If I have a server farm with real servers listening on port 8888 and I apply an HTTP-type health probe with no port number specified, will the ACE know to probe the servers at 8888 or will it try to probe port 80?
Yes it should inherit the port from the real servers defined in the serverfarm. This gives you the flexibility to associate same probe with different serverfarms probing different servers on different ports. This is probe port inheritance feature which is there in ACE.
Kanwal
