Warning message
Phones that are no longer in use
Answered Question
Nov 18th, 2013
Is there a command I can run on the UC560 to find out which phones are no longer in use.  I have a customer with about 90 phones and I know some of them have been replaced so I want to free up the license and clean it up.  How can I find out CLI what phones to remove.
Correct Answer by johschaf about 3 years 9 months ago
show ephone unregistered will show you what phones are not registered to the UC.
However, I'm not sure if that is going to help you here, as only registered phones utilize a license. Removing the unregistered phones from the config would really just be to keep the config clean.
If you need to free up some licenses and you aren't using the FXS ports, that put the port into a shutdown state to free a license.
Hope this helps.
-john
Overall Rating: 5 (1 ratings)
Correct Answer
johschaf Mon, 11/18/2013 - 11:45
  • Silver, 250 points or more
Hope this helps.
-john
mark@excellent-... Wed, 11/20/2013 - 14:05
Thank you very much, I was able to delete the phones not in use and clean it up.  Thanks!
