Warning message
Dial peer for variable length numbers in Germany and Interdigit Timeout (CME)
Answered Question
Nov 13th, 2013
I'm using CME 8.6 with a VIC2-2BRI on an ISDN BRI line. Because of the variable length numbers in Germany a use .T as my destination pattern in the ISDN dial peer. If a dial a number, it takes 10 seconds before the call gets placed. If I dial # at the end of the number, the calls gets placed immediately. I understand that this behaviour is controlled by the interdigit timer? I set it to 2 seconds under my voice port, but it still takes 10 seconds for the router to dial.
interface BRI0/0/0
description CONNECTION_TO_NTBA
no ip address
isdn switch-type basic-net3
isdn overlap-receiving T302 3000
isdn point-to-point-setup
isdn incoming-voice voice
voice-port 0/0/0
translation-profile incoming ADD_LEADING_ZERO_INCOMING_ISDN
compand-type a-law
no comfort-noise
cptone DE
timeouts interdigit 2
description ISDN_SPEECH
bearer-cap Speech
dial-peer voice 10 pots
description INCOMING_AND_OUTGOING_ISDN_CALLS
translation-profile incoming INCOMING_ISDN_CALLS
translation-profile outgoing OUTGOING_ISDN_CALLS
incoming called-number 800XX[YZ]
destination-pattern .T
no digit-strip
port 0/0/0
no sip-register
Correct Answer by Amine Nouasri about 3 years 9 months ago
then set the timer manually. Uner Telephony-service
timeouts interdigit x (value in seconds)
Please rate helpful answers!
Overall Rating: 5 (1 ratings)
Amine Nouasri Wed, 11/13/2013 - 11:09
  • Bronze, 100 points or more
Do you have any timer set under telephony-service? Please post your running-config here.
Correct Answer
Amine Nouasri Wed, 11/13/2013 - 11:45
johannesmoos Wed, 11/13/2013 - 11:56
Thanks, I guess I just set the timer in the wrong place.
Now I set it under 'telephone-service' for SCCP and under 'voice-register-global' for SIP. Works as expected.
Carlo Poggiarelli Wed, 11/13/2013 - 11:51
  • Green, 3000 points or more
Hi.
Can you please collect debug vpm all and debug isdn q931 while dialing out without pressing #
Carlo
johannesmoos Wed, 11/13/2013 - 12:08
Of course:
000451: Nov 13 2013 21:06:14.277 CET: ISDN BR0/0/0 Q931: RX <- FACILITY pd = 8  callref = N/A
    Facility i = 0x91A10F02024275060604008267010A020101
        Protocol Profile = Remote Operations Protocol
        0xA10F02024275060604008267010A020101
        Component = Invoke component
             3PTY Request
    Called Party Number i = 0xA1, '2774XXXXXX'
        Plan:ISDN, Type:National
000452: Nov 13 2013 21:06:15.517 CET: ISDN BR0/0/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 02774XXXXXX
000453: Nov 13 2013 21:06:15.517 CET: ISDN BR0/0/0 Q931: Sending SETUP  callref = 0x0018 callID = 0x801E switch = basic-net3 interface = User
000454: Nov 13 2013 21:06:15.521 CET: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8  callref = 0x18
    Bearer Capability i = 0x8090A3
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0x81
        Preferred, B1
    Calling Party Number i = 0x0080, '02774XXXXXX'
        Plan:Unknown, Type:Unknown
    Called Party Number i = 0x80, '02774XXXXXX'
000455: Nov 13 2013 21:06:15.761 CET: ISDN BR0/0/0 Q931: RX <- SETUP_ACK pd = 8  callref = 0x98
    Channel ID i = 0x89
        Exclusive, B1
000456: Nov 13 2013 21:06:16.093 CET: ISDN BR0/0/0 Q931: RX <- ALERTING pd = 8  callref = 0x98
    Facility i = 0x91A10F0202447F0606040082670101020101
        0xA10F0202447F0606040082670101020101
             3PTY Request
    Progress Ind i = 0x8288 - In-band info or appropriate now available
    Display i = 'CCNR moeglich'
000457: Nov 13 2013 21:06:16.101 CET: mars_flex_dsprm_current_codec_comp:DSP:0 FLEX Complexity Codec
000458: Nov 13 2013 21:06:16.105 CET: flex_dsprm_forking_mixing_support:
000459: Nov 13 2013 21:06:16.109 CET: mars_flex_dsprm_current_codec_comp:DSP:0 FLEX Complexity Codec
000460: Nov 13 2013 21:06:22.412 CET: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x18
    Cause i = 0x8090 - Normal call clearing
000461: Nov 13 2013 21:06:22.492 CET: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8  callref = 0x01
000462: Nov 13 2013 21:06:22.516 CET: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8  callref = 0x98
000463: Nov 13 2013 21:06:22.520 CET: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x18
000464: Nov 13 2013 21:06:22.524 CET: flex_dsprm_close_cleanup
