Warning message
Cisco FXO auto disconnected while talking
Answered Question
Nov 6th, 2013
I am configuring the CISCO2901/K9:
Cisco CISCO2901/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FGL1737248D
2 Gigabit Ethernet interfaces
1 terminal line
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
After I finish FXO configuration and make phone calls from SIP phone CP-3905 to PSTN through FXO ports. The problem is while 02 parties are talking about 2 to 3 minutes, and the call is disconnect suddenly.
Attached file is my running configuration. How can I fix this problem?
Tnks
Correct Answer by dsobrinho about 3 years 9 months ago
Hi guys,
Try configure the  with
Example:
voice-port 0/0/0
trunk-group LINE_FXO_outgoing  -> This is a trunkgroup for outgoing calls.
supervisory disconnect dualtone mid-call
cptone BR
timeouts call-disconnect 1
timeouts wait-release 3
connection plar 372428
description --[NUMBER-ANALOG-LINE]
Best regards,
Daniel Sobrinho
Overall Rating: 5 (7 ratings)
domanhtien Sun, 11/10/2013 - 17:49
Hi all,
I am a newbie in Cisco Voice, anyone have any ideas about this problem ??
Correct Answer
dsobrinho Tue, 11/19/2013 - 06:05
  • Red, 2250 points or more
Hi guys,
Example:
voice-port 0/0/0
cptone BR
Best regards,
Daniel Sobrinho
domanhtien Sun, 11/24/2013 - 18:00
Hi Sobrinho,
I configured base on your advice and it's fixed now.
Thank you.
Tiendm
Bruno rangel Sun, 11/24/2013 - 18:14
  • Green, 3000 points or more
  • Participante em Destaque,
    Prêmio 'Escolha da Audiência' fevereiro 2015
  • Events Top Contributors,
    External, 2014
Good approach Sobrinho!!!!! (+5 Stars)
@domanhtien
Please remember to rate helpful  responses and identify helpful or correct answers.
dsobrinho Mon, 11/25/2013 - 06:19
Hi Domanhtien,
I am very happy for everything is working now.
Thank you for your feedback.
Thank you Bruno for your feedback as well.
Best regards,
Daniel Sobrinho
Related Content
