11-19-2013 10:58 PM - edited 03-16-2019 08:29 PM
Dear Experts !
Since there is no way to give PIN/Password for Meetme numbers in CCM 6.1 , i want it to restrict it thru the h323 gateway .
I have several hundeds DID working, amount them will be a meetme number ex: 456789 .
i want this number (456789) be reachable to certain autorised numbers only from pstn ( ex: 23456, 2424242,059887333)
and all other should be blocked to this number to reach this number.
the idea is "nobody should reach except the authorised numbers" .
regards/
11-19-2013 11:03 PM
You would need to develop a TCL script for that
11-19-2013 11:10 PM
Do have one ! any example where i edit and input my numbers !
appreicate if u help me !
11-19-2013 11:16 PM
No, you would need to build it yourself, you may get some help in the developers forum.
11-20-2013 10:46 PM
Hi Jaime !
thanks for the input, i got it work thru unity Call Handler Combination, got the authenticaion working thru spoken name rather than PIN number. i think this is enough for me at present.
TCL Script is more of hardpart for me , as i cannot do prorgramming,
by the way, do u have any idea how i can monitor this meetme session !
11-21-2013 08:34 AM
If you mean like monitor who is in the conference, no, that only works with ad-hoc.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-21-2013 09:29 AM
You can do this by passing al traffic from the pstn to the meetme number through a CSS that has only translations that match on calling party. Make a general translation that blocks the call and make specific translations that allow the call to go through.
Erik
11-21-2013 01:30 PM
I second Erik's reply. 5+ to you.
You should be able to do this with translation patterns that match on calling party. You'd need to be on CUCM 8.x or never for this to work.
