Warning message
Cisco Core Switch 6506-E Rommon Mode
Nov 18th, 2013
Dear Sir,
Good Day!
Everytime I try to restart my Cisco Core Switch 6506-E, it will go on ROMMON 1 mode command.
This problem I encountered when my Electrical Power accidentally shutdown.
The Solution I did is to just type - boot command
and then Automatic iniatilize the configuration and reboot from normal.
What can I do to fix this issue permanently?
Your immediate response is highly appreciated.
Thanks and Best regards,
Michael D. Miranda
Overall Rating: 5 (1 ratings)
Richard Michael Fri, 11/22/2013 - 02:43
  • Cisco Employee,
check if you have config-register set  to 0x2102 on both RP and SP.
sh version -> on RP
remote login switch
sh version -> on SP
If not i would say change it
Richard.
Leo Laohoo Fri, 11/22/2013 - 15:51
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Maybe the boot statement is incorrect.
Post the output to the following commands:
1.  sh bootvar
2.  dir sup-bootdisk:
3.  dir disk0:
damiranz20 Fri, 12/06/2013 - 04:20
Dear Sir,
Thsi is the snapshot of my Cisco Core Switch. Everytime I restarted it. It will Boot on ROMMon Mode.
aukhadiev Fri, 12/06/2013 - 04:49
  • Bronze, 100 points or more
Hi, Michael Miranda...
I absolutely agree with Richard Michael, he offered you the right solution, but let me explain a little more deeply situation.
Sorry, English is not my native language and I can not well everlasting on it complicated things... I just give you links to two articles, after reading that you all will become clear:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00803e5282.shtml
http://www.cciezone.com/?p=188
In short, you have mismatch of the configuration register of SP and RP...The solution is to reconfigure the configuration register and reload the system:
config t
config-register 0x2102
end
