VDSL 0 is up but no internet traffic
Nov 7th, 2013
hi can anyone help?
i have a cisco 887VA router which lost connection to the WAN and I cant figure out why
the Controller VDSL 0 is up
the ATM0 Int is up
the sub int ATM0.1 is down
and  i am unable to ping 8.8.8.8 from wan interface or lan interface
here is some interface outputs:
sh controller vdsl 0
Controller VDSL 0 is UP
Daemon Status:           Up
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'IFTN'
Chip Vendor Specific:   0x0000                   0x827A
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   '    '
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0x0000
Serial Number Near:    FCZ173691XR 887VA-S 15.3(1)T
Serial Number Far:     2301230123012301230123012301230
Modem Version Near:    15.3(1)T
Modem Version Far:     0x827a
Modem Status:            TC Sync (Showtime!)
DSL Config Mode:         AUTO
Trained Mode:            G.992.5 (ADSL2+) Annex A
TC Mode:                 ATM
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Trellis:                 ON                       ON
SRA:                     disabled                        disabled
SRA count:              0                       0
Bit swap:                enabled                         enabled
Bit swap count:         9573                    0
Line Attenuation:        33.0 dB                 19.1 dB
Signal Attenuation:      38.9 dB                 19.4 dB
Noise Margin:             3.1 dB                  6.0 dB
Attainable Rate:        17452 kbits/s            1076 kbits/s
Actual Power:             0.0 dBm                12.6 dBm
Total FECC:             311947                   0
Total ES:               294                      0
Total SES:              27                       0
Total LOSS:             0                        0
Total UAS:              57                       57
Total LPRS:             0                        0
Total LOFS:             0                        0
Total LOLS:             0                        0
Full inits:             1
Failed full inits:      1
Short inits:            1
Failed short inits:     0
Firmware        Source          File Name (version)
VDSL            embedded        VDSL_LINUX_DEV_01212008 (1)
Modem FW  Version:      120306_1254-4.02L.03.A2pv6C035j.d23j
Modem PHY Version:      A2pv6C035j.d23j
Vendor Version:         Ap6v35j.23j 68
                  DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             0            15199             0              1076
SRA Previous Speed:       0                0             0                 0
Total Cells:              0       1045761926             0          73867432
User Cells:               0             9862             0              2948
Reed-Solomon EC:          0           311947             0                 0
CRC Errors:               0             1506             0                 0
Header Errors:            0            10070             0                 0
Interleave (ms):       0.00             7.96          0.00              0.34
Actual INP:            0.00             1.00          0.00              0.00
sh run
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
zone-member security out-zone
logging event subif-link-status
crypto map ADAPTVPN
pvc 0/38
  oam-pvc manage
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description $FW_INSIDE$
ip address MYLOCALIPANDSUBNET
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat inside
no ip virtual-reassembly in
zone-member security in-zone
interface Dialer0
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 2
ppp authentication chap pap callin
ppp chap hostname
MYISPHOSTNAME
ppp chap password 7 MYISPPASSWORD
ppp pap sent-username
MYISPHOSTNAME
no cdp enable
JMaartenW Thu, 11/07/2013 - 07:37
HSTCIS887DATA1#show ip int brie
Interface                       IP-Address      OK?      Method      Status                 Protocol
ATM0                            unassigned      YES      NVRAM      up                                 up
ATM0.1                         unassigned      YES      manual       down                            down
Dialer0                          unassigned      YES      IPCP           up                                 up
Ethernet0                      unassigned      YES      NVRAM      down                            down
FastEthernet0              unassigned      YES      unset           down                            down
FastEthernet1              unassigned      YES      unset           up                                 up
FastEthernet2              unassigned      YES      unset           down                            down
FastEthernet3              unassigned      YES      unset           down                            down
NVI0                             unassigned      YES      unset           administratively down down
Virtual-Access1           unassigned      YES      unset           up                                 up
Virtual-Access2           unassigned      YES      unset           down                            down
Vlan1                           172.24.105.254  YES    NVRAM      up                                 up
James Neilson Thu, 11/07/2013 - 07:42
Thjis would indicate no sync on the line, the VDSL will retain the stats from the last time it was synched unless rebooted. Try a reload of the router or the shut/no shut on the atm interface.
The noise margin is low, you shoukld be aiming for 10dB but 6dB is acceptable, if there is still no sync after a reload I would log a call with your ISP
JMaartenW Thu, 11/07/2013 - 07:48
thanks james
does that mean there is too much noise on the line? which figure is the important one 3.1db or 6.0db as it lists 2 in the noise margin?
thanks
James Neilson Thu, 11/07/2013 - 07:54
The 3.1 is the most important one as that is downstream. Noise margin is also know as SNR or signal to noise margin, so the lower the number either the more noise there is or the signal strength has degraded too much. With attenuation of 33dB it could be either cause.
The supplier will need to look at putting interleaving on the circuit. The rule of thumb is the lower the attenuation the better and the higher the noise margin the better. Attenuation is mainly to do with copper line quality and the length of the line from the property to the DSLAM.
Related Content
