Warning message
ACS 5.4 FTP \ in username
Nov 16th, 2013
  • Bronze, 100 points or more
I have an ACS 5.4 with the latest patch installed and I want to add an external repository by FTP, except the FTP server is IIS 6.0 on Windows 2k3 and it requires the username to be: DOMAIN\username
It seems the \ character is not unsupported by ACS; GUI gives an error, CLI actually accepts the command but clears the \ from the running (replaces it with DOMAINusername)...
show repository in CLI fails because of this, IIS logs a username/password error in event viewer.
I also tried [email protected]; [email protected] (FQDN), [email protected]... (also tried in lowercase)
anyone ever tried this?
Patrick
Overall Rating: 5 (1 ratings)
Jatin Katyal Sun, 11/17/2013 - 04:55
  • Cisco Employee,
Patrick,
As far as I know ACS 5.x doesn't accept any special characters (\, /, @) in username field while creating repo and few other customers also faced the same issue. This is not supported with GUI and CLI. Last I checked this on ACS 5.3. You need to use a simple user account without any special character. I'll also check if there is any enhancement request filed to support this.
~BR
Jatin Katyal
**Do rate helpful posts**
Miroslav Horak Tue, 11/25/2014 - 07:13
Very well, works for me with ACS 5.5 and IIS 6.0
I can use domain acc now without stating a domain.
Thx
