VPN Client Defines Non-existent Standard-Gateway
jjblaette
Hello!
We have configured a IPSec-tunnel that has on one side the Cisco router 876 and on the other side the Cisco VPN Client. The tunnel is established without problems and the server on the Cisco router 876-side can be reached without problems, when Cisco VPN Client is used on a client with 32 bit.
But, if the Cisco VPN Client with 64 bit on a Windows 7 client is used, the server on the Cisco router 876-side cannot be reached although the tunnel is established correctly. The difference that I could notice is that with 32 bit the standard gateway of the client has the same IP-address as the client interface of the Windows (XP) 32 bit-system. With 64 bit (Windows 7) however the IP address is different than the IP of the client interface and usually does not exist. So we suspect that the server cannot be reached because a non-existent standard-gateway is configured.
Question now is with 64 bit how to define the correct standard-gateway on the client system.
Any help is very much appreciated!
Jakob
Marcin Latosiewicz
Jakob,
The default GW behavior is specific to vista and on (if I properly understand what you're saying).
I'll quote an internal reference:
Due to changes in the way Vista behaves with routing, the default gateway method of the VPN Client routing needed to be changed.
Prior to 4.8.02.0010, the default gateway of a tunnel all connection pointed directly at the VPN assigned IP address.
  Vista didn't like this so it was changed to point at a fake IP address on the VPN assigned subnet.  This does not affect traffic to this address if it happens to overlap with an actual device on that subnet.
Hello, Marcin,
thank you for your kind answer. This helps to understand why the default gateway is different with Windows XP and Windows 7.
Nevertheless the problem remains that with XP the server at the remote site is reachable while with Windows 7 the server is not reachable.
Any idea why this is the case? Thanks in advance!
Jakob
Looks like it's time to troubleshoot connectivity. Except the info about Windows versions we have no information to go with.
May I suggest opening a TAC case? ;-)
