filter url http
Answered Question
Nov 20th, 2013
Hi Everyone,
Our ASA  has below config here
filter url http 192.168.0.0 255.255.0.0 0.0.0.0 0.0.0.0
filter url http 172.16.0.0 255.240.0.0 0.0.0.0 0.0.0.0 longurl-truncate
filter url http 10.0.0.0 255.0.0.0 0.0.0.0 0.0.0.0 longurl-truncate
We have websense configured that has connection to ASA  to block some http and https traffic.
Need to understand what does above config do on the ASA?
MAhesh
Correct Answer by Marius Gunnerud about 3 years 8 months ago
Does the above config means to bypass the websense and directly go to internet if source is from 172.31.128.x?
You are correct, a filter with the exept keyword will exempt all traffic that is defined in that filter from being sent to the filter server.
Does this mean that if rule 1 is matched first just like ACL  it will allow the http traffic from 172.31.128?
Yes, the match is based on a first match logic as with ACLs.
Another thing to ask is if the browser has no proxy config then traffic will come to firewall first and depending on the
config there it will forward the traffic first to the websense or  internet?
Again correct.
Please rate all helpful posts
Correct Answer by Marius Gunnerud about 3 years 9 months ago
This command will send all http traffic to websense for evaluation.
These commands also send http traffic to websense for evaluation, but when dealing with a longer than permitted URL it will only send the IP address portion of the URL or the hostname for evaluation.
Overall Rating: 5 (2 ratings)
Correct Answer
Marius Gunnerud Wed, 11/20/2013 - 10:28
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Firewalling
mahesh18 Wed, 11/20/2013 - 19:49
Hi Marius,
ASA  has  this config  lines
filter url except 172.31.128.0 255.255.192.0 0.0.0.0 0.0.0.0
filter https except 172.31.128.0 255.255.192.0 0.0.0.0 0.0.0.0
and this includes http and https traffic?
if we have below config in following order
filter url except 172.31.128.0 255.255.192.0 0.0.0.0 0.0.0.0   rule 1
MAhesh
Correct Answer
Marius Gunnerud Wed, 11/20/2013 - 23:59
    2017 Firewalling
Again correct.
mahesh18 Thu, 11/21/2013 - 08:07
Many thanks Marius.
Best regards
Mahesh
Message was edited by: mahesh parmar
