Prefix list
Answered Question
Nov 19th, 2013
  • Silver, 250 points or more
hello l have a question about prefix list with 3 routers. l configure 3 router R-1 as the branch, R-2 as the WAN and R-3 the head office (with a lot of loopbacks).
l want to configure prefix list on the WAN(R-2) to block all address with /30 and some of the loopbacks from displaying on the branch office routing table.
it works fine but the problem is, l cannot ping from the branch to any of the loopback. the ICMP does't pass through WAN router.
it works fine with 2 routers as the configuration is done on the head office that will display and work fine.
Posted by WebUser Salis Mahama from Cisco Support Community App
Correct Answer by Karthick Murugan about 3 years 9 months ago
It looks like its an expected behavior as per your configuration. R3 doesn't have information about any of the prefixes of R1 as per the routing table entry. For R3 to reach R1, atleast we need a default-route which is not available.
I EIGRP advertising the default route as "network 0.0.0.0" won't work until you have a static route like ip route 0.0.0.0 0.0.0.0
Thanks & Regards,
Karthick Murugan
CCIE#39285
Overall Rating: 5 (1 ratings)
cadet alain Tue, 11/19/2013 - 02:11
  • Purple, 4500 points or more
post topology diagram and the configs.
Alain
fb_webuser Tue, 11/19/2013 - 07:34
R1 -
........-R-2----
R3
f0/0 10.1.1.0/30 f0/0 f0/1 10.9.1.0/30 f0/0
R1 config
interface FastEthernet0/0
ip address 10.1.1.2 255.255.255.252
speed 100
full-duplex
router eigrp 100
network 0.0.0.0
no auto-summary
R2 config
ip address 10.1.1.1 255.255.255.252
speed 100
full-duplex
interface Serial0/0
ip address 10.9.1.5 255.255.255.252
clock rate 2000000
interface FastEthernet0/1
ip address 10.9.1.1 255.255.255.252
speed 100
full-duplex
router eigrp 100
network 0.0.0.0
distribute-list prefix BLK30 out
no auto-summary
ip prefix-list BLK30 seq 5 deny 0.0.0.0/0 ge 30 le 30
ip prefix-list BLK30 seq 10 permit 0.0.0.0/0 le 32
R3 config
interface Loopback1
ip address 17.1.1.1 255.255.0.0
interface Loopback2
ip address 17.2.2.2 255.255.128.0
interface Loopback3
ip address 17.3.3.3 255.255.192.0
interface Loopback4
ip address 17.4.4.4 255.255.224.0
interface Loopback5
ip address 17.5.5.5 255.255.240.0
ip address 10.9.1.2 255.255.255.252
speed 100
full-duplex
ip address 10.9.1.9 255.255.255.252
speed 100
full-duplex
interface FastEthernet1/0
ip address 10.9.1.13 255.255.255.252
duplex auto
speed auto
router eigrp 100
network 0.0.0.0
no auto-summary
this is the show ip route on R1
Branch1#show ip route eigrp
17.0.0.0/8 is variably subnetted, 5 subnets, 5 masks
D 17.1.0.0/16 via 10.1.1.1, 00:13:03, FastEthernet0/0
D 17.3.0.0/18 via 10.1.1.1, 00:13:03, FastEthernet0/0
D 17.2.0.0/17 via 10.1.1.1, 00:13:03, FastEthernet0/0
D 17.5.0.0/20 via 10.1.1.1, 00:13:03, FastEthernet0/0
D 17.4.0.0/19 via 10.1.1.1, 00:13:03, FastEthernet0/0
10.0.0.0/8 is variably subnetted, 5 subnets, 3 masks
D 10.16.2.0/25 via 10.1.1.1, 00:12:58, FastEthernet0/0
D 10.16.3.0/25 via 10.1.1.1, 00:12:58, FastEthernet0/0
D 10.16.1.0/24 via 10.1.1.1, 00:12:58, FastEthernet0/0
D 10.16.4.0/25 via 10.1.1.1, 00:12:58, FastEthernet0/0
Branch1#
from the config it block all the ip address with /30 and allow everything else but the problem is, after this configuration l cannnot ping from R1 to the loopbacks on R3.
thanks for your help
Correct Answer
Karthick Murugan Tue, 11/19/2013 - 09:41
  • Cisco Employee,
Thanks & Regards,
Karthick Murugan
CCIE#39285
