Router reloaded due to an unknown failure, PC 0x60B38674
Nov 15th, 2013
Hi Team,
One of our production router got reload and we are getting the unknown failure message in the version
Model: Cisco 3845
Please help to sort out the issue.
Arun
acampbell Fri, 11/15/2013 - 04:44
  • Green, 3000 points or more
Arun,
PC Bus errors ussually reflect that the router had issues accessing a certain memory location.
The memery locations can be found by issuing
show region
However this is 99% an IOS code bug.
Raise a TAC or try upgrading your IOS.
Alex.
Please rate useful posts.
arun karthick Fri, 11/15/2013 - 05:22
------------------ show region ------------------
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x0FFFFE00  0x0FFFFFFF         512  Iomem  R/W    BCM region
0x2D900000  0x2FFFFDFF    40893952  Iomem  R/W    iomem
0x60000000  0x6D8FFFFF   227540992  Local  R/W    main
0x6001105C  0x6244BCAF    37989460  IText  R/O    main:text
0x6244C000  0x6451E2BF    34415296  IData  R/W    main:data
0x6451E2C0  0x6498DFBF     4652288  IBss   R/W    main:bss
0x6498DFC0  0x6D8FFFFF   150413376  Local  R/W    main:heap
0x70000000  0x7FFFFFFB   268435452  Local  R/W    Main memory 1
0x7FFFFFFC  0x7FFFFFFF           4  Local  R/W    Protected region
0x80000000  0x8D8FFFFF   227540992  Local  R/W    main:(main_k0)
0xA0000000  0xAD8FFFFF   227540992  Local  R/W    main:(main_k1)
This is the show region found in the router.
acampbell Fri, 11/15/2013 - 05:29
Arun,
Your PC error bolngs in this group of memory locations
I suggest that you try an IOS upgrade or raise a TAC
Alex.
Sandeep Choudhary Fri, 11/15/2013 - 04:53
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
HI Arun,
Troubleshoot bus error:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800cdd51.shtml
Cisco 3800 Series Router Hardware Troubleshooting
http://www.cisco.com/en/US/products/ps5855/products_tech_note09186a008073ee69.shtml
Verly old paper for troubleshooting bus error ,But the steps mentioned still holds good,  it would be a hardware fault  otherwise most probable an IOS bug/issue, which I can see that you'll  also agree about the IOS being obsolete.
Please rate helpful posts
Related Content
