switchport access
hugh.lancaster
Need some help or it may not matter, I have two controllers trunked. One to int 4/0/17 and worked fine I added the other controller to 4/0/17 and I am having issues.
fa 4/0/18 displays, "switchport access vlan5".
fa 4/0/17 does not.  Do I need to remove that and how?
interface FastEthernet4/0/17
description Wire_Control
switchport trunk allowed vlan 1,5
switchport mode trunk
storm-control broadcast level 10.00
macro description cisco-desktop | cisco-desktop
spanning-tree portfast
spanning-tree bpduguard enable
interface FastEthernet4/0/18
description Wireless Controller ip 10.100.0.49
switchport access vlan 5
switchport nonegotiate
macro description cisco-desktop | cisco-desktop | cisco-desktop
glen.grant
  No you don't have to remove it , because you have hardcoded the trunk , "switchport mode trunk" ,  the switchport access vlan 5 has no effect.
glen.grant
I'm thinking, that someone put that port into vlan 5, before they created the trunk. As Glen says, it's basically a dumb config right now, not really doing anything.
I'm assuming VLAN 5 is the wireless network vlan?
thanks
daniel.dib
Level 7
Level 7
It probably was an access port before it was a trunk. It should be in trunk mode, check the operational mode with show interface fa4/0/18 switchport.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
