regex and grouping questions
Carlomd
Hi all, I have a 5510 in route mode, when I add a regex to block 2 sites, it somehow blocks all sites, when I remove it it's back to normal, here's the regex code along with my other nat setting that gives inside users outside access. Thanks in advanced.
(regex entry to block sites)
regex domain1 "\.yahoo\.com"
regex domain2 "\.google\.com"
class-map type regex match-any domain-list
match regex domain1
match regex domain2
class-map web
match port tcp eq www
policy-map type inspect http URL
parameters
match not request header host regex class domain-list
drop-connection
policy-map global_policy
class web
inspect http URL
(nat outside access)
object network obj-LAN
subnet 0.0.0.0 0.0.0.0
nat (inside,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 12.54.x.x 1
5 Accepted Solutions
I am not sure why the TAC engineer said to use single entries.  The only restriction is that you can not use the same static NATed port going from a single external IP to multiple internal IPs.  you should be able to use object group to define the ports and assign it to a single ACL statement.  I have done this several times.
Also from the post above, it looks like you are using ASA 9.1.  In this case your ACL configuration is a little wrong.  Prior to 8.3 you would use the public (NATed) IP when configuring and ACL on the outside interface.  As of 8.3 and higher you will need to use the real IP (private IP) when configuring ACLs.  This is due to the order in which actions are taken on the packet entering the ASA.  8.3 and higher, NAT happens before the ACL check when traffic enters the ASA.
Please add the following to your configuration just remember to add your server's actual IP, and if it is not already in the configuration, assign the ACL to the external interface where the traffic will ingress (often this is called the outside interface):
object-group service SERVICES tcp
port-object eq http
port-object eq https
port-object smtp
access-list MYACL extended permit tcp any host object-group SERVICES
access-group MYACL in interface outside
Please rate all helpful posts
Please remember to select a correct answer and rate helpful posts
Split DNS is for VPN users where you define specific URLs that are to be resolved over the VPN connection.
So you say you have an A record for the OWA URL? for example you have an entry for mail.company.com pointing to 208.x.x.3 or 208.x.x.12?
The issue you are facing is that your inside hosts are trying to connect to the OWA using the public address.  So traffic is routed to the outside interface and then does a u-turn and comes back in.  The ASA views this as spoofed / not allowed and drops the connection.
You will need to set up hairpinning and NAT from inside to inside.
object network MAIL-SERVER-EXTERNAL
host
object network MAIL-SERVER-INTERNAL
host
object network LAN
subnet 208.x.x.0 255.255.255.0
same-security-traffic permit intra-interface
nat (inside,inside) source static LAN LAN desitnation static MAIL-SERVER-EXTERNAL MAIL-SERVER-INTERNAL
Please remember to rate and select a correct answer
That warning comes due to the dynamic NAT statement you already have.  If you are connected remotely, then I would suggest not applying this config at this time.  It would be best to do this when onsite and have physical access to the ASA incase you lose connectivity.  once you apply it, if traffic flow to the internet and to the all other resources are as expected then you can keep the configuration.  If not then remove it, of course.
Keep in mind that the configuration in that article is for ASA 8.2 and earlier.  The same configuration will not work on your ASA running version 9.1
It is quite deceiving, it should say 8.3 and onwards if it is refering to the new way of configuring NAT.  The configuration you posted is pre 8.3.
https://supportforums.cisco.com/docs/DOC-9129
47 Replies 47
Try using the match not keywords under the class map and then call that class map in the policy map
match regex domain1
match regex domain2
class-map type inspect http match-all ALLOWED_URL_CLASS_MAP
match not request uri regex class domain-list
class ALLOWED_URL_CLASS_MAP
drop
Thanks for the reply Marius, I'll give this a try.
Hi Marius, it still allows access to ebay.com, and myspace.com, I had typos at first but I carefully followed your instructions and the commnands worked but was still allowing access to the 2 sites I wanted to block.
here' the current policy entries;
ASA Version 9.1(2)8
regex ebay "\ebay\.com"
regex myspace "\myspace\.com"
match regex ebay
match regex myspace
class-map inspection_default
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
parameters
  drop-connection
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
Message was edited by: CARLO DOMINGUEZ
You need to not use the match not in this case.  The match not means that it will allow access to ebay and myspace but will drop all others.
Sorry I was a bit fast in my copy past and did not change the policy map.
match regex ebay
match regex myspace
match request uri regex class domain-list
drop-connection
By placing the class map under the global policy this will be applied to all interfaces
Please rate any helpful posts.
Hi Marius, I see so the match not command means to only allow what's on the domain-list, and then vice versa. And looks like it needs to also be put in the global policy group for it to take effect to all interfaces. I wasn't putting it in the global policy that's probably why I was having some issues when I first tried it, thanks I'll give it another try at the end of the day.
Hi Marius, I get this error when I add the class under the global policy, any ideas, thanks.
crxasa(config)# policy-map global_policy
crxasa(config-pmap)# class ALLOWED_URL_CLASS_MAP
ERROR: Specified class type is different from the policy-map type.
I forgot to add another policy map in the mix.  The below configuration should work.
match regex ebay
match regex myspace
policy-map type inspect http HTTP_BLOCK_POLICY
parameters
  drop-connection
Hi Marius, thanks for the reply, but somehow it won't work, it still allows ebay and myspace, here's my config of the policies.
match regex ebay
match regex myspace
parameters
parameters
  drop-connection
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Can you try this.
regex url1 "[e|E][b|B][a|A][y|Y]"
regex url2 "[g|G][o|O][o|O][g|G][l|L][e|E]"
class-map type inspect dns match-all web_url_policy
match domain-name regex url1
match domain-name regex url2
policy-map type inspect dns web_policy
class web_url_policy
  drop
Please rate replies and mark question as "answered" if applicable.
Thanks for the reply rr, I'll try this if the other ones don't work.
edit the regex entries.
regex ebay "*\.ebay\.com"
regex myspace "\.myspace\.com"
If that doesn't match, then try using the * infront of the domain.
regex ebay "*ebay\.com"
regex myspace "*myspace\.com"
Configuration looks correct, we just need to find the correct match parameter.
Please rate all helpful posts.
  I have another question on another command I seem to have trouble with, this is my first time hands on with ASA btw, so I'm just getting into the meat and potatoes of the asa just about over a month now.
  I read that you can group together udp and tcp, so I did that with grouping smtp, http. https. and domain to a set of host objects, but email won't go through, I think http worked though but somehow smtp won't unless I seperate it on one line. Any ideas?
Could you post the group objects in question as well as the access list you are using them in.  The following would is an example of how you would configure it.
port-object eq http
port-object smtp
access-list MYACL extended permit tcp host 10.10.10.1 any object-group SERVICES
Marius, thanks for the reply, I'm using the command service-object instead of port-object, I got it from my asa 2nd ed book off a sample. I'll try port-object and see what happens, it'll save me some time having to type seperate lines of command for each host.
object-group service server-services
service-object tcp destination eq www
service-object tcp destination eq https
service-object tcp destination eq smtp
access-list ACL_OUT_IN extended permit object-group server-services host 208.x.x.12 any
