. -98 dBm
   Channel 153.................................. -97 dBm
   Channel 157.................................. -97 dBm
   Channel 161.................................. -95 dBm
   Channel 165.................................. -96 dBm
   Channel 36...................................  -87 dBm @ 1 % busy
   Channel 165.................................. -128 dBm @ 0 % busy
   Channel 40................................... 1/ 0/ 0
   Channel 44................................... 0/ 0/ 0
   Channel 64................................... 0/ 0/ 1
   Channel 157.................................. 0/ 0/ 0
   Channel 161.................................. 1/ 0/ 0
   Channel 165.................................. 0/ 0/ 0
Load Information
   Channel Utilization.......................... 1 %
   RSSI -76 dbm................................ 1 clients
   RSSI -68 dbm................................ 3 clients
   SNR   25 dB.................................. 2 clients
   SNR   40 dB.................................. 1 clients
Nearby APs
   AP 00:22:55:df:9e:70 slot 1.................. -88 dBm on 36 (10.125.18.15)
Radar Information
   Last Channel Change Time..................... Wed Oct 9 10:59:07 2013
   Recommended Best Channel..................... 153
AP Name.......................................... KN1252_AP02
Noise Information
   Channel 1.................................... -96 dBm
   Channel 3.................................... -93 dBm
   Channel 4.................................... -80 dBm
   Channel 5.................................... -95 dBm
   Channel 6.................................... -96 dBm
   Channel 7.................................... -88 dBm
   Channel 8.................................... -72 dBm
   Channel 9.................................... -96 dBm
   Channel 10................................... -96 dBm
   Channel 11................................... -97 dBm
   Channel 1.................................... -76 dBm @ 3 % busy
   Channel 3.................................... -128 dBm @ 0 % busy
   Channel 6.................................... -77 dBm @ 4 % busy
   Channel 7.................................... -128 dBm @ 0 % busy
   Channel 10................................... -62 dBm @ 2 % busy
   Channel 11................................... -75 dBm @ 3 % busy
Load Information
   Transmit Utilization......................... 15 %
   Channel Utilization.......................... 40 %
   RSSI -84 dbm................................ 2 clients
   RSSI -60 dbm................................ 1 clients
   SNR   15 dB.................................. 2 clients
   SNR   20 dB.................................. 1 clients
   SNR   25 dB.................................. 1 clients
   SNR   30 dB.................................. 3 clients
Nearby APs
   AP 00:22:55:df:a5:90 slot 0.................. -74 dBm on   1 (10.125.18.15)
Radar Information
   Last Channel Change Time..................... Wed Oct 9 10:59:08 2013
Noise Information
   Channel 36................................... -98 dBm
   Channel 40................................... -99 dBm
   Channel 44................................... -99 dBm
   Channel 48................................... -99 dBm
   Channel 52................................... -99 dBm
   Channel 56................................... -99 dBm
   Channel 64................................... -99 dBm
    Channel 100.................................. -98 dBm
   Channel 104.................................. -99 dBm
   Channel 108.................................. -99 dBm
   Channel 116.................................. -98 dBm
   Channel 132.................................. -98 dBm
   Channel 136.................................. -99 dBm
   Channel 149.................................. -97 dBm
   Channel 157.................................. -96 dBm
   Channel 161.................................. -96 dBm
   Channel 165.................................. -95 dBm
   Channel 153.................................. -83 dBm @ 8 % busy
   Channel 40................................... 0/ 0/ 0
   Channel 149.................................. 0/ 2/ 0
   Channel 153.................................. 1/ 0/ 1
Load Information
Nearby APs
   AP 00:22:55:df:a5:90 slot 1.................. -79 dBm on 153 (10.125.18.15)
Radar Information
AP Name.......................................... Anham_AP03
Noise Information
   Channel 1.................................... -89 dBm
   Channel 2.................................... -92 dBm
   Channel 4.................................... -71 dBm
   Channel 5.................................... -92 dBm
   Channel 6.................................... -93 dBm
   Channel 7.................................... -91 dBm
   Channel 8.................................... -90 dBm
   Channel 9.................................... -88 dBm
   Channel 1.................................... -74 dBm @ 5 % busy
   Channel 6.................................... -69 dBm @ 1 % busy
   Channel 7.................................... -81 dBm @ 1 % busy
   Channel 10................................... -69 dBm @ 1 % busy
   Channel 11................................... -73 dBm @ 3 % busy
Load Information
   Transmit Utilization......................... 8 %
   Channel Utilization.......................... 20 %
   RSSI -52 dbm................................ 1 clients
Nearby APs
   AP 00:08:30:d7:72:90 slot 0.................. -53 dBm on  6 (10.125.18.15)
   AP 00:08:30:e4:0d:b0 slot 0.................. -70 dBm on 11 (10.125.18.15)
Radar Information
   Last Channel Change Time..................... Wed Oct 30 14:27:11 2013
Noise Information
   Channel 36................................... -99 dBm
   Channel 40................................... -98 dBm
   Channel 60................................... -100 dBm
   Channel 64................................... -100 dBm
   Channel 100.................................. -99 dBm
   Channel 112.................................. -100 dBm
   Channel 116.................................. -100 dBm
   Channel 140.................................. -97 dBm
   Channel 149.................................. -96 dBm
   Channel 153.................................. -93 dBm
   Channel 157.................................. -95 dBm
   Channel 165.................................. -94 dBm
   Channel 48................................... 1/ 0/ 0
   Channel 149.................................. 1/ 0/ 0
   Channel 153.................................. 1/ 0/ 0
Load Information
   Transmit Utilization......................... 1 %
Nearby APs
   AP 00:08:30:d7:72:90 slot 1.................. -68 dBm on 48 (10.125.18.15)
   AP 00:08:30:e4:0d:b0 slot 1.................. -81 dBm on 149 (10.125.18.15)
Radar Information
   Recommended Best Channel..................... 40
AP Name.......................................... ANHAM_AP01
Noise Information
   Channel 1.................................... -61 dBm
   Channel 2.................................... -61 dBm
   Channel 3.................................... -77 dBm
   Channel 4.................................... -91 dBm
   Channel 5.................................... -85 dBm
   Channel 6.................................... -91 dBm
   Channel 1....................................   0 dBm @ 1 % busy
   Channel 2....................................   -1 dBm @ 1 % busy
   Channel 3.................................... -14 dBm @ 1 % busy
   Channel 6.................................... -71 dBm @ 2 % busy
   Channel 10................................... -72 dBm @ 1 % busy
   Channel 11................................... -78 dBm @ 1 % busy
Load Information
   Transmit Utilization......................... 12 %
   Channel Utilization.......................... 25 %
   SNR   5 dB.................................. 1 clients
Nearby APs
   AP 00:08:30:5d:c1:90 slot 0.................. -69 dBm on   1 (10.125.18.15)
   AP 00:08:30:d7:72:90 slot 0.................. -67 dBm on   6 (10.125.18.15)
   AP 00:1d:71:09:32:b0 slot 0.................. -61 dBm on   6 (10.125.18.15)
Radar Information
   Current Channel Average Energy............... -72 dBm
   Previous Channel Average Energy.............. -57 dBm
   Last Channel Change Time..................... Sun Nov 3 04:10:19 2013
Noise Information
   Channel 36................................... -94 dBm
   Channel 108.................................. -98 dBm
   Channel 112.................................. -98 dBm
   Channel 132.................................. -95 dBm
   Channel 136.................................. -95 dBm
   Channel 140.................................. -96 dBm
   Channel 153.................................. -96 dBm
   Channel 64................................... 1/ 0/ 0
   Channel 153.................................. 0/ 0/ 0
Load Information
   SNR   10 dB.................................. 1 clients
Nearby APs
   AP 00:08:30:5d:c1:90 slot 1.................. -87 dBm on 40 (10.125.18.15)
   AP 00:08:30:d7:72:90 slot 1.................. -84 dBm on 48 (10.125.18.15)
   AP 00:1d:71:09:32:b0 slot 1.................. -76 dBm on 64 (10.125.18.15)
Radar Information
   Last Channel Change Time..................... Wed Oct 30 14:27:22 2013
   Recommended Best Channel..................... 149
AP Name.......................................... ANHAM_AP04
Noise Information
   Channel 1.................................... -95 dBm
   Channel 2.................................... -93 dBm
   Channel 4.................................... -87 dBm
   Channel 6.................................... -92 dBm
   Channel 7.................................... -94 dBm
   Channel 9.................................... -95 dBm
   Channel 11................................... -93 dBm
   Channel 1.................................... -70 dBm @ 3 % busy
   Channel 2.................................... -56 dBm @ 2 % busy
   Channel 3.................................... -75 dBm @ 3 % busy
   Channel 6.................................... -69 dBm @ 5 % busy
   Channel 7.................................... -77 dBm @ 4 % busy
   Channel 10................................... -70 dBm @ 3 % busy
   Channel 11................................... -66 dBm @ 3 % busy
Load Information
   Transmit Utilization......................... 9 %
   Attached Clients............................. 1 clients
   RSSI -92 dbm................................ 1 clients
   RSSI -68 dbm................................ 4 clients
   RSSI -60 dbm................................ 6 clients
   SNR   35 dB.................................. 5 clients
Nearby APs
   AP 00:08:30:5d:c1:90 slot 0.................. -93 dBm on   1 (10.125.18.15)
   AP 00:08:30:d7:72:90 slot 0.................. -86 dBm on   6 (10.125.18.15)
Radar Information
   Current Channel Average Energy............... -75 dBm
   Previous Channel Average Energy.............. -58 dBm
   Last Channel Change Time..................... Wed Oct 30 16:06:30 2013
   Recommended Best Channel..................... 6
Noise Information
   Channel 36................................... -95 dBm
   Channel 52................................... -95 dBm
   Channel 56................................... -96 dBm
    Channel 64................................... -97 dBm
   Channel 100.................................. -96 dBm
   Channel 104.................................. -96 dBm
   Channel 108.................................. -93 dBm
   Channel 112.................................. -95 dBm
   Channel 116.................................. -96 dBm
   Channel 132.................................. -96 dBm
   Channel 136.................................. -91 dBm
   Channel 140.................................. -95 dBm
   Channel 36................................... 2/ 0/ 0
    Channel 56................................... 1/ 0/ 0
   Channel 161.................................. 2/ 0/ 0
Load Information
Nearby APs
   AP 00:08:30:e4:0d:b0 slot 1.................. -77 dBm on 149 (10.125.18.15)
Radar Information
   Previous Channel Average Energy.............. -66 dBm
   Last Channel Change Time..................... Fri Nov 1 09:43:03 2013
   Recommended Best Channel..................... 64
AP Name.......................................... ANHAM_AP02
Noise Information
   Channel 3.................................... -91 dBm
   Channel 9.................................... -89 dBm
   Channel 10................................... -84 dBm
   Channel 11................................... -95 dBm
   Channel 2.................................... -75 dBm @ 1 % busy
   Channel 6.................................... -67 dBm @ 1 % busy
   Channel 7.................................... -72 dBm @ 1 % busy
   Channel 10................................... -128 dBm @ 0 % busy
   Channel 11................................... -128 dBm @ 0 % busy
Load Information
   Channel Utilization.......................... 26 %
   SNR   25 dB.................................. 3 clients
Nearby APs
   AP 00:08:30:5d:c1:90 slot 0.................. -58 dBm on   1 (10.125.18.15)
   AP 00:08:30:e4:0d:b0 slot 0.................. -71 dBm on 11 (10.125.18.15)
   AP 00:1d:71:09:32:b0 slot 0.................. -86 dBm on   6 (10.125.18.15)
Radar Information
   Last Channel Change Time..................... Wed Oct 30 15:57:39 2013
Noise Information
   Channel 44................................... -100 dBm
   Channel 48................................... -100 dBm
   Channel 52................................... -100 dBm
   Channel 161.................................. -97 dBm
   Channel 165.................................. -97 dBm
Load Information
Nearby APs
   AP 00:08:30:5d:c1:90 slot 1.................. -72 dBm on 40 (10.125.18.15)
   AP 00:08:30:e4:0d:b0 slot 1.................. -79 dBm on 149 (10.125.18.15)
Radar Information
   Recommended Best Channel..................... 48
802.11a Configuration
802.11a Network.................................. Enabled
11nSupport....................................... Enabled
     802.11a Low Band........................... Enabled
     802.11a Mid Band........................... Enabled
     802.11a High Band.......................... Enabled
802.11a Operational Rates
   802.11a 6M Rate.............................. Mandatory
   802.11a 9M Rate.............................. Supported
   802.11a 12M Rate............................. Mandatory
   802.11a 18M Rate............................. Supported
   802.11a 24M Rate............................. Mandatory
   802.11a 36M Rate............................. Supported
   802.11a 48M Rate............................. Supported
   802.11a 54M Rate............................. Supported
802.11n MCS Settings:
   MCS 0........................................ Supported
   MCS 1........................................ Supported
   MCS 2........................................ Supported
   MCS 3........................................ Supported
    MCS 4........................................ Supported
   MCS 5........................................ Supported
   MCS 6........................................ Supported
   MCS 7........................................ Supported
   MCS 8........................................ Supported
   MCS 9........................................ Supported
   MCS 10....................................... Supported
   MCS 11....................................... Supported
   MCS 12....................................... Supported
   MCS 13....................................... Supported
   MCS 14....................................... Supported
   MCS 15....................................... Supported
802.11n Status:
   A-MPDU Tx:
       Priority 0............................... Enabled
       Priority 1............................... Disabled
       Priority 2............................... Disabled
       Priority 3............................... Disabled
       Priority 4............................... Enabled
       Priority 5............................... Enabled
       Priority 6............................... Disabled
       Priority 7............................... Disabled
   A-MSDU Tx:
       Priority 1............................... Enabled
       Priority 2............................... Enabled
       Priority 3............................... Enabled
   Rifs Rx ..................................... Enabled
   Guard Interval .............................. Any
Beacon Interval.................................. 100
CF Pollable mandatory............................ Disabled
CF Poll Request mandatory........................ Disabled
CFP Period....................................... 4
CFP Maximum Duration............................. 60
Default Channel.................................. 36
Default Tx Power Level........................... 0
DTPC Status..................................... Enabled
Fragmentation Threshold.......................... 2346
TI Threshold..................................... -50
Legacy Tx Beamforming setting.................... Disabled
Traffic Stream Metrics Status.................... Disabled
Expedited BW Request Status...................... Disabled
World Mode....................................... Enabled
EDCA profile type................................ default-wmm
Voice MAC optimization status.................... Disabled
Call Admission Control (CAC) configuration
Voice AC:
   Voice AC - Admission control (ACM)............ Disabled
   Voice Stream-Size............................. 84000
   Voice Max-Streams............................. 2
   Voice max RF bandwidth........................ 75
   Voice reserved roaming bandwidth.............. 6
   Voice CAC Method ............................. Load-Based
   Voice tspec inactivity timeout................ Disabled
CAC SIP-Voice configuration
   SIP based CAC ................................ Disabled
   SIP Codec Type ............................... CODEC_TYPE_G711
   SIP call bandwidth ........................... 64
   SIP call bandwith sample-size ................ 20
Video AC:
   Video AC - Admission control (ACM)............ Disabled
   Video max RF bandwidth........................ Infinite
   Video reserved roaming bandwidth.............. 0
   Best-effort AC - Admission control (ACM)...... Disabled
   Background AC - Admission control (ACM)....... Disabled
802.11a Advanced Configuration
AP Name                         MAC Address       Admin State Operation State Channel   TxPower
KNOWLOGY_DC01                   00:1d:71:09:8f:90 ENABLED     UP             44*         1(*)
KNOWLOGY_DC02                   00:22:55:a5:0c:30 ENABLED     UP             36*         1(*)
KN1252_AP01                     00:22:55:df:a5:90 ENABLED     UP             153*         1(*)
KN1252_AP02                     00:22:55:df:9e:70 ENABLED      UP             36*         1(*)
Anham_AP03                       00:08:30:5d:c1:90 ENABLED     UP             40*         1(*)
ANHAM_AP01                       00:08:30:e4:0d:b0 ENABLED     UP             149*         1(*)
ANHAM_AP04                      00:1d:71:09:32:b0 ENABLED     UP             64*         1(*)
ANHAM_AP02                       00:08:30:d7:72:90 ENABLED     UP             48*         1(*)
802.11a Airewave Director Configuration
RF Event and Performance Logging
Channel Update Logging......................... Off
Coverage Profile Logging....................... Off
Foreign Profile Logging........................ Off
Load Profile Logging........................... Off
Noise Profile Logging.......................... Off
Performance Profile Logging.................... Off
TxPower Update Logging......................... Off
Default 802.11a AP performance profiles
802.11a Global Interference threshold.......... 10 %
802.11a Global noise threshold................. -70 dBm
802.11a Global RF utilization threshold........ 80 %
802.11a Global throughput threshold............ 1000000 bps
802.11a Global clients threshold............... 12 clients
Default 802.11a AP monitoring
802.11a Monitor Mode........................... enable
802.11a Monitor Mode for Mesh AP Backhaul...... disable
802.11a Monitor Channels....................... Country channels
802.11a RRM Neighbor Discover Type............. Transparent
802.11a AP Coverage Interval................... 180 seconds
802.11a AP Load Interval....................... 60 seconds
802.11a AP Noise Interval...................... 180 seconds
802.11a AP Signal Strength Interval............ 60 seconds
Automatic Transmit Power Assignment
Transmit Power Assignment Mode................. AUTO
Transmit Power Update Interval................. 600 seconds
Transmit Power Threshold....................... -70 dBm
Transmit Power Neighbor Count.................. 3 APs
Min Transmit Power............................. -10 dBm
Max Transmit Power............................. 30 dBm
Transmit Power Update Contribution............. SNI..
Transmit Power Assignment Leader............... WLAN Controller 5508 (10.125.18.15)
Last Run....................................... 64 seconds ago
Coverage Hole Detection
802.11a Coverage Hole Detection Mode........... Enabled
802.11a Coverage Voice Packet Count............ 100 packets
802.11a Coverage Voice Packet Percentage....... 50%
802.11a Coverage Voice RSSI Threshold.......... -80 dBm
802.11a Coverage Data Packet Count............. 50 packets
802.11a Coverage Data Packet Percentage........ 50%
802.11a Coverage Data RSSI Threshold........... -80 dBm
802.11a Global coverage exception level........ 25 %
802.11a Global client minimum exception lev.... 3 clients
Automatic Channel Assignment
Channel Assignment Mode........................ AUTO
Channel Update Interval........................ 600 seconds
Anchor time (Hour of the day).................. 0
Channel Update Contribution.................... SNI..
CleanAir Event-driven RRM option............... Disabled
CleanAir Event-driven RRM sensitivity.......... Medium
Channel Assignment Leader...................... WLAN Controller 5508 (10.125.18.15)
DCA Sensitivity Level.......................... MEDIUM (15 dB)
DCA 802.11n Channel Width...................... 20 MHz
DCA Minimum Energy Limit....................... -95 dBm
Channel Energy Levels
   Minimum...................................... -86 dBm
   Average...................................... -86 dBm
   Maximum...................................... -86 dBm
Channel Dwell Times
   Minimum...................................... 3 days, 01 h 40 m 18 s
   Average...................................... 18 days, 18 h 35 m 56 s
   Maximum...................................... 40 days, 13 h 58 m 47 s
802.11a 5 GHz Auto-RF Channel List
   Allowed Channel List......................... 36,40,44,48,52,56,60,64,149,
                                                 153,157,161
   Unused Channel List.......................... 100,104,108,112,116,132,136,
                                                140,165
802.11a 4.9 GHz Auto-RF Channel List
   Unused Channel List.......................... 1,2,3,4,5,6,7,8,9,10,11,12,
                                                 13,14,15,16,17,18,19,20,21,
                                                 22,23,24,25,26
DCA Outdoor AP option.......................... Disabled
Radio RF Grouping
802.11a Group Mode............................. AUTO
802.11a Group Update Interval.................. 600 seconds
802.11a Group Leader........................... WLAN Controller 5508 (10.125.18.15)
   802.11a Group Member......................... WLAN Controller 5508 (10.125.18.15)
802.11a Last Run............................... 64 seconds ago
802.11a CleanAir Configuration
Clean Air Solution............................... Disabled
Air Quality Settings:
   Air Quality Reporting........................ Enabled
   Air Quality Reporting Period (min)........... 15
   Air Quality Alarms........................... Enabled
   Air Quality Alarm Threshold.................. 35
Interference Device Settings:
   Interference Device Reporting................ Enabled
   Interference Device Types:
       TDD Transmitter.......................... Enabled
       Jammer................................... Enabled
       Continuous Transmitter................... Enabled
       DECT-like Phone.......................... Enabled
      Video Camera............................. Enabled
       WiFi Inverted............................ Enabled
       WiFi Invalid Channel..................... Enabled
       SuperAG.................................. Enabled
       Canopy................................... Enabled
       WiMax Mobile............................. Enabled
       WiMax Fixed.............................. Enabled
   Interference Device Alarms................... Enabled
   Interference Device Types Triggering Alarms:
       TDD Transmitter.......................... Disabled
       Continuous Transmitter................... Disabled
       DECT-like Phone.......................... Disabled
       Video Camera............................. Disabled
       SuperAG.................................. Disabled
       Canopy................................... Disabled
       WiMax Mobile............................. Disabled
       WiMax Fixed.............................. Disabled
Additional Clean Air Settings:
   CleanAir Event-driven RRM State.............. Disabled
   CleanAir Driven RRM Sensitivity.............. Medium
   CleanAir Persistent Devices state............ Disabled
802.11a CleanAir AirQuality Summary
AQ = Air Quality
DFS = Dynamic Frequency Selection
AP Name           Channel Avg AQ Min AQ Interferers DFS
Press Enter to continue or <ctrl-z> to abort
802.11b Configuration
802.11b Network.................................. Enabled
11gSupport....................................... Disabled
802.11b Operational Rates
   802.11b 1M Rate.............................. Mandatory
   802.11b 2M Rate.............................. Mandatory
   802.11b 5.5M Rate............................ Mandatory
   802.11b 11M Rate............................. Mandatory
802.11n Status:
   A-MPDU Tx:
   A-MSDU Tx:
CF Pollable mode................................. Disabled
Default Channel.................................. 1
Call Admission Limit ........................... 105
G711 CU Quantum ................................. 15
ED Threshold..................................... -50
PBCC mandatory................................... Disabled
RTS Threshold.................................... 2347
Short Preamble mandatory......................... Enabled
Short Retry Limit................................ 7
Faster Carrier Tracking Loop..................... Disabled
   Voice CAC Method.............................. Load-Based
   SIP call bandwidth: .......................... 64
   SIP call bandwidth sample-size ............... 20
802.11b Advanced Configuration
KNOWLOGY_DC01                   00:1d:71:09:8f:90 ENABLED     UP             11*         1(*)
KNOWLOGY_DC02                   00:22:55:a5:0c:30 ENABLED     UP             1*           1(*)
KN1252_AP01                     00:22:55:df:a5:90 ENABLED     UP             1*           1(*)
KN1252_AP02                     00:22:55:df:9e:70 ENABLED     UP             1*           1(*)
Anham_AP03                       00:08:30:5d:c1:90 ENABLED     UP             1*           1(*)
ANHAM_AP01                       00:08:30:e4:0d:b0 ENABLED     UP             11*         1(*)
ANHAM_AP04                      00:1d:71:09:32:b0 ENABLED     UP             6*           1(*)
ANHAM_AP02                       00:08:30:d7:72:90 ENABLED     UP             6*           1(*)
802.11b Airewave Director Configuration
Transmit Power Update Logging.................. Off
Default 802.11b AP performance profiles
802.11b Global Interference threshold.......... 10 %
802.11b Global noise threshold................. -70 dBm
802.11b Global RF utilization threshold........ 80 %
802.11b Global throughput threshold............ 1000000 bps
802.11b Global clients threshold............... 12 clients
Default 802.11b AP monitoring
802.11b Monitor Mode........................... enable
802.11b Monitor Channels....................... Country channels
802.11b RRM Neighbor Discovery Type............ Transparent
802.11b AP Coverage Interval................... 180 seconds
802.11b AP Load Interval....................... 60 seconds
802.11b AP Noise Interval...................... 180 seconds
802.11b AP Signal Strength Interval............ 60 seconds
Last Run....................................... 65 seconds ago
802.11b Coverage Hole Detection Mode........... Enabled
802.11b Coverage Voice Packet Count............ 100 packets
802.11b Coverage Voice Packet Percentage....... 50%
802.11b Coverage Voice RSSI Threshold.......... -80 dBm
802.11b Coverage Data Packet Count............. 50 packets
802.11b Coverage Data Packet Percentage........ 50%
802.11b Coverage Data RSSI Threshold........... -80 dBm
802.11b Global coverage exception level........ 25 %
802.11b Global client minimum exception lev.... 3 clients
DCA Sensitivity Level: ...................... MEDIUM (10 dB)
   Minimum...................................... -80 dBm
   Average...................................... -75 dBm
   Maximum...................................... -72 dBm
Channel Dwell Times
   Minimum...................................... 1 days, 06 h 13 m 02 s
   Average...................................... 16 days, 20 h 34 m 48 s
   Maximum...................................... 40 days, 13 h 58 m 48 s
802.11b Auto-RF Allowed Channel List........... 1,6,11
Auto-RF Unused Channel List.................... 2,3,4,5,7,8,9,10
Radio RF Grouping
802.11b Group Mode............................. AUTO
802.11b Group Update Interval.................. 600 seconds
802.11b Group Leader........................... WLAN Controller 5508 (10.125.18.15)
   802.11b Group Member......................... WLAN Controller 5508 (10.125.18.15)
802.11b Last Run............................... 65 seconds ago
       Bluetooth Link........................... Enabled
       Microwave Oven........................... Enabled
       802.11 FH................................ Enabled
       Bluetooth Discovery...................... Enabled
       802.15.4................................. Enabled
       Microsoft Device......................... Enabled
       Bluetooth Link........................... Disabled
       Microwave Oven........................... Disabled
       802.11 FH................................ Disabled
       Bluetooth Discovery...................... Disabled
       802.15.4................................. Disabled
       Microsoft Device......................... Disabled
AQ = Air Quality
Mobility Configuration
Symmetric Mobility Tunneling (current) .......... Enabled
Symmetric Mobility Tunneling (after reboot) ..... Enabled
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... OGR
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0x2e80
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 1
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
MAC Address       IP Address       Group Name                       Multicast IP     Status
30:e4:db:1b:99:80 10.125.18.15     OGR                               0.0.0.0         Up
Mobility Foreign Map Configuration
WLAN ID     Foreign Mac Address     Interface
Probe request filtering.......................... Enabled
Probes fwd to controller per client per radio.... 2
Probe request rate-limiting interval............. 500 msec
Aggregate Probe request interval................. 500 msec
EAP-Identity-Request Timeout (seconds)........... 30
EAP-Identity-Request Max Retries................. 2
EAP Key-Index for Dynamic WEP.................... 0
EAP Max-Login Ignore Identity Response........... enable
EAP-Request Timeout (seconds).................... 30
EAP-Request Max Retries.......................... 2
EAPOL-Key Timeout (milliseconds)................. 1000
EAPOL-Key Max Retries............................ 2
EAP-Broadcast Key Interval....................... 3600
Fastpath Packet Capture.......................... disable
Fastpath Fast Cache Control...................... enable
Fastpath Fast Testmode........................... 0x0
dot11-padding.................................... Disabled
Location Configuration
RFID Tag data Collection......................... Enabled
RFID timeout.................................... 1200 seconds
RFID mobility.................................... Oui:00:14:7e : Vendor:pango State:Disabled
Interface Configuration
Interface Name................................... knowlogy_ogr
MAC Address...................................... 30:e4:db:1b:99:84
IP Address....................................... 10.125.1.15
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 10.125.1.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 101
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 10.1.1.15
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
L2 Multicast..................................... Enabled
Interface Name................................... management
MAC Address...................................... 30:e4:db:1b:99:80
IP Address....................................... 10.125.18.15
IP Gateway....................................... 10.125.18.1
VLAN............................................. 118
AP Manager....................................... Yes
Interface Name................................... service-port
MAC Address...................................... 30:e4:db:1b:99:81
IP Address....................................... 0.0.0.0
DHCP Protocol.................................... Enabled
Interface Name................................... virtual
IP Address....................................... 1.1.1.1
Virtual DNS Host Name............................ Disabled
Interface Group Configuration
WLAN Configuration
WLAN Identifier.................................. 1
Profile Name..................................... ANHAM Internal Staff
Network Name (SSID).............................. ASTAFF
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 13
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ knowlogy_ogr
Multicast Interface.............................. Not Configured
--More or (q)uit current module or <ctrl-z> to abort
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
     WPA (SSN IE)............................... Disabled
     WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
      Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT(802.11r)............................. Disabled
         FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
CCKM tsf Tolerance............................... 1000
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Enabled
   H-REAP Local Authentication................... Disabled
H-REAP Learn IP Address....................... Enabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
WLAN ID     IP Address           Status
WLAN Configuration
WLAN Identifier.................................. 2
Profile Name..................................... Knowlogy Internal Staff
Network Name (SSID).............................. KSTAFF
Broadcast SSID................................... Disabled
Number of Active Clients......................... 8
Radius Servers
Security
      Auth Key Management
WLAN Configuration
WLAN Identifier.................................. 3
Profile Name..................................... Guest KNOWLOGY DC Office
Network Name (SSID).............................. DCGuest
Number of Active Clients......................... 2
Scan Defer Priority.............................. 4,5,6
Radius Servers
Security
      Auth Key Management
WLAN Configuration
WLAN Identifier.................................. 4
Profile Name..................................... Knowlogy Mobile Devices
Network Name (SSID).............................. KMOBILE
Number of Active Clients......................... 0
Radius Servers
   Authentication................................ Disabled
   Accounting.................................... Disabled
Security
      Auth Key Management
WLAN Configuration
WLAN Identifier.................................. 5
Profile Name..................................... Test1
Network Name (SSID).............................. Test1
Radius Servers
Security
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   Client MFP.................................... Optional but inactive (WPA2 not configured)
WLAN Configuration
WLAN Identifier.................................. 6
Profile Name..................................... ANHAM Mobile Devices
Network Name (SSID).............................. AMOBILE
Number of Active Clients......................... 28
Radius Servers
Security
      Auth Key Management
WLAN Configuration
WLAN Identifier.................................. 7
Profile Name..................................... ANHAM OLD
Network Name (SSID).............................. HFNOUR01
Number of Active Clients......................... 9
Radius Servers
Security
         TKIP Cipher............................. Enabled
      Auth Key Management
WLAN Configuration
WLAN Identifier.................................. 8
Network Name (SSID).............................. OGRGuest
Radius Servers
Security
   Web Based Authentication...................... Enabled
      ACL............................................. Unconfigured
      Web Authentication server precedence:
      1............................................... ldap
      2............................................... local
      3............................................... radius
WLAN Configuration
WLAN Identifier.................................. 9
Profile Name..................................... Guest ANHAM 8075
Network Name (SSID).............................. LPGuest
Quality of Service............................... Bronze (background)
Radius Servers
Security
      1............................................... local
      2............................................... radius
      3............................................... ldap
WLAN Configuration
WLAN Identifier.................................. 10
Profile Name..................................... Test2
Network Name (SSID).............................. Test2
Status........................................... Disabled
Interface........................................ management
Radius Servers
Security
      Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
   H-REAP Local Switching........................ Disabled
ACL Configuration
ACL name: ANHAM_Guest
                       Source                       Destination               Source Port Dest Port
Index Dir       IP Address/Netmask             IP Address/Netmask       Prot   Range       Range   DSCP Action    Counter
     1 Any     10.120.12.0/255.255.255.0       10.120.1.9/255.255.255.255 Any     0-65535     0-65535 Any Permit           0
     2 Any     10.120.12.0/255.255.255.0       10.120.12.0/255.255.255.0   Any     0-65535     0-65535 Any Permit           0
     3 Any     10.120.12.0/255.255.255.0         10.0.0.0/255.0.0.0       Any     0-65535     0-65535 Any   Deny           0
     4 Any     10.120.12.0/255.255.255.0       192.168.0.0/255.255.0.0     Any     0-65535     0-65535 Any   Deny           0
     5 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0         Any     0-65535     0-65535 Any Permit           0
ACL name: Knowlogy Guest
     1 Any     10.125.12.0/255.255.255.0       10.125.12.0/255.255.255.0   Any     0-65535     0-65535 Any Permit           0
     2 Any     10.125.12.0/255.255.255.0         10.1.1.15/255.255.255.255 Any     0-65535     0-65535 Any Permit           0
     3 Any     10.125.12.0/255.255.255.0         10.0.0.0/255.255.255.0   Any     0-65535     0-65535 Any Permit           0
     4 Any     10.125.12.0/255.255.255.0           0.0.0.0/0.0.0.0         Any     0-65535     0-65535 Any Permit           0
CPU ACL Configuration
CPU Acl Name................................ NOT CONFIGURED
Wireless Traffic............................ Disabled
Wired Traffic............................... Disabled
RADIUS Configuration
Vendor Id Backward Compatibility................. Disabled
Call Station Id Case............................. lower
Call Station Id Type............................. IP Address
Aggressive Failover.............................. Enabled
Keywrap.......................................... Disabled
Fallback Test:
   Test Mode.................................... Off
   Probe User Name.............................. cisco-probe
   Interval (in seconds)........................ 300
MAC Delimiter for Authentication Messages........ hyphen
MAC Delimiter for Accounting Messages............ hyphen
Authentication Servers
Idx Type Server Address   Port   State     Tout RFC3576 IPSec - AuthMode/Phase1/Group/Lifetime/Auth/Encr
Accounting Servers
TACACS Configuration
Idx Server Address   Port   State    Tout
Authorization Servers
Accounting Servers
LDAP Configuration
Idx Server Address   Port Enabled
1   10.1.1.15       389   Yes
Local EAP Configuration
User credentials database search order:
   Primary ..................................... Local DB
   Secondary ................................... LDAP
Timer:
   Active timeout .............................. 300
Configured EAP profiles:
EAP Method configuration:
   EAP-FAST:
     Server key ................................ <hidden>
     TTL for the PAC ........................... 10
     Anonymous provision allowed ............... Yes
     Authority ID .............................. 436973636f0000000000000000000000
     Authority Information ..................... Cisco A-ID
HREAP Group Summary
HREAP Group Summary: Count: 1
Group Name              # Aps
ANHAM_8075                 0
HREAP Group Detail
HREAP Group Name - ANHAM_8075
Number of Ap's in Group: 0
Group Radius Servers Settings:
Primary Server Index............................ Disabled
Secondary Server Index.......................... Disabled
Group Radius AP Settings:
AP RADIUS server............ Disabled
EAP-FAST Auth............... Disabled
LEAP Auth................... Disabled
Server Key Auto Generated... No
Server Key..................     <hidden>
Authority ID................ 436973636f0000000000000000000000
Authority Info.............. Cisco A_ID
PAC Timeout................. 0
Number of User's in Group: 0
Route Info
Number of Routes................................. 0
Destination Network         Netmask               Gateway
Qos Queue Length Info
Platinum queue length............................ 100
Gold queue length................................ 75
Silver queue length.............................. 50
Bronze queue length.............................. 25
Mac Filter Info
Authorization List
Authorize MIC APs against AAA ................... disabled
Authorize LSC APs against Auth-List ............. disabled
APs Allowed to Join
AP with Manufacturing Installed Certificate.... yes
AP with Self-Signed Certificate................ no
AP with Locally Significant Certificate........ no
Load Balancing Info
Aggressive Load Balancing........................ per WLAN enabling
Aggressive Load Balancing Window................. 5 clients
Aggressive Load Balancing Denial Count........... 3
Statistics
Total Denied Count............................... 0 clients
Total Denial Sent................................ 0 messages
Exceeded Denial Max Limit Count.................. 0 times
None 5G Candidate Count.......................... 0 times
None 2.4G Candidate Count........................ 0 times
DHCP Info
No leases allocated.
DHCP Opt-82 RID Format: <AP radio MAC address>
DHCP Proxy Behaviour:   disabled
Exclusion List ConfigurationUnable to retrieve exclusion-list entry
CDP Configuration
cdp version v2
Country Channels Configuration
Configured Country............................. US - United States
     KEY: * = Channel is legal in this country and may be configured manually.
           A = Channel is the Auto-RF default in this country.
           . = Channel is not legal in this country.
           C = Channel has been configured for use by Auto-RF.
           x = Channel is available to be configured for use by Auto-RF.
         (-,-) = (indoor, outdoor) regulatory doamin allowed by this country.
   802.11bg     :
   Channels     :                   1 1 1 1 1
                 : 1 2 3 4 5 6 7 8 9 0 1 2 3 4
US (-A   ,-AB ): A * * * * A * * * * A . . .
   802.11a     :                         1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
   Channels     : 3 3 3 4 4 4 4 4 5 5 6 6 0 0 0 1 1 2 2 2 3 3 4 4 5 5 6 6
                 : 4 6 8 0 2 4 6 8 2 6 0 4 0 4 8 2 6 0 4 8 2 6 0 9 3 7 1 5
US (-A   ,-AB ): . A . A . A . A A A A A * * * * * . . . * * * A A A A *
4.9GHz 802.11a :
   Channels     :                   1 1 1 1 1 1 1 1 1 1 2 2 2 2 2 2 2
                 : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6
US (-A   ,-AB ): * * * * * * * * * * * * * * * * * * * A * * * * * A
WPS Configuration Summary
Auto-Immune
Auto-Immune.................................... Disabled
Client Exclusion Policy
Excessive 802.11-association failures.......... Enabled
Excessive 802.11-authentication failures....... Enabled
Excessive 802.1x-authentication................ Enabled
IP-theft....................................... Enabled
Excessive Web authentication failure........... Enabled
Signature Policy
Signature Processing........................... Enabled
Custom Web Configuration
Radius Authentication Method..................... PAP
Cisco Logo....................................... Enabled
CustomLogo....................................... None
Custom Title..................................... Welcome to the Guest Wireless Network
Custom Message................................... Please Contact the Front Desk for a Username and Password.
Custom Redirect URL.............................. None
Web Authentication Type.......................... Internal Default
External Web Authentication URL.................. None
Configuration Per Profile:
WLAN ID: 8
   WLAN Status................................... Enabled
   Web Security Policy........................... Web Based Authentication
   Global Status................................. Disabled
   WebAuth Type.................................. Internal
WLAN ID: 9
Core dump Configuration
Core Dump is disabled
Rogue AP Configuration
Rogue on wire Auto-Contain....................... Disabled
Rogue using our SSID Auto-Contain................ Disabled
Valid client on rogue AP Auto-Contain............ Disabled
Rogue AP timeout................................. 1200
Monitor Mode Report Interval..................... 10
MAC Address       Classification     # APs # Clients Last Heard
00:02:6f:96:b9:68 Unclassified       1     0         Mon Nov 4 10:23:10 2013
00:02:6f:96:b9:69 Unclassified       1     0         Mon Nov 4 10:20:10 2013
00:12:17:7a:ad:9c  Unclassified       1     0         Mon Nov 4 10:23:10 2013
00:13:10:a0:c7:75 Unclassified       2     4         Mon Nov 4 10:23:04 2013
00:13:46:1b:f8:22 Unclassified       2     0         Mon Nov 4 10:20:04 2013
00:14:a9:d4:f5:c0 Unclassified      2     0         Mon Nov 4 10:14:04 2013
00:14:a9:d5:04:a0 Unclassified       2     1         Mon Nov 4 10:20:04 2013
00:15:e9:65:ac:29 Unclassified       2     0         Mon Nov 4 10:20:04 2013
00:15:ff:44:66:2b Unclassified       2     0        Mon Nov 4 10:20:04 2013
00:16:b6:4f:73:8b Unclassified       1     0         Mon Nov 4 10:17:10 2013
00:17:0f:35:81:70 Pending           1     0         Mon Nov 4 10:22:51 2013
00:17:c5:4f:cc:07 Unclassified       2     1         Mon Nov 4 10:20:57 2013
00:17:c5:85:2b:e7 Unclassified       1     0         Mon Nov 4 10:14:04 2013
00:17:c5:ba:e9:c5 Unclassified       1     0         Mon Nov 4 10:20:04 2013
00:17:c5:cf:4d:34 Unclassified       2     1         Mon Nov 4 10:22:21 2013
00:17:c5:de:77:e5 Unclassified       2     0         Mon Nov 4 10:23:04 2013
00:17:df:2f:3c:c0 Unclassified       1     0         Mon Nov 4 10:20:55 2013
00:18:39:18:23:ed Unclassified       1    0         Mon Nov 4 10:13:21 2013
00:18:3a:b6:65:73 Unclassified       1     0         Mon Nov 4 10:02:04 2013
00:1a:1e:c1:ea:40 Unclassified       2     0         Mon Nov 4 10:20:04 2013
00:1a:1e:c1:ea:41 Unclassified       2     0         Mon Nov 4 10:23:04 2013
00:1a:70:33:9e:4d Unclassified       1     0         Mon Nov 4 10:17:57 2013
00:1a:70:fb:d6:94 Unclassified       1     0         Mon Nov 4 10:23:10 2013
00:1b:90:76:51:20 Unclassified       2     0         Mon Nov 4 10:19:52 2013
00:1c:10:fe:6b:ec Unclassified       1     0         Mon Nov 4 10:16:51 2013
00:1e:4a:19:a5:b0 Unclassified       1     0         Mon Nov 4 10:13:21 2013
00:1e:58:fe:20:d7 Unclassified       2     0         Mon Nov 4 10:20:04 2013
00:21:29:6a:f5:42 Unclassified       2     0         Mon Nov 4 10:19:21 2013
00:22:6b:9d:1f:98 Unclassified       3     1         Mon Nov 4 10:22:51 2013
00:22:6b:9e:dc:70 Unclassified       1     0         Mon Nov 4 10:22:51 2013
00:25:4b:b9:23:92 Unclassified       1     0         Mon Nov 4 10:16:11 2013
00:25:9c:1e:01:1d Unclassified       2     0         Mon Nov 4 10:23:04 2013
00:25:9c:69:e8:06 Unclassified       1     1         Mon Nov 4 10:13:21 2013
00:26:52:db:2b:30 Unclassified       2    0         Mon Nov 4 10:14:04 2013
00:3a:98:81:61:10 Unclassified       1     0         Mon Nov 4 10:19:14 2013
00:3a:98:9b:bc:60 Unclassified       1     1         Mon Nov 4 10:08:56 2013
00:7f:28:86:bc:41 Unclassified       2     0         Mon Nov 4 10:20:04 2013
00:7f:28:fc:ea:49 Unclassified       1     0         Mon Nov 4 10:17:57 2013
00:80:48:65:70:34 Unclassified       2     0         Mon Nov 4 10:17:04 2013
0c:85:25:33:84:13  Unclassified       2     0         Mon Nov 4 10:19:11 2013
0c:85:25:33:84:14 Unclassified       2     0         Mon Nov 4 10:22:51 2013
0c:85:25:33:84:15 Unclassified       2     1         Mon Nov 4 10:22:11 2013
0c:85:25:33:84:17 Unclassified      2     0         Mon Nov 4 10:19:49 2013
0c:85:25:33:84:18 Unclassified       2     0         Mon Nov 4 10:22:51 2013
0c:85:25:33:84:1a Unclassified       2     0         Mon Nov 4 10:20:58 2013
0c:85:25:33:84:1b Unclassified       2     0        Mon Nov 4 10:22:50 2013
0c:85:25:33:84:1c Unclassified       2     0         Mon Nov 4 10:20:58 2013
0c:85:25:33:84:27 Unclassified       1     0         Mon Nov 4 10:21:58 2013
0c:85:25:33:84:2a Unclassified       1     0         Mon Nov 4 10:12:56 2013
0c:85:25:33:84:2b Unclassified       1     0         Mon Nov 4 10:21:58 2013
0c:85:25:33:84:2c Unclassified       1     0         Mon Nov 4 10:09:55 2013
20:aa:4b:f9:7a:ab Unclassified       2     2         Mon Nov 4 10:23:04 2013
20:aa:4b:f9:7a:ad Unclassified       2     0         Mon Nov 4 10:09:05 2013
20:e5:2a:11:ec:7f Unclassified       2     0         Mon Nov 4 10:21:05 2013
20:e5:2a:11:ec:80 Unclassified       2     0         Mon Nov 4 10:22:21 2013
20:e5:2a:19:3c:41  Unclassified       2     0         Mon Nov 4 10:21:56 2013
20:e5:2a:19:3c:42 Unclassified       2     0         Mon Nov 4 10:23:04 2013
2c:b0:5d:3b:36:15 Pending           1     0         Mon Nov 4 10:21:56 2013
2c:b0:5d:3b:36:16 Unclassified       2     0         Mon Nov 4 10:20:04 2013
2c:b0:5d:42:c0:1a Unclassified       2     0         Mon Nov 4 10:22:15 2013
2c:b0:5d:42:c0:1b Unclassified       2     2         Mon Nov 4 10:23:10 2013
30:14:4a:48:cc:bd Unclassified       2     0         Mon Nov 4 10:08:04 2013
34:bd:c8:b3:86:00 Unclassified       2     0         Mon Nov 4 10:19:21 2013
34:bd:c8:b3:86:01 Unclassified       2     0         Mon Nov 4 10:07:22 2013
48:f8:b3:6c:bc:fd Unclassified       2     4         Mon Nov 4 10:22:21 2013
48:f8:b3:6c:bc:ff Unclassified       2     0         Mon Nov 4 10:21:56 2013
50:06:04:8d:7e:f5 Unclassified       1     0         Mon Nov 4 10:23:10 2013
50:06:04:8d:7e:f7 Unclassified       1     0         Mon Nov 4 10:17:10 2013
50:06:04:8d:7e:f8 Unclassified       1     0         Mon Nov 4 10:23:10 2013
50:06:04:8d:7e:fa Unclassified       1     0         Mon Nov 4 10:20:10 2013
58:6d:8f:84:f2:2f Unclassified       1    2         Mon Nov 4 10:20:10 2013
58:6d:8f:84:f2:30 Pending           1     0         Mon Nov 4 10:21:28 2013
6c:3b:e5:01:fc:9c Unclassified       2     0         Mon Nov 4 10:17:04 2013
6c:3b:e5:ea:1b:f6 Unclassified       3     1         Mon Nov 4 10:19:11 2013
6c:f3:7f:25:b6:40 Unclassified       2     0         Mon Nov 4 10:23:04 2013
6c:f3:7f:25:b6:41 Unclassified       2     0         Mon Nov 4 10:23:04 2013
70:10:5c:f2:19:b2 Unclassified       2     0         Mon Nov 4 10:23:10 2013
70:10:5c:f2:19:b4 Unclassified       2     0         Mon Nov 4 10:23:10 2013
70:10:5c:f2:19:b5 Unclassified       3     0         Mon Nov 4 10:22:15 2013
70:10:5c:f2:19:b6 Unclassified       2     0         Mon Nov 4 10:22:15 2013
70:10:5c:f2:19:b7 Unclassified       3     0         Mon Nov 4 10:22:15 2013
70:10:5c:f2:19:b8 Unclassified       4     0         Mon Nov 4 10:23:10 2013
70:10:5c:f2:19:b9 Unclassified       2     0        Mon Nov 4 10:23:10 2013
70:10:5c:f2:19:ba Unclassified       3     0         Mon Nov 4 10:23:10 2013
70:10:5c:f2:19:bb Unclassified       2     0         Mon Nov 4 10:22:15 2013
70:10:5c:f2:19:bc Unclassified       1     0         Mon Nov 4 10:16:13 2013
70:10:5c:f2:19:bd Unclassified       2     0         Mon Nov 4 10:22:15 2013
70:10:5c:f2:19:be Unclassified       1     0         Mon Nov 4 10:19:14 2013
88:1f:a1:38:16:5c Unclassified       1     0         Mon Nov 4 10:05:04 2013
90:72:40:18:2b:a4 Unclassified       2     0         Mon Nov 4 10:14:09 2013
a0:21:b7:ac:85:db Unclassified       2     0         Mon Nov 4 10:23:10 2013
a0:21:b7:ac:85:dd Unclassified       1     0         Mon Nov 4 10:21:28 2013
a0:cf:5b:68:6d:c3  Unclassified       1     0         Mon Nov 4 10:20:55 2013
a0:cf:5b:68:6d:c4 Unclassified       1     0         Mon Nov 4 10:17:54 2013
a0:cf:5b:68:6d:c5 Unclassified       1     0         Mon Nov 4 10:20:55 2013
a0:cf:5b:68:6d:c8 Unclassified      1     0         Mon Nov 4 10:17:54 2013
a0:cf:5b:68:89:93 Unclassified       2     0         Mon Nov 4 10:22:51 2013
a0:cf:5b:68:89:94 Unclassified       2     1         Mon Nov 4 10:19:52 2013
a0:cf:5b:68:89:95 Unclassified       2     0        Mon Nov 4 10:22:51 2013
a0:cf:5b:68:89:98 Unclassified       1     0         Mon Nov 4 10:19:52 2013
a0:cf:5b:68:a5:03 Unclassified       1     0         Mon Nov 4 10:20:55 2013
a0:cf:5b:68:a5:04 Unclassified       1     0         Mon Nov 4 10:14:54 2013
a0:cf:5b:68:a5:05 Unclassified       1     0         Mon Nov 4 10:17:54 2013
a0:cf:5b:68:a5:08 Unclassified       1     0         Mon Nov 4 10:14:54 2013
a4:56:30:a2:bb:90 Unclassified       2     0         Mon Nov 4 10:22:21 2013
a4:56:30:a2:bb:91 Unclassified       2     0         Mon Nov 4 10:23:04 2013
a4:56:30:a2:d3:50 Unclassified       2     1         Mon Nov 4 10:22:21 2013
a4:56:30:a2:d3:51 Unclassified       2    0         Mon Nov 4 10:19:21 2013
c0:3f:0e:17:27:54 Unclassified       2     0         Mon Nov 4 10:14:04 2013
c0:c1:c0:12:69:b9 Unclassified       3     0         Mon Nov 4 10:20:55 2013
c0:c1:c0:12:69:ba Unclassified       3     0         Mon Nov 4 10:21:58 2013
c0:c1:c0:85:fd:16 Unclassified       1     0         Mon Nov 4 10:22:51 2013
c0:c1:c0:85:fd:17 Unclassified       1     0         Mon Nov 4 10:22:51 2013
d8:fe:e3:02:7b:50 Unclassified       1     0         Mon Nov 4 10:08:56 2013
e0:06:e6:31:64:07 Unclassified       3     0         Mon Nov 4 10:22:51 2013
f4:7f:35:74:11:e0 Unclassified       1     0         Mon Nov 4 10:20:57 2013
f4:7f:35:74:11:e1 Unclassified       1     0         Mon Nov 4 10:17:57 2013
f4:7f:35:74:11:e2 Unclassified       1     0         Mon Nov 4 10:20:57 2013
f4:7f:35:74:11:e3 Unclassified       1     0         Mon Nov 4 10:14:56 2013
f4:7f:35:74:11:ec Unclassified       1     0         Mon Nov 4 10:19:14 2013
f4:7f:35:74:11:ee Unclassified       1     0         Mon Nov 4 10:13:13 2013
f4:7f:35:74:11:ef Unclassified       1     0         Mon Nov 4 10:16:13 2013
f4:b7:e2:3c:81:bb Unclassified       2     0         Mon Nov 4 10:20:04 2013
f8:e4:fb:c2:44:e7 Unclassified       1    0         Mon Nov 4 10:22:21 2013
f8:e4:fb:c3:7c:69 Unclassified       2     0         Mon Nov 4 10:19:21 2013
Adhoc Rogue Configuration
Detect and report Ad-Hoc Networks................ Enabled
Auto-Contain Ad-Hoc Networks..................... Disabled
Client MAC Address Adhoc BSSID         State             # APs   Last Heard
00:15:99:ea:09:45   86:d1:92:ee:68:8c   Alert             1       Mon Nov 4 10:20:57 2013
00:20:00:32:19:a8   02:8d:69:90:0e:74   Alert             1       Mon Nov 4 10:14:54 2013
00:24:81:d3:78:59   da:ce:46:09:87:fe   Alert             2       Mon Nov 4 10:22:21 2013
00:80:92:94:26:16   d6:47:44:75:23:af   Alert             3       Mon Nov 4 10:22:51 2013
06:1e:58:fe:20:d7   06:1e:58:fe:20:d7   Alert             2       Mon Nov 4 10:07:22 2013
26:aa:4b:f9:7a:ab   26:aa:4b:f9:7a:ab   Alert             2       Mon Nov 4 10:20:04 2013
4e:f8:b3:6c:bc:fd   4e:f8:b3:6c:bc:fd   Alert             2       Mon Nov 4 10:10:22 2013
Rogue Client Configuration
Validate rogue clients against AAA............... Disabled
MAC Address        State             # APs Last Heard
00:19:7e:93:32:8b Alert             2     Mon Nov 4 10:22:51 2013
00:24:d7:f1:58:64 Alert             1     Mon Nov 4 10:08:56 2013
04:e5:36:05:fd:bc Alert             1     Mon Nov 4 10:05:08 2013
0c:ee:e6:d4:49:ae Alert             2     Mon Nov 4 10:16:21 2013
18:0c:ac:14:38:25 Alert             1     Mon Nov 4 10:10:22 2013
18:34:51:48:b5:ad Alert             1     Mon Nov 4 10:19:21 2013
18:3d:a2:62:98:98 Alert             1     Mon Nov 4 10:05:04 2013
1c:4b:d6:39:b0:e0 Alert             1     Mon Nov 4 10:08:56 2013
20:10:7a:32:cb:d1 Alert            1     Mon Nov 4 10:05:04 2013
20:10:7a:32:cb:ed Alert             2     Mon Nov 4 10:08:04 2013
5c:0a:5b:46:dc:19 Alert             2     Mon Nov 4 10:10:22 2013
68:a8:6d:74:2a:07 Alert             1     Mon Nov 4 10:20:04 2013
70:18:8b:9a:84:45 Alert             1     Mon Nov 4 10:20:10 2013
7c:d1:c3:6b:96:b4 Alert             2     Mon Nov 4 10:17:04 2013
90:18:7c:8c:51:87 Alert             1     Mon Nov 4 10:16:51 2013
90:b2:1f:0c:84:49 Alert             1     Mon Nov 4 10:05:04 2013
9c:4e:36:38:9c:4c Alert             2     Mon Nov 4 10:23:04 2013
b0:79:94:7e:42:1d Alert             1     Mon Nov 4 10:14:04 2013
b8:e8:56:0d:e5:94 Alert             1     Mon Nov 4 10:23:04 2013
bc:3b:af:3b:4f:9a Alert            1     Mon Nov 4 10:14:54 2013
c4:17:fe:ac:1c:1e Alert             1     Mon Nov 4 10:23:10 2013
c8:f7:33:8e:19:03 Alert             1     Mon Nov 4 10:19:11 2013
cc:3a:61:17:24:b2 Alert             1     Mon Nov 4 10:20:10 2013
e4:ce:8f:24:cf:8e Alert             1     Mon Nov 4 10:23:04 2013
Ignore List Configuration
MAC Address
Rogue Rule Configuration
Priority Rule Name               State   Type         Match Hit Count
Media-Stream Configuration
Multicast-direct State........................... disable
Allowed WLANs....................................
Stream Name   Start IP       End IP         Operation Status
URL..............................................
E-mail...........................................
Phone............................................
Note.............................................
State............................................ disable
2.4G Band Media-Stream Configuration
Multicast-direct................................. Enabled
Best Effort...................................... Disabled
--More-- or (q)uit
Video Re-Direct.................................. Enabled
Max Allowed Streams Per Radio.................... Auto
Max Allowed Streams Per Client................... Auto
Max Video Bandwidth.............................. 0
Max Voice Bandwidth.............................. 75
Max Media Bandwidth.............................. 85
Min PHY Rate..................................... 6000
Max Retry Percentage............................. 80
5G Band Media-Stream Configuration
--More-- or (q)uit
Number of Clients................................ 0
Client Mac         Stream Name  Stream Type Radio WLAN QoS   Status
(Cisco Controller) >
Stephen Rodriguez Tue, 11/05/2013 - 08:38
  • Purple, 4500 points or more
So is the issue with roaming between AP, or changing SSID?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Firas.alwan Tue, 11/05/2013 - 08:39
Changing the SSID .. Sorry if i miss addressed it..
thanks in advance.
Firas
Firas.alwan Wed, 11/06/2013 - 05:15
Is there anybuddy looking into this please ?
thanks,
Firas
Scott Fella Wed, 11/06/2013 - 05:23
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You shouldn't be roaming between different SSID's. Roaming occurs between AP's with the client on the same SSID. Clients that move from one ssid to a different ssid, isn't called roaming. As the client will drop and the client device will have to look for another SSID to associate to.
Firas.alwan Wed, 11/06/2013 - 05:28
OK, I see your point. thanks for the correction Scott.
So my problem occur when i disconect from one SSID and try to connect to other SSID .
Do you have any ideas how to fix that ?
thanks,Firas
Scott Fella Wed, 11/06/2013 - 05:34
  • Hall of Fame,
    2017 Wireless
As long as Fast SSID Change is enabled, you should have no issue. This allows devices to switch between SSID's without having to wait for the WLC to remove the client entry. It shouldn't matter what vlan the client is also being placed in as switching to a different ssid requires a full reauth.
Firas.alwan Wed, 11/06/2013 - 05:41
The Fast SSID  been Enabled since the begining.. plus, the problem only happning on the Remot site, i had no issue in the HQ office which is lead that the controller setting is fine . Am I right ?
thanks,
Firas
Scott Fella Wed, 11/06/2013 - 05:52
  • Hall of Fame,
    2017 Wireless
Well you need to understand the behavior of h-reap or what it's called now, FlexConnect. In this mode, the clients are still remembers on the WLC until the session timer/idle timer expires. So switching between SSID's in h-reap will not be the same when switching when the AP's are in local mode.
Take a look at the client when connected in FlexConnect in the WLC GUI monitor tab. Thus will show you what ssid and vlan the client is on. Now switch to a different ssid and compare this. It's probably the same because the client has not timed out. Now go back to the other ssid and look again. Now on the WLC, remove or delete the client and then switch to the other ssid at the same time. Or switch SSID's and then remove the client. The client will join the new ssid and in the monitor tab, you should see the info.
There is no need to have clients have multiple SSID's unless your testing. Devices should only have one ssid profile configured to eliminate any connectivity issues from the device wanting to switch SSID's.
Firas.alwan Wed, 11/06/2013 - 07:06
Scot,
Thanks For your Helpfull info.I did removed the unit from the clinets list and then connected to the other SSID but i end up with the same results : which is says connecting but not able to get an IP address from the New SSID.
here is the status of one of the client
So Basicly connectting but not getting IP . and same way Vise Versa.
Scott Fella Wed, 11/06/2013 - 07:18
  • Hall of Fame,
    2017 Wireless
Connect a laptop to a port on the switch for the same vlan the WLAN is associated to and see if you get an IP.
Firas.alwan Wed, 11/06/2013 - 07:53
Well, I have many other users connected to the other vlan throug the same port withand they can get IP.
the whole issue is whenevr a new clinet got connectd to any VLAN ( SSID ), he wont be able to go to the other VLAN ( SSID ) .
Trending Topics - Security & Network
