Warning message
ap and wgb
Answered Question
Nov 17th, 2013
I know wgb is used as wireless client to extend connectivity to wired end devices. However, can someone please help me understand the difference between
a normal ap & wgb(after it is converted to wgb from an ap), in terms of connectivity & signal coverage.
Can we substitute a normal AP in place of wgb if there is a need to connect a thermal scanner to this wgb or ap and the connections needs to work over the wireless network.
Correct Answer by Rasika Nayanajith about 3 years 9 months ago
If the requirement is to extend the coverage to a location where wired users will be connected, can a WGB be used.
i.e WGB connects to another AP nearby for wireless & a switch is connected to the ethernet port of WGB , where users will connect themselves on.
      Yes, this is the functionality of WGB. See below post topology is what you are trying to achieve. If it is, you are ok with that.
           http://mrncciew.com/2013/06/16/unified-ap-wgb-with-multiple-vlan/
Is this feasible or we need to have a normal AP(non-WGB) for such a scenario. The users in this location might also connect themselves via wireless at times.
     As WGB is typically act as a client, it does not provide wireless coverage expansion (or acting as AP). So you need to have normal AP wireless coverage in the area to wireless client to join (including WGB itself)
Hope this clear, if not let me know
Rasika
**** Pls rate all useful resposnes ****
Assuming you will use WGB in your Unified Wireless Environment (without connecting it to another autonomous AP)
WGB will not consume any AP licence of your controller as it will connect to a Lightweight Access point managed by your WLC. There is no direct communication between WLC & WGB.
WGB(client) <====> LAP < ==== > SW <====>  WLC
Wired clients sitting behind WGB will appear under client list (Monitor -> Clients) of your WLC & appear them as a WGB clients (ie "WGB=Yes")
Rasika
Overall Rating: 5 (4 ratings)
suthomas1 Sun, 11/17/2013 - 16:50
thanks.
so can we say that a wgb can only provide connectivity to a client connected wired to it?
But it will not be able to provide wireless coverage for end users along the area. is that understanding correct?
Rasika Nayanajith Sun, 11/17/2013 - 17:01
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Yes, that's correct.
WGB solution is not for extending wireless coverage, but connecting wired clients (who does not have wireless interfaces) to your wireless network.
Rasika
suthomas1 Sun, 11/17/2013 - 17:05
Thanks.
Will WGB reflecting as client add to the AP licenses on the controller , as the license count increases the same way when we add an access point?
Correct Answer
Rasika Nayanajith Sun, 11/17/2013 - 18:11
    2017 Wireless
Rasika
suthomas1 Wed, 11/20/2013 - 16:06
Just getting some more understanding on this. Thanks.
Correct Answer
Rasika Nayanajith Wed, 11/20/2013 - 17:09
    2017 Wireless
Rasika
Rasika Nayanajith Sun, 11/17/2013 - 10:38
    2017 Wireless
As you identified, WGB is nothing but a wireless client (to connect wired devices to wireless network). Therefore you cannot connect any wireless devices to WGB under normal scenario.
So you cannot compare a AP & WGB as it does completely two different functions. You can think of WGB is a wireless client who is having very good antenna/througput (depend on the AP model/SS/etc)
If your WGB is dual band, then you can configure WGB assoication in one radio & you can create a normal wireless SSID in another band. But you need to test this (i haven't test it) & verify it gives what you need as this is not a common way of deploying WGB.
If your Termal Scanner is a wireless device, it will associate to your ROOT AP as normal client.
Rasika
**** Pls rate all useful responses ****
