11-14-2013 09:34 PM - edited 07-04-2021 01:16 AM
I am unclear on the documentation. Can Cisco Prime auto shutdown switch ports that have rogue access points connected to it? The auto switchport trace feature doesn't seem to be shutting down the port on the switch. I need to know if there is a way to automate the port shutdown.
Attached is a document with my current configuration.
11-14-2013 10:12 PM
Not sure but you can configure the WLC to auto-contain a rogue-on-a-wire.
11-20-2013 12:39 AM
you can disable the switch ports, ( Wired Rogue Access Point Switch Ports). Please refer to the switch port tracing and "switch port tracing details" from the below document.
For "Rogue containment " by controller, as what said by Leo, refer to
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080b40901.shtml
05-25-2017 07:55 PM
Today I had a chance to test this feature, I dont see any options to automatically disable ports that found by SPT. I think administrator need to manually disable the ports. Please correct me if I am wrong.
04-27-2018 12:01 AM
