Changins Subnet Mask and Gateway for CUCM & CUC 8.6
Answered Question
Nov 19th, 2013
Am planning for cutting down the Subnet of Telecom Servers IP Range. Once i do this, all CUCM & CUC servers Subnet mask and Gateway has to be changed, but IP Address remains the same.
Changing the Subnet mask and Gateway will impact anything or any precautionary measures or any procedures to be followed ??
Pls suggest.
Jagadish G
Correct Answer by Aman Soi about 3 years 9 months ago
Hi Jagadish,
I was just referring the DOC which I have attached which says
Initial Trust List and Certificate Regeneration
If you change the IP address or the hostname of a server in a Cisco Unified Communications Manager release 8.0 or later cluster, the Initial Trust List (ITL) file and the certificates in the ITL are regenerated. The regenerated files do not match the files stored on the phones.
regds,
aman
Overall Rating: 5 (1 ratings)
Jaime Valencia Tue, 11/19/2013 - 23:02
  • Cisco Employee,
  • Hall of Fame,
    2011
Not if youre using MCS, otherwise, youll need to rehost the licenses as it affects the license MAC
Jagsuvce G Tue, 11/19/2013 - 23:10
Yes we are using Cisco MCS 7800 series servers. How will the mac gets affected ??
Jaime Valencia Tue, 11/19/2013 - 23:17
  • Cisco Employee,
  • Hall of Fame,
    2011
It wont, that only affects if you are running over ESXi
Jagsuvce G Tue, 11/19/2013 - 23:26
So i can go a head and change the subnet mask and default gateway without any measures right ??
Jagsuvce G Tue, 11/19/2013 - 23:53
Will the ITL files gets changed/regenerated after changing only the Subnet Mask & Gateway ??.
Correct Answer
Aman Soi Wed, 11/20/2013 - 00:11
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Hi Jagadish,
regds,
aman
