Dell STP and Cisco Rapid-PVST+ interoperabillity
ivanbarkic
Referencing to this doc:
https://supportforums.cisco.com/docs/DOC-16177
which was very helpful, I noticed that I'm getting this error message:
%SW_MATM-4-MACFLAP_NOTIF: Host d067.e5cc.2e49 in vlan 1 is flapping between port Po11 and port Po12
I have Dell PC6248 connected to C3560 with two port channels. In fact, I have two Dell switches in a stack. As document describes, I configured MST on both switches and that resolved slow convergence of network, but above message now appears.
That MAC address is no host:
Cisco switch
Dell switch
Cisco switch:
Router_Switch#sh mac address-table
          Mac Address Table
Vlan    Mac Address       Type        Ports
All    0100.0ccc.cccc    STATIC      CPU
All    0100.0ccc.cccd    STATIC      CPU
All    0180.c200.0000    STATIC      CPU
All    0180.c200.0001    STATIC      CPU
All    0180.c200.0002    STATIC      CPU
All    0180.c200.0003    STATIC      CPU
All    0180.c200.0004    STATIC      CPU
All    0180.c200.0005    STATIC      CPU
All    0180.c200.0006    STATIC      CPU
All    0180.c200.0007    STATIC      CPU
All    0180.c200.0008    STATIC      CPU
All    0180.c200.0009    STATIC      CPU
All    0180.c200.000a    STATIC      CPU
All    0180.c200.000b    STATIC      CPU
All    0180.c200.000c    STATIC      CPU
All    0180.c200.000d    STATIC      CPU
All    0180.c200.000e    STATIC      CPU
All    0180.c200.000f    STATIC      CPU
All    0180.c200.0010    STATIC      CPU
All    ffff.ffff.ffff    STATIC      CPU
   1    d067.e5cc.2e49    DYNAMIC     Po11
255    d067.e5cc.2e47    DYNAMIC     Po11
Total Mac Addresses for this criterion: 22
WSS_Dell_PC6248#show bridge address-table
Aging time is 300 Sec
  Vlan        Mac Address       Port          Type
1        04C5.A464.301F        ch1        Dynamic
1        04C5.A464.3025        ch2        Dynamic
1        04C5.A464.3028        ch1        Dynamic
255      04C5.A464.3045        ch1        Dynamic
255      D067.E5CC.2E47        cpu        Management
Total MAC Addresses in use:5
VLAN 255 is mgmt vlan. I didn't get that message before using mst.
Configuration of trunk ports on Dell:
interface port-channel 1
description 'TRUNK_3560_1'
switchport mode general
switchport general allowed vlan add 10,255 tagged
exit
What seems to be the problem here?
Cisco
##### MST0    vlans mapped:   1-4094
Dell
###### MST 0 Vlan Mapped:   1, 10, 20, 255
MSTP BPDUs contain a digest of the VLANs-to-instance mapping table and this digests have to match on all switches within the Region (in addition with the revision number and the name). You can check the digest on the Cisco switch with "show spanning-tree mst configuration digest", I guess there is also a command to show it available for the Dell.
I'm not sure if this is really an issue in your scenario because the Dell has accepted the Cisco as the root bridge.
[]EDIT:
WSS_Dell_PC6248#show spanning-tree mst-configuration
Revision: 0
Names and Revisions also have to match.
Rolf
Peter Koltl
Level 7
Level 7
show spanning-tree mst 0
show etherchannel summary
Check the same on Dell side.
Check the port channel cabling to make sure the member links form the same pairs on both sides.
CISCO 3560:
Router_Switch#show spanning-tree mst 0
Bridge        address 04c5.a464.3000  priority      32768 (32768 sysid 0)
Root          this switch for the CIST
Operational   hello time 2 , forward delay 15, max age 20, txholdcount 6
Configured    hello time 2 , forward delay 15, max age 20, max hops    20
Interface        Role Sts Cost      Prio.Nbr Type
Fa0/25           Desg FWD 200000    128.29   P2p
Po11             Desg FWD 100000    128.136  P2p
Po12             Desg FWD 100000    128.144  P2p
Router_Switch#show etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 2
Number of aggregators:           2
Group  Port-channel  Protocol    Ports
11     Po11(SU)         -        Fa0/33(P)   Fa0/35(P)
12     Po12(SU)         -        Fa0/27(P)   Fa0/36(P)
DELL:
WSS_Dell_PC6248#show interfaces port-channel
Channel   Ports                         Hash Algorithm Type
ch1       Active: 1/g48, 2/g48          3
ch2       Active: 1/g47, 2/g47          3
(output omited)
Revision: 0
Instance    Vlan Mapped
0          1, 10, 20, 255
Spanning tree Enabled  BPDU flooding Disabled Portfast BPDU filtering  Disabled mode mstp
CST Regional Root:        A0:00:D0:67:E5:CC:2E:47
Regional Root Path Cost:  0
ROOT ID
              Address         04:C5:A4:64:30:00
              Path Cost       100000
              Root Port      ch2
              Hello Time 2 Sec Max Age 20 sec Forward Delay 15 sec
Bridge ID
              Priority        40960
              Address         D0:67:E5:CC:2E:47
              Hello Time 2 Sec Max Age 20 sec Forward Delay 15 sec TxHoldCount 6 sec
(output omited)
  1/g47   Enabled  128.47            0   FWD  Disb      No      No
1/g48   Enabled  128.48            0   FWD  Disb      No      No
(output omited)
ch1     Enabled   96.626      100000   DSC  Altn      No      No
ch2     Enabled   96.627      100000   FWD  Root      No      No
(output omited)
Cisco
Dell
[]EDIT:
Revision: 0
Rolf
Today I started scenario again and it didn't show the flapping message and I even didn't configure mst instances to be same on both switches. However, just in case I will configure instances to be equal on both sides. Thanks.
