How to configure WPA2 on Cisco AP 1220?
Good day,
I wonder if my CISCO AP 1220 with IOS Version 12.2 (8) JA, can be configured with WPA2. What should I do to make it?
thanks
6 Replies 6
Scott Fella
That code doesn't support WPAv2 and I believe the hardware itself also doesn't support WPAv2.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Sandeep Choudhary
Hi Javier,
WPA is not supported on your IOS Version 12.2 (8) JA.
You must upgrade the IOS image to atleast 12.2(11)JA to support WPA feature.
To check more, please visit : http://tools.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
After updation u can configure wpa like this:
ap1200# configure terminal
ap1200(config)# interface dot11radio 0
ap1200(config-if)# encryption mode cipher tkip
ap1200(config-if)# ssid xyz
ap1200(config-ssid)# authentication open
ap1200(config-ssid)# authentication key-management wpa
Hope it helps.
Reagrds
I need configure WPA2. I know WPA is supported to cisco AP 1220.
thanks
Hi Javier,
if you need to configure wpa2 on 1220AP.
Then u must have
• Cisco IOS Software Release 12.3(8)JA or later (autonomous).
• Cisco IOS Software Release 12.3(11)JX or later (Lightweight Mode).
AP> enable
AP# configure terminal
AP (config)# interface dot11radio 0
AP(config-if)# ssid Admin
AP (config-if-ssid)# vlan 30
AP(config-if-ssid)# authentication open
AP(config-if-ssid)# authentication key-management wpa version 2
AP(config-if-ssid)# wpa-psk ascii your-key-here
Hope it helps.
Please rate helpful posts and marked as answered if u are satified with answer.
