Warning message
Ethernet bridging over mesh network
Answered Question
Nov 14th, 2013
I'm trying to extend my wired connection over wireless mesh network. There are multiple vlans in the network. Management is vlan 333. Vlans 17 and 50 are used for Voice and Data.
Access points are online.
1. I have unchecked VLAN transparency in the global mesh configuration
2. I have enabled Ethernet Bridging for all APs
3. I configured switchports as a trunk with native vlan 333 in both ends of the LAN (connected to the RAP and MAP)
4. I configured RAP's and MAP's ports as a trunk with native vlan 333 and added vlans 17 and 50
5. I connected a switch to the mesh AP.
Tagged vlans 17 and 50 will work fine, but I can't access the switch in vlan 333. Is there something that I'm missing?
---[switch in vlan 333]----[RAP] ~~~~~~~~[MAP]----[switch in vlan 333]--[client in vlan 17/50]
WLC4404 and code is 7.0.240.3. APs are AIR-LAP1522.
Correct Answer by Scott Fella about 3 years 9 months ago
Take a look at this link
https://supportforums.cisco.com/servlet/JiveServlet/downloadBody/22077-1...
Overall Rating: 5 (1 ratings)
Scott Fella Thu, 11/14/2013 - 06:16
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Can the switch ping the gateway?
PetriSignal Thu, 11/14/2013 - 22:18
I don't have any IT guys onsite until Monday. I'll ask them to test.
I can't ping the device from the controller or from the other switch, so I guess the vlan 333 is not working at all.
Would it be an option to make up some vlan id just for the native vlan use and then add vlan 333 as tagged?
Scott Fella Thu, 11/14/2013 - 23:54
  • Hall of Fame,
    2017 Wireless
With Ethernet bridging, the native vlan gets tunneled back to the WLC and is also the vlan the the RAP is assigned to. So if the RAP is on a trunk port with native vlan 333, then the switch on the other end also should be on native vlan 333.
PetriSignal Thu, 11/14/2013 - 23:58
Both switchports have the same config. Native vlan is set to 333.
Correct Answer
Scott Fella Fri, 11/15/2013 - 00:14
  • Hall of Fame,
    2017 Wireless
PetriSignal Fri, 11/15/2013 - 03:59
Thank you for your help. Your document pretty much explains it all.
vlad.mihailov Thu, 11/14/2013 - 07:47
I think VLAN333 in this case will not be passed at the other side of the wireless bridge. I never fully investigated why but I have seen this issue before.
Related Content
