Warning message
Scott Fella Sun, 11/17/2013 - 12:18
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I don't know what your asking.  if your talking about 802.11b, that is a standard and you can compare the difference of 802.11b, 802.11a, 802.11g, 802.11n and or 802.11ac. Wireless devices, that means client devices have to be able to support the standard that the access point is using.  So if an access point is 802.11b only, the wireless client device has to be able to support 802.11b.  If for example, the access point is 802.11b/g/a/n/ac, that means the client has to be able to support at least one of those standards to be able to connect.
Just take a look at the standards,  here is a link to a quick comparison.
http://compnetworking.about.com/cs/wireless80211/a/aa80211standard.htm
Scott
Help out other by using the rating system and marking answered questions as "Answered"
Mohammed.Mutai.Khan Mon, 11/18/2013 - 01:43
I do know about the standards mentioned . This B Channel is some concept with long distance coverage with high throughputs. Something I believe is used for Wi-Fi Base Stations.I just wanted to know if there is any document I can refer with it?
Scott Fella Mon, 11/18/2013 - 04:40
  • Hall of Fame,
    2017 Wireless
I don't know of any B channels "concept".
Scott
Leo Laohoo Mon, 11/18/2013 - 14:04
  • Hall of Fame,
    2017 LAN, Wireless
Define "high throughputs".  1 Mbps is considered as a "high throughput" if you ONLY consider 802.11b was first released.
There's a strange possibility that you are refering to a very old document (even the ORIGINAL marketing document for the release of 802.11b standard).
vlad.mihailov Mon, 11/18/2013 - 21:34
I too have not heard about the B Channel concept.
What is referenced often as 802.11b standard today is described in two clauses under 802.11 standard - Clause 15 and Clause 18. Clause 15 defines the DSSS encoding for data speeds of 1 and 2Mbps. Later protocol improvement is referenced in Clause 18 and adds the 5.5 and 11 Mbps encodings. This encoding was also called High Rate DSSS (HR/DSSS) and was also part of the 802.11b amendment. Could that be that by High Throughput you are referencing the HR/DSSS 5.5 and 11 encodings?
George Stefanick Mon, 11/18/2013 - 21:42
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Clause 18 is indeed HRDSS. It added cck bit coding at 5.5 and 11. HT is clause 20 better know as 802.11n
George Stefanick Mon, 11/18/2013 - 21:46
Let me further add .. 802.11 clause 14/15 come in 2 flavors (fhss and dsss). DSSS uses barker code to chip the bits and uses DBFSK and DQPSK as modulations, 1 and 2 meg phys respectably. 802.11b was introduced which brought 5.5 and 11 phys.
Hope this helps
vlad.mihailov Tue, 11/19/2013 - 13:08
My association was going between 'B' and 'High' ;-) Thus I thought that something in between has to be HR/DSSS.
Mohammed.Mutai.Khan Tue, 11/19/2013 - 01:53
As I have said, this is something which has been asked in the RFP , once i get the complete details I wil update on whct was meant by the customer.
Scott Fella Tue, 11/19/2013 - 04:34
  • Hall of Fame,
    2017 Wireless
Yeah... Please ask and get more detail, because it doesn't make sense.
mscherting Tue, 11/19/2013 - 10:10
Any chance the customer is asking about the 802.11n extension or bonded channel?
Abhishek Abhishek Thu, 11/21/2013 - 09:56
  • Gold, 750 points or more
There are only 3 non-overlapping channels available in the 802.11b   standard.These are Channels 1,6, and 11. For WiFi access points that are   located near each other it is recommended that they each use one of  the  above non-overlapping channels to minimize the effects of  interference.
Mohammed.Mutai.Khan Wed, 11/27/2013 - 22:17
I had a meeting with the telecom operator, they are still saying it as B Channel, but on asking for detail, what they are explaining is completely identical to channel Bonding. SO I believe this is their terminology to call Channel Bonding as B Channel. So I believe this is the conclusion. Any more inputs on channel Bonding will be very helpful.
Related Content
