Warning message
Cisco ASA 8.2 - anyconnect-essentials
Answered Question
Nov 16th, 2013
Experts
I need to enable the command anyconnect-essentials in my webvpn configuration.
When I do show run webvpn  I see:
no anyconnect-essentials.
If I go to webvpn:
(config-webvpn)anyconnect-essentials  ( then hit enter)  I get this error message:
Clientless sessions currently active:3
After all clientless sessions are disconnected, manually enable Anyconnect Essentials using ASDM or "anyconnect-essentials" CLI under webvpn mode.
For some Reason JAVA is screwed up and I can't run ASDM.
How Do I disconnect the Clientless sessions via CLI in order to add the command
Thanks for your help!!
Correct Answer by Marcin Latosiewicz about 3 years 9 months ago
vpn-sessiondb logoff ....
Overall Rating: 5 (1 ratings)
Ranbeckycr_2 Sat, 11/16/2013 - 06:53
Marcin,
Thanks for the quick response.
Question, will this only disconnect the Clientless sessions or will it also affect the other SA's?
If I run a show cry isa sa ---> It shows    Active SA:  57
I need to know if these 57 VPN tunnels will be affected.   :-)
Thanks again!!
Dinesh Moudgil Sat, 11/16/2013 - 07:26
  • Cisco Employee,
To log off all or selected VPN sessions, use the vpn-sessiondb logoff command in global configuration mode.
vpn-sessiondb logoff {remote | l2l | webvpn | email-proxy | protocol protocol-name | name username | ipaddressIPaddr | tunnel-group groupname | index indexnumber | all}
Richard Burts Sat, 11/16/2013 - 08:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I am somewhat puzzled. When you look for show cry isa sa  you are looking for ISAKMP but this is used for IPSec. I would expect the clientless and the AnyConnect sessions to be SSL based and not IPSec ISAKMP based.
I would also ask whether you already have installed the AnyConnect Essentials license on this ASA.
Rick
Marcin Latosiewicz Sat, 11/16/2013 - 08:47
  • Cisco Employee,
Hehe, good point, although this might be AC IKEv2 tunnels :-)
@Randall yes, you're probably looking for clearing your SSL connections as Rick mentions.
Richard Burts Sat, 11/16/2013 - 08:50
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I sort of wondered about that until I remembered that the title of the thread says that the ASA is running 8.2 code.
Rick
Ranbeckycr_2 Sat, 11/16/2013 - 10:26
Thanks a bunch for the help, @Richard: Anyconnect license is already installed because it was previously working. I noticed that configuration change today after the reboot. I didn´t know if the SA and Clientless where related, but I know understand that they are 2 separte things completely.
*- Just to clarify, if I run the vpn-sessiondb logoff it will knock out all the clientless sessions.
So step 1:  Run vpn-sessiondb logoff
Step 2:Run in (config-webvpn)anyconnect-essentials
Sounds about right?
Once again, thanks
