Supervisor Desktop Not Showing Correct Skill Group (UCCX 9.0.2)
Answered Question
Nov 10th, 2013
While viewing active calls in the Cisco Supervisor Desktop, the "Agents - Team State" area is not displaying the correct Skill Group. No matter what level a particular agent is set to within the group, it always shows a Skill Group of "5" while the agent is talking. Is this normal?
Jason
Correct Answer by Ravi Shankar Pandit about 3 years 9 months ago
Hi Jason,
I recreated in Lab and i am getting skill group 1. I think its ID of spefic skill not the actual skill of agent .
you can have any 5/6/7 skill set of agents but skill ID will be same .
Ravi
Overall Rating: 5 (1 ratings)
Ravi Shankar Pandit Mon, 11/11/2013 - 04:59
  • Cisco Employee,
Hi Jason,
Can you please attach the screen shot? So that we can understand the problem better .
Ravi
jasonfnb2007 Mon, 11/11/2013 - 13:59
Sure. I have attached the following to the original post:
agentstate.jpg: Shows the Agent State view while the agents are talking, both show "5".
djsettings.jpg - Settings for one of the agents, showing a skill setting of "6".
dgsettings.jpg - Settings for the other agent, showing a skill setting of "7".
Jason
Correct Answer
Ravi Shankar Pandit Tue, 11/12/2013 - 03:06
  • Cisco Employee,
Hi Jason,
Ravi
