Warning message
2911 - %SMC-2-BAD_ID_HW and license lost after rommon upgrade
Nov 22nd, 2013
First of all I had a 2911 with IOS c2900-universalk9-mz.SPA.151-4.M4 and ROMMON Version 15.0(1r)M6. The following licenses were installed as permanent: ipbasek9, securityk9.
Router#show version
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
When trying to upgrade to IOS c2900-universalk9-mz.SPA.152-4.M5 I received the following error message during boot:
*** Bus Error (Load) Exception ***
Access address = 0xffffffba
  PC = 0x80000a68, SP = 0x8efffd40, RA = 0x80000844
  Cause Reg = 0x4000801c, Status Reg = 0x504080e3
monitor: command "boot" aborted due to exception
I tried this on several 2911 routers, same result: All routers with ROMMON Version 15.0(1r)M6 failed to load IOS 152-4.M5. Routers with ROMMON Version 15.0(1r)M15 loaded the new IOS without any problem.
So i tried to upgrade the ROMMON on the first 2911 to the latest downloadable version from Cisco:
Router#upgrade rom-monitor file flash0:C1900_2900_RM2.srec.SPA.150-1r.M16
Platform Field Upgradeable ROMMON LOAD test
___________________________________________
RSA Signature Verification Passed ...
ROM: Digitally Signed Production Software
This command will result in a  'power-on reset' of the router!
Continue? [yes/no]: yes
ROMMON image upgrade in progress.
Erasing boot flash eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Programming boot flash pppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppp
Now Reloading
After the reboot I now receive the following error messages:
%SMC-2-BAD_ID_HW: Failed Identification Test in 0/-1/-1 [7/0]
       The module in 0/-1/-1 in this router may not be a genuine
       Cisco product.  Cisco warranties and support programs only
       apply to genuine Cisco products.  If Cisco determines that
       your insertion of non-Cisco memory, WIC cards, AIM cards,
       Network Modules, SPA cards, GBICs or other modules into a
       Cisco product is the cause of a support issue, Cisco may
       deny support under your warranty or under a Cisco support
       program such as SmartNet.
And my ipbasek9 and securityk9 licenses are lost:
Router#show version
ipbase        ipbasek9      None           ipbasek9
security      None          None           None
Show diag shows me a failed identification test:
Router#sh diag
Slot 0:
        Failed Identification Test [ 7/0 ]
        C2911 Mother board 3GE, integrated VPN and 4W Port adapter, 3 ports
        Port adapter is analyzed
        Port adapter insertion time 01:41:01 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC171*****
        Hardware Revision        : 1.0
        Part Number              : 73-11833-11
        Top Assy. Part Number    : 800-30797-06
        Board Revision           : A0
        Deviation Number         : 130603
        Fab Version              : 03
        Product (FRU) Number     : CISCO2911/K9
        Version Identifier       : V07
        CLEI Code                : CMMJD00ARA
        Processor type           : C1
        Chassis Serial Number    : FCZ163*****
        Chassis MAC Address      : bc16.654a.****
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1   (...)
So I tried to downgrade ROMMON back to Version 15.0(1r)M6. The problem stays the same.
--> What can I do to recover this router to normal operation?
--> How can I upgrade a 2911 with ROMMON Version 15.0(1r)M6 safely to IOS 152-4.M5 ?
myrdinthemyr Wed, 09/30/2015 - 23:21
i know it is a veeeery old post, i am having the exact same issue and TAC can't figure it out either. I am wondering if the user managed to fixed and how.
cheers
sebastian.lemke Wed, 09/30/2015 - 23:27
No, this wasn't fixed unfortunately. The routers went back to our distributor...
myrdinthemyr Wed, 09/30/2015 - 23:33
well thanks heaps to replying on this...that does not sound promising!
Related Content
