Warning message
maximum number of ssid for 1600 ap
Answered Question
Nov 8th, 2013
Dear support,
kindly advise what the maximum number of SSID supported on aironet 1602
best regards
Correct Answer by Sandeep Choudhary about 3 years 9 months ago
Hi Saade,
MAX WLAN or the SSID that u can go on a AP is 16.
Depending on the firmware, typically a WLC can support up to 16 SSID.
Reagrds
Overall Rating: 5 (1 ratings)
Correct Answer
Sandeep Choudhary Fri, 11/08/2013 - 02:38
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Hi Saade,
Reagrds
Sandeep Choudhary Fri, 11/08/2013 - 05:37
    2017 Wireless
If you are satisfied with the answer then can u plz mark as answered and also plz rate the post.
Leo Laohoo Fri, 11/08/2013 - 16:54
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Doesn't make any difference.  If you enable 16 SSID per AP then your channel get over-utilized, which is not good.
Consider shrinking your SSID to 4 and below.
