Anyconnect Licensing
Nov 5th, 2013
  • Bronze, 100 points or more
I have a remote access VPN via an ASA 5510. Clients are currently using the Cisco VPN Client which I believe is coming to an end or has...?
I've upgraded the ASA to most current IOS and also the ASDM as I want clients to use anyconnect.
I've done a lot of reading but still a bit confused regarding the licensing for Anyconnect. The clients I have connecting via the VPN Client, are they using an IPSEC license? I believe these come as standard out the box with the ASA?
Now if I want my remote clients to connect using Anyconnect client (IPSEC) - is this possible or is it all SSL licensing that is used now for remote access?
I'm not talking about site to site vpns, just interested in remote clients connecting in through anyconnect.
Marvin Rhoads Tue, 11/05/2013 - 16:07
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
For AnyConnect Secure Mobility Client, there are two basic license types - Essentials and Premium:
  • AnyConnect Essentials is licensed per ASA. You need a single license no matter how many remote access VPN clients connect (constrained only by the platform capabilities).
  • AnyConnect Premium is licensed in tiers of users. (10, 25, 50 etc.)
You pick one or the other - not both. Part numbers for both are as listed on the product data sheet, table 2, here. AnyConnect remote access VPN can use either SSL or IPsec (IKKEv2 only).
There is a Q&A here with an overview of this. Comparison of these two variants and some other options is here.
Karsten Iwen Tue, 11/05/2013 - 22:52
  • Purple, 4500 points or more
    2017 Firewalling, VPN
And it's important to mention that premium users are concurent logged-in users, regardless of the amount of installed clients.
But in the given scenario (where the old IPsec client should be replaced), it sounds like AnyConnect Essentials is the way to go.
