How enable frequency 5 ghz in the WLC 5508 release 6.0?
Nov 8th, 2013
Hi friends,
I have the WLC 5508 release 6.0 and AP clients LAP1142, and is enabled frequency 2.4 ghz only.
How I could enable frequency 5 ghz in the WLC?
Best Regards,
Ale
Overall Rating: 4.3 (6 ratings)
Stephen Rodriguez Fri, 11/08/2013 - 11:18
  • Purple, 4500 points or more
5Ghz is going to be enabled under  Wireless > 802.11a/n > Network.  There is a checkbox there to enable/disable the network
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Alexandre Venan... Fri, 11/08/2013 - 11:51
Steve,
This checkbox was marked and even so the clients don't find the frequency 5 ghz.
It's necessary enable this frequency in the LAP?
Alexandre
Leo Laohoo Fri, 11/08/2013 - 16:27
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hmmmmm ... what country is the AP and the client located.  Maybe it's part of the Regulatory Domain.  In some countries, 802.11a is not allowed so the WLC will not be able to enable 802.11a/n.
Next, what is the exact model of the wireless client.  Maybe the wireless client (like early iPhone and iPad) is only 802.11b/g.
Alexandre Venan... Mon, 11/11/2013 - 02:09
Leo Laohoo,
The Regulatory Domain is:
Configured Country Code (s): US
Regulatory Domain: 802.11a:     -A
                                 802.11bg:   -A
I'm in Brazil, and when I try change Country Code, don't allow apply the configuration, and return to Country Code US.
Alexandre.
Leo Laohoo Mon, 11/11/2013 - 13:57
  • Hall of Fame,
    2017 LAN, Wireless
Ok, just as I suspected.
802.11a/n is most likely disabled because you have two different regulatory domain.  Your WLC is configured for the US (-A) but your APs are in Brazil (-T, -Z, -N).
If you enable Brazil and disable US, do you see both radios go up?
Leo Laohoo Tue, 11/12/2013 - 02:32
  • Hall of Fame,
    2017 LAN, Wireless
Post the output to the WLC command "sh sysinfo".
Alexandre Venan... Tue, 11/12/2013 - 03:31
Output "sh sysinfo":
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 6.0.199.4
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... Cisco_Controller_SP
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... 10.1.6.100
Last Reset....................................... Software reset
System Up Time................................... 1 days 17 hrs 57 mins 54 secs
System Timezone Location.........................
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +39 C
External Temperature............................. +19 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 4
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 129
Burned-in MAC Address............................ 28:94:0F:AD:ED:C0
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 50
Alexandre.
Scott Fella Tue, 11/12/2013 - 03:55
  • Hall of Fame,
    2017 Wireless
You are only allowing one country code... US:
You would need to add the other country code.  The others have posted how to do that piece.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
Leo Laohoo Tue, 11/12/2013 - 13:35
  • Hall of Fame,
    2017 LAN, Wireless
No you didn't.  It is still set to the US.
Try again.
Scott Fella Mon, 11/11/2013 - 06:11
  • Hall of Fame,
    2017 Wireless
If the AP is located in the US then you can enable the US country code. If the AP is located or going to be used in Brazil, then you might be getting into trouble. AP's are made for a specific country. See this list
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps5861/produc...
Using an access point for another carry can be breaking the law. Here is the USA, FCC regulates what channel and power leveled we can use.
The reason the 5ghz is not working is because the WLC has to have the country code enabled for the country code for the access point. Also, the most common channels and power levels are used. So if a country code that is configured in the WLC doesn't allow 5ghz, then all AP's even ones that are for other countries, the 5ghz will be disabled.
Alexandre Venan... Mon, 11/11/2013 - 08:55
Scott Fella,
How I can see in the LAP if it is Regulatory domain equal to WLC?
Alexandre.
Scott Fella Mon, 11/11/2013 - 09:01
  • Hall of Fame,
    2017 Wireless
Add the Country Code to the WLC.
Scott
Scott Fella Mon, 11/11/2013 - 09:18
  • Hall of Fame,
    2017 Wireless
You can't add it to the AP, only the WLC.
Scott
Alexandre Venan... Mon, 11/11/2013 - 09:49
I note that in the configuration from LAP, the interface Dot11Radio1 is in shutdown.
Did I can add the command "no shutdown" for do the interface to be UP?
But I don't able to add the command in the LAP; How do it?
Alexandre.
Sandeep Choudhary Mon, 11/11/2013 - 09:18
    2017 Wireless
To change the country code, from the GUI of the WLC, go to Wireless ->Country and select or add your country.
Scott Fella Tue, 11/12/2013 - 03:04
  • Hall of Fame,
    2017 Wireless
Post some screen shots also so we can see exactly what you are referring to.
Alexandre Venan... Mon, 11/25/2013 - 02:22
I'm sorry the late, but I will able to change the country code only this week.
I'll informer the results coming soon.
Best regards.
Alexandre Venan... Wed, 11/27/2013 - 15:56
I tryed change the Country Code for BR, but don't was applied, it come back for Country Code US.
What I could do for change Country Code e enable 802.11a?
In the APs appear 802.11a/n:
Admin status-> enable
Oper status-> Down
Regualtory domain-> Not supported
