Warning message
FQDN
Answered Question
Nov 13th, 2013
I haven't used a proxy server. I have used nat for Internet traffic. The internet traffic passes through asa 5520. I want to log the full address of the Internet page visited by Internet client, how is this possible ?
Mero
Correct Answer by rfalconer.sffcu about 3 years 9 months ago
At the code level you're at, I don't think there is any option for logging URLs. You'll have to get some kind of service that performs web filtering. That will generate reports of where people are visiting.
Some of the SaaS offerings for this are very good and reasonably priced.
Overall Rating: 4 (2 ratings)
rfalconer.sffcu Wed, 11/13/2013 - 16:56
  • Bronze, 100 points or more
What version are you running? If you are on later than 8.2(3),  If you put 'inspect http' in your policy map, it should resolve the URL.
Mero Cisco Sun, 11/17/2013 - 01:50
Dear Falconer,
Thanks for your kind support. I have got the following version.
Cisco Adaptive Security Appliance Software Version 7.2(4)
What to do now ? My traffic passes through 1841,  3925 and 2800 series router, can I log through this routers.
Mero
rfalconer.sffcu Sun, 11/17/2013 - 10:10
As far as I know, you can't log through any of the other routers.
Have you considered an upgrade to the ASA? That code must be over 4 years old.
Mero Cisco Sun, 11/17/2013 - 20:51
Dear Falconer,
Currently I have got only one of this hardware, so, can't take risk, if something goes wrong, I don't have got any other option. What features have it got else this one?
Mero
Correct Answer
rfalconer.sffcu Mon, 11/18/2013 - 07:58
