11-05-2013 09:28 AM - edited 03-17-2019 03:41 PM
Does anyone know if there is a way to disable the Windows Jabber client from writing it's syslog (csf-unified.log and csf-unified.log.1-10)
I work in an enviornment where we run VMware View and the user appdata directory is redirected back to a file server that is getting pegged by jabber logs. The top I/O offenders are these logs and it's affecting performance in a major way so I'm hoping to be able to disable these logs or perhaps redirect them to a different location.
On the client side we're using 9.1.5 and on the server side it's CUP 8.6.4.
The full directory path of the logs is C:\Users\%username%\appdata\local\cisco\unified communications\jabber\csf\logs
Any thoughts would be appreciated.
Solved! Go to Solution.
11-12-2013 03:22 AM
Starting from 9.2.x version, LOG_DIRECTORY argument is being defined for installer.
Take a look at
With LOG_DIRECTORY defined, you can redirect logs into custom directory, thus avoiding appdata directory.
Vladimir.
11-12-2013 03:22 AM
Take a look at
Vladimir.
11-13-2013 06:14 AM
We're running 9.1.5, but plan to upgrade within the next few months and I'm sure this will help. Thanks for the information!
