Warning message
E1 Clocking
Nov 22nd, 2013
I have an MGCP gateway with 2 E1 PRI lines connected. One of them the slips and errors are incrementing. The clock source is line from the telco as per normal. I have also tried setting the clock source as internal but still there is a problem with clocking
Anything else I can try or do I need to report this to the telco?
There is one difference between the 2 PRI lines. One (E1 1/0 is a traditional e1 TDM circuit and the line with the error is a VOIP PRI i.e the E1 line is connected from my router E1 1/1 to the telco Cisco router E1 interface
CONFIG:
network-clock-participate slot 1
network-clock-select 1 E1 1/0
E1 1/0 is up.
  Applique type is Channelized E1 - balanced
No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 255, spm_count = 0
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  Current port master clock:recovered from backplane
  Data in current interval (458 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 1 15 minute intervals):
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
E1 1/1 is up.
No alarms detected.
  Data in current interval (677 seconds elapsed):
     15 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     15 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Gordon Ross Fri, 11/22/2013 - 02:14
  • Blue, 1500 points or more
You need to be clear who is the clock soure for interface 1/1. If you're not the clock source, then you need a "network-clock-select" command for the interface.
GTG
Please rate all helpful posts.
Aman Soi Fri, 11/22/2013 - 02:26
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Hi ,
can u share output of show network-clocks?
regds,
aman
CiscoRunner Fri, 11/22/2013 - 03:00
Hi Gordon,
I have tried putting network-clock-select 2 E1 1/1 but that doesnt make any difference...
Aman, show network-clocks:
Network Clock Configuration
  Priority      Clock Source    Clock State     Clock Type
     1          E1 1/0          GOOD            E1
     2          E1 1/1          GOOD            E1
    10          Backplane       GOOD            PLL
  Current Primary Clock Source
     1          E1 1/0          GOOD            E1
Gordon Ross Fri, 11/22/2013 - 03:04
In which case, are you and the other end sure you know who is producing the clock?
GTG
CiscoRunner Fri, 11/22/2013 - 03:23
I was under the impression it was the telco providing the source but seeing as I am still getting errors hence my question earlier :
"Anything else I can try or do I need to report this to the telco?"
Gordon Ross Fri, 11/22/2013 - 03:25
I'd speak to your Telco's tech support team.
GTG
