11-12-2013 03:00 PM - edited 03-18-2019 02:07 AM
HI,
One of the options for installing TMSXE 3.1.2 is in non AD Mode
Installing with Non-AD mode
To be able to run Cisco TMSXE in Non-Active Directory mode, launch the Cisco TMSXE installer with the
following command line switch :
-NONADCONNECTIONMODE
I can not seem to get this commandline switch to be accepted. Does someone have an example of the correct syntax?
thx,
rf
11-12-2013 05:57 PM
Additional info
Appendix 1
anybody have success using this commandline switch?
11-13-2013 06:49 AM
worked with TAC to get this figured out. The correct syntax is
msiexec /i TMSXESetup.msi NONADCONNECTIONMODE=1
A documentation defect has been opened with ID: CSCul18387
Hopefully that will help someone in the future.
07-22-2014 04:52 AM
is there anyway to revert back to AD mode after installation?
thx
07-23-2014 11:18 AM
Not without loss of data. If you really want to do this, please open a service request with TAC to get dedicated support in assessing your particular deployment.
A word of advice for others who are considering installing TMSXE in non-AD Mode: This option was introduced to support a couple of customers who had very specific requirements. 99.5% of customers do not have Exchange deployments where these conditions apply. Don't install TMSXE in non-AD Mode unless you have discussed it with your Cisco account team and agreed that this is right for you.
Kjetil
