MAC Filtering on Router via MQC
johnlloyd_13
Level 9
Level 9
hi all,
i'm doing a policy on a 2911 rouer to filter MAC address and apply it on the LAN port.
i didn't see the "permit" keyword and did a "no drop" instead on the policy-map.
appreciate if anyone could advise if this is correct and will accomplish my objective. TIA!
2911(config-pmap)#class MAC_FILTER_CLASS
2911(config-cmap)#match source-address mac ?
  H.H.H  MAC address
2911(config-cmap)#match source-address mac aaaa.bbbb.cccc
2911(config-cmap)#exi
2911(config)#policy-map MAC_FILTER_POLICY
2911(config-pmap)#class ?
  WORD            class-map name
  class-default   System default class matching otherwise unclassified packets
2911(config-pmap-c)#?
Policy-map class configuration commands:
  bandwidth        Bandwidth
  compression      Activate Compression
  drop             Drop all packets
  exit             Exit from class action configuration mode
  fair-queue       Enable Flow-based Fair Queuing in this Class
  log              Log IPv4 and ARP packets
  netflow-sampler  NetFlow action
  no               Negate or set default values of a command
  police           Police
  priority         Strict Scheduling Priority for this Class
  queue-limit      Queue Max Threshold for Tail Drop
  random-detect    Enable Random Early Detection as drop policy
  service-policy   Configure QoS Service Policy
  set              Set QoS values
  shape            Traffic Shaping
  <cr>
2911(config-pmap-c)#permit
% Invalid input detected at '^' marker.
2911(config-pmap-c)#no ?
  bandwidth        Bandwidth
  police           Police
  set              Set QoS values
  <cr>
2911(config-pmap-c)#no drop
2911(config-pmap-c)#do sh policy-map
  Policy Map MAC_FILTER_POLICY
    Class MAC_FILTER_CLASS
                                                   <<< "no drop" NOT FOUND OR IS IT THE DEFAULT?
2911(config)#int GigabitEthernet0/0
2911(config-subif)#service-policy input MAC_FILTER_POLICY
Yes, you are right with your asumption, "no drop" is a dfault in MQC. But what exactly do you want to achieve? Only allow one MAC-address and drop the rest?
Then you would configure your first class (the one where you match the MAC-address) in the policy-map with no action and add another class with "match any" and configure that with the action drop.
And remember that the class you configured at the beginning is a "match all" class. If you want to match on more then one address, you have to configure a "match any" class.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Karsten,
Thanks for confirming! The one I posted is just a sample. I've actually got a long list of MAC to for this task.
Are you referring to adding the 'class default' to be added on the second class to be dropped?
Could you give a sample template to test it out? I miss joining the Firewall/VPN group discussion. Been away and really busy lately :)
If you run a very new IOS it's worth to test it with the class-default. At least on 15.0 the class-default doesn't support the drop-action.
untested, but I think the following policy-map should work:
class-map match-all TEST-ANY
  match any
class-map match-any TEST-MAC
  match source-address mac AAAA.BBBB.CCCC
  match source-address mac BBBB.CCCC.DDDD
  match source-address mac CCCC.DDDD.EEEE
policy-map TEST
  class TEST-MAC
  class TEST-ANY
   drop
Just to confirm: Are the systems that you want to allow L2-adjacent to the router so that the router really sees the MAC-address of the PCs? If there is a L3-switch between, then it won't work. And always remember that this only implements a very weak security that can be easily circumvented by a skilled user (depending on the other security-measures you have in place).
Hi guys,
sorry for bringing this old one up, I tested it on a C886VA router and the limit for MAC ACLs was 75.
Is there any documentation around if this limit is for all router classes?
Michael
Michael Please rate all helpful posts
