Warning message
Applying NTP reference to IP Phones
Nov 17th, 2013
  • Gold, 750 points or more
Please clarify whether applying the NTP reference to date/time group in turn this date/time group is assigned to device pool is it going to require the phones to be restarted..
Overall Rating: 5 (4 ratings)
Aman Soi Sun, 11/17/2013 - 05:26
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Hi Mahmood,
the phones would restart .
Adding a Date/Time Group
After adding a new date/time group to the database, you can assign it to a device pool to configure the date and time information for that device pool.
You must reset devices to apply any changes that you make.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmsys/a02sycfg.html#wp1074727
the same would happen for NTP as well.
further, other nodes also need to be restarted in cluster for changes to happen.
https://supportforums.cisco.com/thread/2184534
regds,
aman
mahmoodmkl Sun, 11/17/2013 - 20:53
Thanks for the reply.
Please confrim whether just adding the NTP reference without assigning to any date/time group will cause any reset of IP Phones.
Aman Soi Sun, 11/17/2013 - 22:00
    2017 IP Telephony
Hi Mahmood,
I do not think so but let me check.
regds,
aman
Carlo Poggiarelli Sun, 11/17/2013 - 22:56
  • Green, 3000 points or more
Hi.
As Aman stated(+5 P Aman) you don't need to reset anything if you just add a new ntp reference without assign it.
Carlo
Aman Soi Mon, 11/18/2013 - 06:30
    2017 IP Telephony
Hi Carlo,
thanks for confirming.[+5]
regds,
aman
