Warning message
Lost access to switch after upgrade to metro access image
Nov 21st, 2013
Hello
After an upgrade of a 3400 ME switch image to metro access one (340x), the switch was reloaded. After that, the only way to access the switch is the console port. I am beginner with cisco switches but I managed to configure the switch to make an upgrade through TFTP. Now I want to configure port 0/1 on vlan access mode to vlan 1. Any help on this is more than welcome. Thank you.
Switch   Ports  Model              SW Version              SW Image
*    1   26     ME-3400-24TS-D     12.2(35)SE3             ME340x-METROACCESS-M
no aaa new-model
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 10
name management
interface FastEthernet0/1
speed 100
duplex full
interface FastEthernet0/2
shutdown
interface FastEthernet0/3
no switchport
no ip address
no ip route-cache
shutdown
interface FastEthernet0/4
shutdown
--More--
interface GigabitEthernet0/2
port-type nni
interface Vlan1
ip address 192.168.1.252 255.255.255.0
no ip route-cache
interface Vlan10
no ip address
no ip route-cache
shutdown
ip default-gateway 192.168.1.1
no ip http server
cisco3400#sh int fastEthernet 0/1 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Capture Mode Disabled
Capture VLANs Allowed: ALL
selim.ellouze Thu, 11/21/2013 - 04:56
I found the source of the problem. My switch was connected to another one. I had to explicitly put port type to nni.
Hope it helps someone.
Related Content
