Cisco AIR-LAP1252AG-A-K9 Factory Reset
Answered Question
Nov 6th, 2013
How do you do a factory reset from the console on a Cisco AIR-LAP1252AG-A-K9?
I have the password. Holding down the  mode button while the access point is booting does not seem to do the trick.
Correct Answer by Rasika Nayanajith about 3 years 9 months ago
It's looks like your AP is lwapp & try the below & see. Try the last two commands & see if that works. If not try with the first command as well.
AP0023.045e.df34#debug console cli
AP0023.045e.df34#delete flash:private-multiple-fs
AP0023.045e.df34#reload
Rasika
**** Pls rate all useful responses ****
Overall Rating: 5 (1 ratings)
Rasika Nayanajith Wed, 11/06/2013 - 18:47
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
If it has a autonomous image you can try "write default-config" on the AP priviledge mode CLI.
If it has a lightweight image you can try "erase /all nvram:" on the AP priviledge mode CLI.
Mode button option & GUI option is described in this doc
http://www.cisco.com/en/US/docs/wireless/access_point/1250/installation/guide/125h_c3.html
Rasika
djelizondo Fri, 11/08/2013 - 16:54
That is not working. Here is the ouput.
IOS Bootloader - Starting system.
Xmodem file system is available.
flashfs[0]: 3 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31868928
flashfs[0]: Bytes used: 2330624
flashfs[0]: Bytes available: 29538304
flashfs[0]: flashfs fsck took 14 seconds.
Reading cookie from flash parameter block...done.
Base Ethernet MAC address: 00:23:04:5e:df:34
Loading "flash:/c1250-rcvk9w8-mx/c1250-rcvk9w8-mx"...###########################
File "flash:/c1250-rcvk9w8-mx/c1250-rcvk9w8-mx" uncompressed and installed, entr
y point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1250 Software (C1250-RCVK9W8-M), Version 12.4(10b)JA1, RELE
ASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 30-Jan-08 12:11 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x003DD740
Initializing flashfs...
flashfs[1]: 3 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 31868928
flashfs[1]: Bytes used: 2330624
flashfs[1]: Bytes available: 29538304
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
cisco AIR-LAP1252AG-A-K9   (PowerPC 8349) processor (revision A0) with 49142K/16
384K bytes of memory.
Processor board ID FTX123590E6
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power-on
LWAPP image version 3.0.51.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:23:04:5E:DF:34
Part Number                          : 73-10425-05
PCA Assembly Number                  : 800-27630-05
PCA Revision Number                  : A0
PCB Serial Number                    : FOC12334VW4
Top Assembly Part Number             : 800-29536-02
Top Assembly Serial Number           : FTX123590E6
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1252AG-A-K9
o
% Invalid input detected at '^' marker.
Press RETURN to get started!
*Mar  1 00:00:06.975: %CDP_PD-4-POWER_OK: Full power - INJECTOR_DETECTED inline
power source
*Mar  1 00:00:06.979: %SYS-5-RESTART: System restarted --
ASE SOFTWARE (fc2)
*Mar  1 00:00:07.939: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state
to up
*Mar  1 00:00:08.939: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet0, changed state to up
*Mar  1 00:00:26.983: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar  1 00:00:27.131: Logging LWAPP message to 255.255.255.255.
%DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 10.0.7.
180, mask 255.255.255.0, hostname AP0023.045e.df34
Translating "CISCO-LWAPP-CONTROLLER.toltsg.com"...domain server (10.253.0.50)
%LWAPP-3-CLIENTEVENTLOG: Did not get vendor specific options from DHCP.
%LWAPP-3-CLIENTEVENTLOG: Did not get log server settings from DHCP.
%SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI init
iated
%LWAPP-3-CLIENTEVENTLOG: Performing DNS resolution for CISCO-LWAPP-CONTROLLER.to
ltsg.com
%LWAPP-3-CLIENTERRORLOG: DNS Name Lookup: could not resolve CISCO-LWAPP-CONTROLL
ER.toltsg.com
AP0023.045e.df34>en
Password:
AP0023.045e.df34#erase /all nvram
AP0023.045e.df34#write default-config
AP0023.045e.df34#
Correct Answer
Rasika Nayanajith Fri, 11/08/2013 - 23:08
    2017 Wireless
Rasika
rashmi814 Wed, 12/30/2015 - 20:17
All,
I have this problem. I have tried commands suggested by Rasika and also have tried MODE on AP. I am not able to factory reset configuration. I keep getting error message as below and am not able to configure AP.
*Mar 1 00:46:46.251: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar 1 00:46:46.283: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar 1 00:46:46.307: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
Not in Bound state.
*Mar 1 00:47:31.807: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar 1 00:47:34.815: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar 1 00:47:34.879: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.2.238, mask 255.255.255.0, hostname AP001e.f71a.ca2e
Related Content
