Warning message
Cannot ping interfaces
Answered Question
Nov 19th, 2013
Ok.. Good day, I have an ASA 5510 and a 2921 -
My ASA is used for VPN and Internet
My 2921 is used to connect different subnets
I also have an attached diagram
I have a directly connected interface on 2921-10.10.10.1 to the ASA 10.10.10.2
Also on the 2921 i have a subnet 192.168.2.0 and 10.20.30.0
I have trunk link on my switch 2950 from the 2921... The ASA is aslo connected to the switch
on the ASA
Int0/0 66.xxx.xxx.xxx internet
Int0/1 10.20.60.2 - Gateway for computers
Int0/2 10.10.10.2 - connected to 2921
on the 2921
gig0/1 10.10.10.1 - connected to ASA
gig0/1.20 sub-if 192.168.2.1
gig0/1.30 sub-if 10.20.30.1
I have connected some static routes to get from 10.20.60.0 to 192.168.2.0
I cannot ping 10.10.10.2 from my PC
I cannot ping 10.20.60.2 from my 2921
I would appreciate any ideas for configuration help...  And redesign...
What cannot happen is for us to use the 2921 for vpn and internet..
Thanks,,, see image.
Correct Answer by Jon Marshall about 3 years 8 months ago
Roger
I think the way you have it now is the way to do it ie. use the 2921 to route the internal vlans and only use the ASA when you need to go to the internet or use the vpn. If you wanted to use the ASA to route the vlans then you would need additional configuration on it and i can't see the advantage of doing that unless you have security issues ?
Does this make sense ?
Jon
Overall Rating: 4.5 (2 ratings)
Umesh Shetty Tue, 11/19/2013 - 09:36
Hi Roger,
The config from routing perspective looks good, now since in both cases you are trying to ping the IP configured on the ASA firewall I wonder if there is a stealth rule thats dropping that traffic.(I am not an expert though with ASA, I would check that first).
Also if you have set the rule to allow ICMP between these subnets can you try
1> Pinging from your PC to 10.10.10.1
2> From 2921 to ping your PC
Another suggestion would be since this probles is related to ASA you could post this in the Security section to get the security experts to help you.
Umesh
Jon Marshall Tue, 11/19/2013 - 11:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Roger
You won't be able to because on the ASA this is a restriction by design ie you cannot ping another interface across the ASA.  You can obviously ping through the ASA ie. in one interface and out another (as long as your rulebase allows it) but if the destination IP of the packet is another ASA interface this will be blocked.
So what you are seeing is correct behaviour. Do you have a connectivity problem or was it just a query you had ?
Jon
Roger Richards Wed, 11/20/2013 - 09:23
Not connectivity issues but probems with provisioning some avaya phones using DHCP on W2K8 server . Just basically needed to do intervlan routing with the 2921 but we still need the ASA connected as default gateway. Sooooooooo....... i need lots of help. Maybe on a different forum. But thats how this all started.
Jon Marshall Wed, 11/20/2013 - 10:00
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
If it's a problem with the phones then maybe the VOIP forums but if it is the network layout then this is the right forum.
If it is network layout etc. can you perhaps specify exactly what you want to be able to do and then we may be able to help you.
Jon
Roger Richards Wed, 11/27/2013 - 12:50
I got everything working. That "untagpvidonly" is a avaya command.
My real issue is I can ping anything on the 192.168.2.0 subnet but I cant actually login to any devices. If I can resolve that, it'll be great. Take another look at the attached diagram and tell what can I do. If I put my pc with a gateway address of 10.20.60.1 I can log into my phone call server, If I put my pc with 10.20.60.2 , it just hangs there
Jon Marshall Wed, 11/27/2013 - 13:01
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
What is 10.20.60.1 ?
Jon
Roger Richards Wed, 11/27/2013 - 13:11
sorry I forgot to include 10.20.60.1. Its a sub interface on the 2921, and its dot1q is 10. Vlan 10. I coudnt see how else I colud have routed to the 192.168.2.0 network. and both subnet has ip helper pointing to a dhcp server.
Correct Answer
Jon Marshall Wed, 11/27/2013 - 13:19
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
Jon
Roger Richards Tue, 12/03/2013 - 09:54
Hey Jon,
I got another Issue. How can I use the 2921 for the internet ,my ASA has the 10.20.60.2 <-- as the gateway for my computers and also my 2921 has the interface 10.20.60.1 interface also?
i appreciate any information given.
Jon Marshall Tue, 12/03/2013 - 10:33
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
This could get a bit complicated but not necessarily.
Your ASA has 2 internal connections, one to the switch and one to the 2921. But it only really needs the one connection to the 2921.  So all vlans internally are routed off the 2921 and you only go to the firewall for VPN and internet.
However that would mean changes to the 2921 and more importantly the ASA. The current ASA inside interface is on the 10.20.60.x network whereas it would move to the 10.10.10.0/31. This would mean a route change on the 2921 but potentially a fair bit more config on the ASA.
Before you did any of that thoug, on the ASA you have this route -
172.20.2.0 255.255.255.0 172.20.16.11 inside
what is the 172.20.2.x network and what device is 172.20.16.11 ?
Jon
Roger Richards Tue, 12/03/2013 - 10:38
thats a network on the other side on the vpn. I couldnt get to it from the 2921
Jon Marshall Tue, 12/03/2013 - 10:50
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
If it is a network on the other side of the VPN then why does the ASA have a route pointing back into your network ie. the route is reachable via the inside interface of the ASA not the outside.
Not trying to be difficult but if i am to suggest changes i need to make sure i don't stop things working.
Jon
Roger Richards Tue, 12/03/2013 - 10:55
Sorry Jon, my apologeeez.. that was an experimentl route... it does not  serve a perpose. I do and will appreciate if i can get this task done.  It would solve my problems. (well at least the ones here)
Jon Marshall Tue, 12/03/2013 - 11:04
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
No problem. Can you post the configs of the 2921 and the ASA and i can then have a look and suggest how to reorganize it so all vlans are routed off the 2921 and the ASA is just for internet.
Note when you post remove any sensitive info from the ASA such as public IPs etc.
Jon
Roger Richards Tue, 12/03/2013 - 12:04
THIS IS THE ASA:
ciscoasa-stx# show run
: Saved
ASA Version 8.3(1)
hostname ciscoasa-stx
domain-name stt.vidol.gov
enable password lb70NCTEuCJ09Sct encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
nameif Vipowernet
security-level 0
ip address 66.xx.xx.xx  255.255.255.248
interface Ethernet0/1
nameif Inside
security-level 100
ip address 10.20.60.2 255.255.254.0
interface Ethernet0/2
shutdown
nameif Voice
security-level 100
no ip address
interface Ethernet0/3
nameif 2921
security-level 100
ip address 10.10.10.2 255.255.254.0
interface Management0/0
nameif management
security-level 100
ip address 10.20.80.100 255.255.255.0
boot system disk0:/asa831-k8.bin
ftp mode passive
clock timezone AST -4
dns domain-lookup Inside
dns server-group DefaultDNS
name-server 10.20.60.21
name-server 172.20.16.3
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network STT
subnet 172.20.16.0 255.255.255.0
description St. Thomas Office
object network A_66.xx.xx.xx.105
host 66.xx.xx.xx.105
object network PublicServer_NAT1
host 10.20.60.39
object service ClockLink
service tcp source eq 5074 destination eq 5074
description Clock Link Management Software
object network A_66.xx.xx.xx.107
host 66.xx.xx.xx.107
object service rdp
service tcp destination eq 3389
description Remote Desktop Protocol
object network VoIP-STT-Network
subnet 192.168.4.0 255.255.255.0
object network VoIP-STX-Network
subnet 192.168.2.0 255.255.255.0
object network STTNET
description STT NETWORK
object network STXET
subnet 10.20.60.0 255.255.254.0
description STX NETWORK
object network outside
host 66.xx.xx.xx.106
object network inside
host 10.20.60.2
object network Public-66.xx.xx.xx.108
host 66.xx.xx.xx.108
object service TCP8080
service tcp source eq 8080
object network VC_66.xx.xx.xx.109
host 66.xx.xx.xx.109
object network Clock82
host 10.20.61.82
object network Clock83
host 10.20.61.83
object network Clock81
host 10.20.61.81
object network Clocks
range 10.20.61.81 10.20.61.83
description Clocks
object network Polycom
host 10.20.60.8
object network PRTG
host 10.20.60.35
object network prtg1
host 10.20.60.35
object network Object_Clock81
host 10.20.61.81
object network Object_Clock_6401
host 10.20.61.81
object network Object_Clock_6402
host 10.20.61.82
object network Object_Clock_6403
host 10.20.61.83
object network Voice1
host 192.168.2.1
object-group network DM_INLINE_NETWORK_1
network-object host 172.20.21.4
network-object 172.20.16.0 255.255.255.0
network-object 192.168.4.0 255.255.255.0
object-group network DM_INLINE_NETWORK_2
network-object 10.20.60.0 255.255.254.0
network-object 192.168.2.0 255.255.255.0
object-group network DM_INLINE_NETWORK_3
object-group network DM_INLINE_NETWORK_4
network-object object VoIP-STX-Network
object-group network DM_INLINE_NETWORK_6
network-object object STT
network-object object VoIP-STT-Network
object-group network DM_INLINE_NETWORK_8
network-object host 125.210.221.172
network-object host 220.231.141.29
object-group service POLLY tcp
port-object eq h323
port-object eq sip
port-object eq 1731
port-object range 3230 3235
object-group service DM_INLINE_SERVICE_2
service-object tcp-udp destination eq domain
service-object tcp destination eq www
service-object tcp destination eq https
object-group service web tcp
port-object eq 8081
object-group network DM_INLINE_NETWORK_7
network-object host 10.20.61.81
network-object host 10.20.61.82
network-object host 10.20.61.83
object-group service ExtClkLnk tcp
port-object eq 5402
access-list Vipowernet_access_in extended deny ip object-group DM_INLINE_NETWORK_8 any inactive
access-list Vipowernet_access_in extended permit ip object-group DM_INLINE_NETWORK_3 any
access-list Vipowernet_access_in extended deny tcp any object PRTG eq 8081 inactive
access-list Vipowernet_access_in extended deny tcp any object Polycom eq www inactive
access-list Vipowernet_access_in extended permit tcp host 66.248.189.100 object-group DM_INLINE_NETWORK_7 eq 5402
access-list Vipowernet_cryptomap extended permit ip object-group DM_INLINE_NETWORK_2 object-group DM_INLINE_NETWORK_1
access-list Inside_access_in extended permit ip object STXET object STTNET
access-list Inside_access_in extended permit ip host 10.20.61.1 any
access-list Inside_access_in extended permit object-group DM_INLINE_SERVICE_2 host 10.20.60.81 any
access-list Inside_access_in extended deny ip host 10.20.60.81 any
access-list Inside_access_in extended permit ip object-group DM_INLINE_NETWORK_4 any
access-list Inside_access_in extended permit ip any any
access-list Inside_access_in extended deny ip any any
access-list 2921_access_in extended permit ip any any log
access-list outside_1_cryptomap extended permit ip 10.20.60.0 255.255.254.0 172.20.16.0 255.255.255.0
access-list DOF extended permit ip any 172.20.2.0 255.255.255.0
access-list vidolas extended permit ip host 10.20.60.251 host 172.20.16.109
access-list vidolas extended permit ip host 172.20.16.109 host 10.20.60.251
access-list STX-STT extended permit ip object STXET object STTNET
access-list STX-STT extended permit ip object STTNET object STXET
access-list block extended deny ip host 23.15.5.113 any
access-list voice-to-lan extended permit ip 10.20.60.0 255.255.254.0 192.168.2.0 255.255.255.0
pager lines 24
logging enable
logging timestamp
logging trap notifications
logging asdm informational
logging host Inside 10.20.60.35
logging host Inside 172.20.16.87
logging permit-hostdown
mtu Vipowernet 1500
mtu Inside 1500
mtu Voice 1500
mtu 2921 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any Vipowernet
icmp permit any Inside
icmp permit any Voice
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
nat (Inside,any) source static any any destination static DM_INLINE_NETWORK_6 DM_INLINE_NETWORK_6
nat (management,Vipowernet) dynamic interface
nat (Inside,Vipowernet) static 66.xx.xx.xx.108
nat (Inside,Vipowernet) static 66.xx.xx.xx.109
nat (Inside,Vipowernet) static interface service tcp 5402 6401
nat (Inside,Vipowernet) static interface service tcp 5402 6402
nat (Inside,Vipowernet) static interface service tcp 5402 6403
nat (Inside,Vipowernet) after-auto source dynamic any interface
access-group Vipowernet_access_in in interface Vipowernet
access-group Inside_access_in in interface Inside
access-group 2921_access_in in interface 2921
route Vipowernet 0.0.0.0 0.0.0.0 66.xx.xx.xx.105 1
route 2921 10.20.30.0 255.255.254.0 10.10.10.1 1
route Inside 172.20.2.0 255.255.255.0 172.20.16.11 1
route 2921 192.168.2.0 255.255.255.0 10.10.10.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication telnet console LOCAL
aaa authorization command LOCAL
aaa authorization exec authentication-server
http server enable
http 192.168.1.0 255.255.255.0 management
http 10.20.60.0 255.255.254.0 Inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map Vipowernet_map0 1 match address Vipowernet_cryptomap
crypto map Vipowernet_map0 1 set peer 66.xx.xx.xxx.170
crypto  map Vipowernet_map0 1 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5  ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5  ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map Vipowernet_map0 interface Vipowernet
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set peer 66.xx.xx.xx.170
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto ca trustpoint ASDM_TrustPoint0
enrollment url http://stxdc3:80/certsrv
crl configure
crypto ca trustpoint ASDM_TrustPoint1
enrollment url http://stxdc3:80/CertSrv
crl configure
crypto ca trustpoint ASDM_TrustPoint2
enrollment url http://stxdc3:80/CertEnroll
crl configure
crypto ca trustpoint ASDM_TrustPoint3
crl configure
crypto ca trustpoint ASDM_TrustPoint4
enrollment terminal
crl configure
crypto isakmp enable Vipowernet
crypto isakmp enable Voice
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 15
encryption des
hash md5
group 2
lifetime 28800
telnet 172.20.16.0 255.255.255.0 Vipowernet
telnet 10.20.61.1 255.255.255.255 Inside
telnet 10.20.60.0 255.255.254.0 Inside
telnet 0.0.0.0 0.0.0.0 Inside
telnet 172.20.16.0 255.255.255.0 Inside
telnet timeout 30
ssh timeout 5
console timeout 0
management-access Inside
dhcpd auto_config management
dhcprelay timeout 60
threat-detection basic-threat
threat-detection statistics host number-of-rate 2
threat-detection statistics port number-of-rate 2
threat-detection statistics protocol number-of-rate 2
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ntp server 10.20.60.21 source Inside prefer
ntp server 172.20.16.3 source Inside
webvpn
username Admin password 44WTHkc9M2sg5m4p encrypted privilege 15
username Ruser1 password IrO5kN5XfPlLpQcH encrypted
tunnel-group 66.xx.xx.xx.170 type ipsec-l2l
tunnel-group 66.xx.xx.xx.170 ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect pptp
service-policy global_policy global
privilege cmd level 3 mode exec command perfmon
privilege cmd level 3 mode exec command ping
privilege cmd level 3 mode exec command who
privilege cmd level 3 mode exec command logging
privilege cmd level 3 mode exec command failover
privilege cmd level 3 mode exec command packet-tracer
privilege show level 5 mode exec command import
privilege show level 5 mode exec command running-config
privilege show level 3 mode exec command reload
privilege show level 3 mode exec command mode
privilege show level 3 mode exec command firewall
privilege show level 3 mode exec command asp
privilege show level 3 mode exec command cpu
privilege show level 3 mode exec command interface
privilege show level 3 mode exec command clock
privilege show level 3 mode exec command dns-hosts
privilege show level 3 mode exec command access-list
privilege show level 3 mode exec command logging
privilege show level 3 mode exec command vlan
privilege show level 3 mode exec command ip
privilege show level 3 mode exec command ipv6
privilege show level 3 mode exec command failover
privilege show level 3 mode exec command asdm
privilege show level 3 mode exec command arp
privilege show level 3 mode exec command route
privilege show level 3 mode exec command ospf
privilege show level 3 mode exec command aaa-server
privilege show level 3 mode exec command eigrp
privilege show level 3 mode exec command crypto
privilege show level 3 mode exec command vpn-sessiondb
privilege show level 3 mode exec command ssh
privilege show level 3 mode exec command dhcpd
privilege show level 3 mode exec command blocks
privilege show level 3 mode exec command wccp
privilege show level 3 mode exec command dynamic-filter
privilege show level 3 mode exec command webvpn
privilege show level 3 mode exec command module
privilege show level 3 mode exec command uauth
privilege show level 3 mode exec command compression
privilege show level 3 mode configure command interface
privilege show level 3 mode configure command clock
privilege show level 3 mode configure command access-list
privilege show level 3 mode configure command logging
privilege show level 3 mode configure command ip
privilege show level 3 mode configure command failover
privilege show level 5 mode configure command asdm
privilege show level 3 mode configure command arp
privilege show level 3 mode configure command route
privilege show level 3 mode configure command aaa-server
privilege show level 3 mode configure command crypto
privilege show level 3 mode configure command ssh
privilege show level 3 mode configure command dhcpd
privilege show level 5 mode configure command privilege
privilege clear level 3 mode exec command dns-hosts
privilege clear level 3 mode exec command logging
privilege clear level 3 mode exec command arp
privilege clear level 3 mode exec command aaa-server
privilege clear level 3 mode exec command crypto
privilege clear level 3 mode exec command dynamic-filter
privilege cmd level 3 mode configure command failover
privilege clear level 3 mode configure command logging
privilege clear level 3 mode configure command arp
privilege clear level 3 mode configure command crypto
privilege clear level 3 mode configure command aaa-server
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
hpm topN enable
Cryptochecksum:b414a7744b28428be148e7c9b3083d67
THIS IS THE 2921
Labrstxrt1#show run
Building configuration...
Current configuration : 4023 bytes
! Last configuration change at 16:55:18 Caracas Fri Nov 29 2013 by ruser1
version 15.2
hostname Labrstxrt1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 weG1bff8xq6vwYSaAhFlBe/uto9gzwL2MYg8LekeXp6
no aaa new-model
clock timezone Caracas -4 0
ip cef
ip domain name stt.vidol.gov
no ipv6 cef
crypto pki trustpoint TP-self-signed-2781641347
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2781641347
revocation-check none
rsakeypair TP-self-signed-2781641347
crypto pki certificate chain TP-self-signed-2781641347
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32373831 36343133 3437301E 170D3133 30363135 30303433
35345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37383136
34313334 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100CFAF D23E606C C51528EA 47F8028A 83570542 09EFCB1F 67410747 F0C94084
AF3129F7 2233EACD 98F1F99C 2BCEC5C3 7C19832B D4C913E0 FC0FF02D 9A4F3082
8F97FDAE C02F9D94 AA1152C0 EA825EE5 00571372 0E3C6C8E B3FD9457 E15F1192
563C3B11 1670F621 C683FCC6 A947E4B4 3220EA1E BC011FAC CC84E076 02C9F617
29D10203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14FDB25B C1F42448 FF76D440 401C0CEE 9D852B3C DD301D06
03551D0E 04160414 FDB25BC1 F42448FF 76D44040 1C0CEE9D 852B3CDD 300D0609
2A864886 F70D0101 05050003 81810073 05C06429 C2397277 F4943DEB C59B996C
66E43213 1B7350EA FBAC44D1 BEF573BF 746B9B6C AE149735 4BBFC01A 93D385D8
8828787C 68585752 459A247C CD84DE74 F23C35C6 10115568 F2A08FEB 42546A2F
F4203FD7 EE8251FF 17B76913 8CCF5C4F 8062F788 9B087559 93C0305F 91E880A7
4C0F0662 9656D563 801B5A6E C804FA
       quit
license udi pid CISCO2921/K9 sn FTX1724AM2U
license boot module c2900 technology-package securityk9
object-group network Clock_6401
host 10.20.61.81
object-group network Clock_6402
host 10.20.61.82
object-group network Clock_6403
host 10.20.61.83
username ruser1 privilege 15 secret 4 AOt2ZJMSG0QC5a/jxOxI9WhUy2Z8zyuyGyQheOp0w2E
username Admin view root secret 4 56jyXs.RSLFQFX5Ebzwqm0eXTwHAtDmINcDLgnOqA16
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Internet$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.10
description Data$ETH-LAN$
encapsulation dot1Q 10
ip address 10.20.60.1 255.255.254.0
ip helper-address 10.20.60.21
interface GigabitEthernet0/1.20
description VoiceVlan$ETH-LAN$
encapsulation dot1Q 20
ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/2
description Directly Connected to ASA$ETH-LAN$
ip address 10.10.10.1 255.255.254.0
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 172.20.16.0 255.255.255.0 10.10.10.2 permanent
ip route 192.168.4.0 255.255.255.0 10.10.10.2 permanent
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
Jon Marshall Tue, 12/03/2013 - 12:18
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
Note that the ASA uses 8.3 code and that uses a completely different NAT than previous versions - are you comfortable with that NAT because i haven't used it before but i should be able to sort it out. Basically i think the easiest thing would be to simply reconnect the 2921 to the inside interface of the ASA but we would need to readdress the inside interface.
Anyway, lets do the router first. If you could answer the following -
1) you only have these routes on the router -
From your diagram i expected to see a default route so i'm not sure how 192.168.2.x clients get to the internet ?
2) Can you confirm that the only internal networks that need routing are -
10.20.60.0/24
192.168.2.0/24
If the 2) is correct then the only change we need to make on the router is to remove those 2 routes and simply add a default ie.
ip route 0.0.0.0 0.0.0.0 10.10.10.1   <-- which will be the new inside interface of the ASA
but i need both 1) and 2) answering first.
Also important to note you will need an outage to do this work and you have to do it all together so we also need to sort out the ASA.
Jon
Roger Richards Tue, 12/03/2013 - 12:33
OK...
1) Those address  are on the other side of the VPN. couldnt get to them from the 2921.
2) And Yes... only  two internal thats needs routing,, maybe more in the future..
Jon Marshall Tue, 12/03/2013 - 12:40
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Right, well that't the router sorted then. Once we have done all this the 192.168.2.x network will be able to get to the internet.
So it's just a question of sorting out the ASA.  Basically we need to have the inside interface readdressed to 10.10.10.2 and the 2921 interface on the ASA shutdown with no ip address.  I think it's a good idea to use the inside interfce because the NAT statements refer to that interface.
So you would need to reconnect the 2921 to the inside interface of the ASA and readdress.
But like i say i'm not familiar with the ASA NAT config so i need to have a look at it with the docs just to work out if there are any gotchas. How comfortable are you with the ASA config in terms of NAT ?
It's not that complicated it's just i can't give you an immediate answer unless you know it well.
Jon
Roger Richards Tue, 12/03/2013 - 12:51
I am somewhat familiar with it.
Question, if you remove the  2921 interface and reconnect to the inside interface on the asa, what would happen to my Vlan 10 which is on my 10.20.60.0 network?
Jon Marshall Tue, 12/03/2013 - 13:01
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
vlan 10 is going to be routed off the 2921 so the ASA does not need a connection to that network. So to get to the internet or VPN a 10.20.60.x client would send it's traffic to the 2921 as this is now it's default gateway (or it will be, can't remember whether we changed that or not). The 2921 has a default route pointing to the ASA so it will send the packets on to the ASA.
So if the clients are still using 10.20.60.2 as their default gateway that would need changing to 10.20.60.1 ie. the 2921.
Okay, so you know what needs doing. Bear in mind that you should probably reload the 2921 and ASA ot clear all caches and you may need to reboot the clients or clear their arp caches if they are still using 10.20.60.2 as the default gateway.
Do you want to me look at the ASA configs or are you comfortable with that.
On a more general note are you comfortable with all i've outlined because it is quite a big change ?
Jon
Roger Richards Tue, 12/03/2013 - 16:01
I am totally comfortable with the changes and I dont mind if you look at the configs...
Jon Marshall Tue, 12/03/2013 - 16:10
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
Good to hear. I was only worried about the ASA because i know the old NAT very well but then Cisco had to go and change it and i've not go to use the new NAT yet.
But it should all be fine and it would then be much easier i think to add new subnets etc. in future.
Let me know how it goes and if you want/need a second pair of eyes on the config just post them here and i'll be happy to have a look.
Jon
Jon Marshall Tue, 12/03/2013 - 13:11
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
Sorry, i forgot to mention we will need to add these routes to the ASA -
route inside 10.20.60.0 255.255.254.0 10.10.10.1
route inside 192.168.2.0 255.255.255.0 10.10.10.1
Jon
Jon Marshall Tue, 12/03/2013 - 13:42
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
And obviously remove these routes -
Jon
Roger Richards Mon, 12/09/2013 - 11:37
Hey there, back again. Can I change my local network subnet instead of changing the interface? Just wondering if it would be easier instead of messing with the natting and stuff.
example; instead of using 10.20.60.0 on my local net, ill use 10.20.40.0 on vlan 10...
then and the necesarry routing.
route inside 10.20.40.0/23 10.10.10.1
Jon Marshall Mon, 12/09/2013 - 13:01
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
Whatever is easiest basically. But the inside interface on the ASA is not 10.10.10.2 so -
not sure how that would work.  I thought you were going to simply  move the 2921 connection on the ASA to the inside interface and then readdress that to 10.10.10.2. The NAT refers to "inside" so it just should work.
I can't see any NAT statements that refer to the actual 10.20.60.2 address of the inside interface so changing it should not make a difference. And you simply shutdown the 2921 interface on the ASA.
The only reason i said it needed checking was just in case i missed something because i'm not that familiar with 8.3 NAT on the ASA.
Jon
Roger Richards Wed, 12/11/2013 - 12:12
Jon, I made a mistake in that last post..Take a look at the changes.. Also dont pay attention to the routes shown. They were not changed from the previous setup...
Jon Marshall Wed, 12/11/2013 - 12:18
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
My understanding was that you wanted to use the 2921 to route the internal vlans ? If so there are quite a few points to clarify -
1) The ASA only has 2 routes via it's inside interface. This interface (inside) is now connected to the 2921 is that correct ?
The routes it has are for 10.20.60.0 which is directly connected and 172.16.20.0 which i think you said was just a test route.
So how is it going to get to the 2921 subnets ?
You need to add routes for vlans 10 and 20 pointing to 10.20.60.1.  Also your diagram shows a guest network (vlan 50) so you would need to add a route for that as well.
2) The 2921 only needs a default route pointing to the ASA. Why are all the routes pointing to 10.10.10.2 still there ?
3)  What do you mean when you say in the diagram "But there is no vlan 10 on the router" ?
Edit - okay, you have just updated post so the stuff about the routes does not apply. Can you answer point 3) though.
Jon
Roger Richards Wed, 12/11/2013 - 12:48
Jon,
Sorry for the confusion. So with this update I would need to add to the ASA
routes to 10.20.10.0,192.168.2.0 and 10.20.50.0
and a defualt route in the 2921 to the ASA? Also my gateway would now be 10.20.60.1
Roger Richards Wed, 12/11/2013 - 13:19
Sorry for the headache Jon,  But I think I will stick to your original idea whci  was to readress the Inside interface. It makes more sense....
Jon Marshall Wed, 12/11/2013 - 13:44
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
No problem.
You can do what you are suggesting in the diagram and it would work fine.
Yes you add routes on ASA for all the 2921 subnets via 10.20.60.1.
And you would only need a default route on the 2921 pointing to 10.20.60.2.
Jon
Roger Richards Thu, 12/12/2013 - 04:35
Ok.. I realize I have a lot of ACL's and some natting to different objects, so changing the Inside interface might be a better choice....
But I do understand what i need to do, by changing it though...
Roger Richards Fri, 12/20/2013 - 04:32
I made an attemp to do the configuration. But I couldnt get to devices on my 10.20.60.0 subnet... or ping devices on that subnet from the ASA.
I stuck with your originial plan to change the inside interface 10.10.10.2 ..
But i didnt really know what else to change beside the interface and adding the routes.. What nat would need to change? what acl or other object needs to change?
Thanks again
Jon Marshall Fri, 12/20/2013 - 05:21
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
Can you post configs of the router + ASA. Could you add them as attachments otherwise this thread is going to get too big to open. Or start a new thread as a continuation of this one.
Can you be specific as to what you mean when you say you couldn't get to 10.20.60.x devices ie. from where ?
Were other subnets working ?
Jon
Roger Richards Fri, 12/20/2013 - 08:31
the  Other subnets was working... .. I could not get to ping any server on the 10.20.60.0 subnet from the ASA... but was able to get to 192.168.2.0 sub.
All my devices are on the 10.20.60.0 network... from pcs to servers. so remember the plan was to remove the 2921 interface and use 10.10.10.2 on the inter with 10.20.60.2...
in the asa I added the routes via the Inside interface (10.10.10.2)
route to 10.20.60.0/23 10.10.10.2
route to 192.168.2.0/24 10.10.10.2
Jon Marshall Fri, 12/20/2013 - 10:40
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
edited
Jon Marshall Fri, 12/20/2013 - 10:48
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
But you haven't done this according to the configs you have just posted.
The idea is to use the inside interface to connect to the 2921 so that you do not need to change any NAT statements on the ASA. But you still have the 2921 interface connected to the router. So do this (note you will need downtime) -
1) shutdown the 2921 interface on the ASA and remove the address from the config.
2) remove the cable from the inside interface of the ASA that i think still connects to a switch.
3) take the cable that is in the 2921 interface on the ASA and connect it to the inside interface of the ASA.
Now the 2921 router physical connection runs from gi0/2 on the router to the inside interface of the ASA.
4) remove the 10.20.60.2 address from the inside interface on the ASA and add the 10.10.10.2 address that was previously on the 2921 ASA interface.
5) these routes on the ASA need changing  -
a) remove these -
no route 2921 10.20.30.0 255.255.254.0 10.10.10.1 1
no route 2921 192.168.2.0 255.255.255.0 10.10.10.1 1
b) add these
route inside 10.20.30.0 255.255.254.0 10.10.10.1 1
route inside 192.168.2.0 255.255.255.0 10.10.10.1 1
6) add this route to the 2921
ip route 0.0.0.0 0.0.0.0 10.10.10.2
That should do it. As i say you will need downtime but once done all internal vlans should route via the 2921 and the ASA should only be used for internet. The ASA NAT statements reference the inside interface so it should just work.
Jon
Roger Richards Fri, 12/20/2013 - 10:56
The config i sent you was the current one. I had to put it back in order for things to work, cause its a production network ...
I did exactly what you have above..
Except I added a route in the asa to
10.20.60.0 /23 10.10.10.1 <-- ?
so i will do it again, and remove that route and all the other ones.
Jon Marshall Fri, 12/20/2013 - 11:01
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
Sorry, i just copied the routes from the ASA config. You will need that 10.20.60.0/23 route ie.
I don't know where the 10.20.30.0/23 network is ie. there is a route on the ASA but no sign of it on the 2921. If there is no such network then just remove it from the ASA config altogether.
One other point. When you do the change after you have moved the cables around make sure you clear the arp tables on the both the 2921 and the ASA because the mac to IP mappings will have changed.
Jon
Roger Richards Thu, 01/09/2014 - 13:58
HAPPY NEW YEAR!!
I must be doing something wrong, cause I still cant get it to work.
Jon Marshall Thu, 01/09/2014 - 14:14
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
Happy New Year as well.
Okay, what didn't work and can you post the configs or are they back to where they were before the changes (i suspect they are).
Jon
Jon Marshall Thu, 01/09/2014 - 14:16
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Roger
Can you start a new thread for this as my browser keeps hanging every time i try to open or post a reply into this thread.
And i suspect we may well be sending a few more replies each to get this working
Jon
Related Content
