Warning message
Searching for OID equvalent for "show module"
Nov 7th, 2013
Hi all,
on my 6509 I can do an show module see output below.
What is the OID to get the same result specially the "Online Diag Status"?
Willem
rou0801#sh module
Mod Ports Card Type                              Model              Serial No.
  2    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      SAL1513A9FV
  4   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL09264M88
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL09285BUU
  6   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL09285D84
Mod MAC addresses                       Hw    Fw           Sw           Status
  2  c89c.1dc1.1374 to c89c.1dc1.1377   3.2   12.2(18r)S1  12.2(18)SXF1 Ok
  4  0014.6af3.dcdc to 0014.6af3.dcf3   2.2   12.2(14r)S5  12.2(18)SXF1 Ok
  5  0012.dae4.7df0 to 0012.dae4.7df3   4.4   8.1(3)       12.2(18)SXF1 Ok
  6  0014.f215.b268 to 0014.f215.b297   2.2   12.2(14r)S5  12.2(18)SXF1 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  2  Centralized Forwarding Card WS-F6700-CFC       SAL15119BAR  4.1    Ok
  4  Centralized Forwarding Card WS-F6700-CFC       SAL09285FFQ  2.0    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3B       SAL09274YM9  2.1    Ok
  5  MSFC3 Daughterboard         WS-SUP720          SAL09274U8K  2.3    Ok
  6  Centralized Forwarding Card WS-F6700-CFC       SAL09274T2C  2.0    Ok
Mod  Online Diag Status
  2  Pass
  4  Pass
  5  Pass
  6  Pass
rou0801#
Rolf Fischer Thu, 11/07/2013 - 03:12
  • Blue, 1500 points or more
you can query the inventory-data by the objects of the ENTITY-MIB, e.g. entPhysicalDescr, entPhysicalSerialNum, etc.
For Information about the Diagnostic Status you can query the CISCO-ENTITY-DIAG-MIB, e.g. the object  ceDiagTestPerfLastResult; this one will provide very similar information like a "show diagnostic result module ".
Rolf
Willem de Groot Thu, 11/07/2013 - 04:31
Hi Rolf,
Thanks.
In ENTITY-MIB I don't find the Status.
My 6509 does not answer to CISCO-ENTITY-DIAG-MIB tree at all
The only partly usable result coes from:
1.3.6.1.4.1.9.3.6.11.1.9
Description:
The operational status of the card. cardOperStatus is up when a card is recognized by the device and is enabled for operation. cardOperStatus is down if the card is not recognized by the device, or if it is not enabled for operation. cardOperStatus is standby if the card is enabled and acting as a standby slave
Enumerations:
1  -  not-specified
2  -  up
3  -  down
4  -  standby Description:
I hoped that Online Diag Status shows a bit more information.
