Warning message
what is the command that shows that port-fast is enabled on certain ports.
Nov 13th, 2013
How to see whether port-fast is enabled on a port or not ?
Here port fast is disabled globally.
switch0#sh span sum
Switch is in pvst mode
Root bridge for:
Extended system ID           is enabled
Portfast Default             is disabled
O/p of show spanning tree:
switch0#show spanning-tree
VLAN0001
  Spanning tree enabled protocol ieee
  Root ID    Priority    1
             Address     00D0.5865.B7E7
             Cost        19
             Port        1(FastEthernet0/1)
             Hello Time  2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    28673  (priority 28672 sys-id-ext 1)
             Address     000A.F3D2.55D2
             Aging Time  20
Interface        Role Sts Cost      Prio.Nbr Type
Fa0/1            Root FWD 19        128.1    P2p
Fa0/2            Altn BLK 19        128.2    P2p
Now i enable port-fast on Fa0/2. (Just doing trial and Error to understand things a better)
switch0(config)#interface fastEthernet 0/2
switch0(config-if)#spanning-tree portfast
%Warning: portfast should only be enabled on ports connected to a single
host. Connecting hubs, concentrators, switches, bridges, etc... to this
interface  when portfast is enabled, can cause temporary bridging loops.
Use with CAUTION
%Portfast has been configured on FastEthernet0/2 but will only
have effect when the interface is in a non-trunking mode.
switch0(config-if)#switchport mode access
switch0(config-if)#end
Now, where what is the command that shows that port-fast is enabled on certain ports.
REgards,
Chandu
Abzal Sembay Wed, 11/13/2013 - 01:52
  • Silver, 250 points or more
try this one:
#sh spanning-tree detail | inc FastEthernet|portfast
Hope it will help.
Best regards,
Abzal
chandra_rc16 Wed, 11/13/2013 - 03:56
Got it. Since the port-fast enabled ports doesn't participate in STP. There is no Fa0/1 port in o/p of sh span tree detail.
switch0#show spanning-tree detail
VLAN0001 is executing the ieee compatible Spanning Tree Protocol
  Bridge Identifier has priority of 0, sysid 1, 000A.F3D2.55D2
  Configured hello time 2, max age 20, forward delay 15
  Current root has priority 1
  Topology change flag not set, detected flag not set
  Number of topology changes 0 last change occurred 00:00:00 ago
            from FastEthernet0/1
  Times:  hold 1, topology change 35, notification 2
          hello 2, max age 20, forward delay 15
  Timers: hello 0, topology change 0, notification 0, aging 300
Port 2 (FastEthernet0/2) of VLAN0001 is designated forwarding
  Port path cost 19, Port priority 112, Port Identifier 112.2
  Designated bridge has priority 1, address 000A.F3D2.55D2
  Designated port id is 112.2, designated path cost 19
  Timers: message age 16, forward delay 0, hold 0
  Number of transitions to forwarding state: 1
  Link type is point-to-point by default
Chandu
