Dialling from 7960 - speed dial works, manual dial fails
tony.ratcliffe
Hi, i've got an issue on a dialling a particular number from 7960 phones. When i dial a speed dial setup with the number 9121000 i hit the correct route pattern and the the 9 is stripped and an external call is placed to 121000 through my gateway.
if i dial 9121000 manually the call fails, and the 7960 display looks like its attempting to the 4 digit internal number 1210
I can't work out why this would work differently through speed dial and manual dial - any ideas?
thanks in advance for any hints
Chris Deren
This is because you have overlapping pattern i.e. TP or RP, DN extension, etc with urgent priority set on it.  Locate it and disable urgent priority.
HTH,
Chris
Chris Deren
HTH,
Chris
Thanks for the quick reply Chris, thats fixed the problem.
Chris Deren
Great, please mark ideation as answered.
