ASA 5505 - adding an Access Point
Nov 10th, 2013
I have just bought an ASA 5505 for my home.  Currently I have just a WiFi router from the ISP (Virgin Broadband Fibre), but I aim to put this into modem mode and put onto the outside of the ASA.
Once I have done that I need to enable WiFi again, but I will need an access point of some sort I guess, can anyone recommend one and can the PoE ports be used for this?
I may use a VOIP phone in the other PoE port.
Karsten Iwen Sun, 11/10/2013 - 13:11
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
The Cisco SMB-APs can use PoE. There are different models with 2.4 GHz, 5GHz, or even both. As the 5505 only has FE-ports, the 300 or even 500 models could be a little bit overkill. But the WAP561 is a quite good model with simultaneous 802.11abgn that still fits when you decide to attach the AP to dedicated switch at a later time.
