Warning message
Directed call park not reverting, calls disconnecting
Nov 14th, 2013
We're running v7.1.5 cucm and I've set up a few directed call park BLF's.  Functionally, they work great.  However, when the reversion timer hits the calls are dropped rather than reverting.  Regular Call Park is reverting correctly.
Any ideas?
Rob Huffman Thu, 11/14/2013 - 10:19
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Nicholas,
Have you checked the park reversion CSS for the park
numbers in question?
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Nicholas Johnson Thu, 11/14/2013 - 13:55
Yes, and the CSS is correct.  However, even with an incorrect CSS I would expect a re-order tone of some sort.  Presently the calls are just dropped after the timer expires.
Nicholas Johnson Tue, 11/19/2013 - 06:19
This function began working when I removed the "Reversion Number" from the Directed Call Park Configuration.
I believe that is where you would you put in the number to which you would like the parked call to ring to once the timer expires, but that doesn't seem to work.  Once I removed that field the calls rang back to the extension from which they were parked.
