Interconnection Between Cisco Nexus 5k
Answered Question
Nov 5th, 2013
Hi everyone.
I have the next question, If i interconnect two arrangement of Cisco Nexus UCS 5k by an VPC between them, i will have problems with that connection, i will have some impact?; there is any problem with the Vpc domains between them?
Thank you.
Correct Answer by Reza Sharifi about 3 years 9 months ago
Ok, than that should not be an issue.  You connect all 4 5ks full meshed together and put them in one vPC.
I have done it between 5ks and 7ks, but it should work the same way when they are all 5ks.
Overall Rating: 5 (1 ratings)
Reza Sharifi Tue, 11/05/2013 - 18:18
  • Cisco Designated VIP,
    2017 LAN
Not sure exactly what is your question, but are refereeing to 2 sets of 5ks or one set?
jmp780718 Tue, 11/05/2013 - 18:31
Hi Reza.
Is correct i have 2 set of 5Ks and i need to connect between them thru VPC in order to extend vlans.
Thank you.
Correct Answer
Reza Sharifi Tue, 11/05/2013 - 18:52
    2017 LAN
