Warning message
CAD email ready/not ready disabled.
Nov 18th, 2013
Hi Folks,
In the process of setting up email contact capability and have successfully configured CCX to integrate with Exchange.  I can see the email account and that it has automatically created a folder for my test CSQ and emails are coming in and being routed to the CSQ folder.  They aren't however being routed then to the assignments subfolders, I believe because the test agents can't set themselves to email ready, because Cisco Agent Desktop shows that the email ready/not ready buttons are greyed out.  What have I missed having followed the CAD and CCX guides?
Gabriel Saavedra Mon, 11/18/2013 - 16:06
  • Silver, 250 points or more
Hi Geordie, do you create the CSQ as an email CSQ and asign it to the agent?
Gabriel.
Geordie Guy Mon, 11/18/2013 - 16:24
Hi Gabriel,
Yes I did.  We can tell this is working correctly because otherwise the mailbox wouldn't be receiving email and routing it into the appropriate CSQ sub folder..
Geordie Guy Mon, 11/18/2013 - 16:31
Ok I think I know what's wrong but not how to fix it.  Wireshark convo output between CAD and Exchange;
* OK The Microsoft Exchange IMAP4 service is ready.
A0 CAPABILITY
* CAPABILITY IMAP4 IMAP4rev1 AUTH=NTLM AUTH=GSSAPI AUTH=PLAIN STARTTLS UIDPLUS CHILDREN IDLE NAMESPACE LITERAL+
A0 OK CAPABILITY compleNted.
A1 AUTHENTICATE PLAIN
AvNpc2NvQWdlbnREZdNrdG9wSW1hAH1273FyQ0Y1
A1 NO AUTHENTICATE failed.
A2 LOGOUT
* BYE Microsoft Exchange Server 2010 IMAP4 server signing off.
A2 OK LOGOUT completed.
So CAD is acting as an IMAP client (expected), asking to authenticate in plain text (expected), then sending an encrypted password (wut).
Geordie Guy Tue, 11/19/2013 - 18:56
None of the existing suggestions on this forum helped, I checked before I posted.  It's UCCX 9.
tom.sullivan@ca... Wed, 11/20/2013 - 10:05
An initial review would suggest the following possible causes:
-          invalid username/password entered in.
-          the connection to exchange is on a port that allows a certain type of connection but the credentials were provided in a different format. The install guide states what the forms of the credentials must be depending on the connection type. e.g. for NTLM, provided login must be domain\username, etc.
Beyond that, you'll want to work this through with TAC if you aren't already.
Tom
Saeed Syed Thu, 11/21/2013 - 05:06
We had a same problem but were able to resolve it after a long time. Hope you have premimum license follow the instruction for email setup guide. also user should assigned to email csq with proper skills and competense. Also a correct version of Java.
Geordie Guy Mon, 11/25/2013 - 14:06
This got resolved but I couldn't tell you how.  I had to rip out all the configuration and go again and whatever was misconfigured the first time is now correct.
Christian Quiroga Thu, 03/19/2015 - 14:42
I Have this problem, but we don´t have Exchange. We have Apple Mavericks OSX Server 10.9 with IMAP and SMTP.
From Desktop Administrator i can connect with the server usign IMAP and SMTP, but  the system  can´t assign it to agents. All emails remain in CSQ folder and email buttons in Agent Desktop Interface are disable.
Any idea about this ?
I know that this works good with exchange but my customer don´t have this software and licences.
Thanks.
Related Content
