Warning message
ios upgrade on switch stack
Answered Question
Nov 22nd, 2013
We have a stack of three switches.
Two are 3750E switches which use the universal ios and one is a 3750G switch which does not.
they are all at same version 12.2.55 SE3
i think when we built the stack we installed the ios individually but now we want to upgrade the stack preferrably with taking it apart.
the stack master is the 3750G switch.
we tried using the archive download-sw and no joy.
is there a procedure we can use to upgrade the ios on the stack that will work ?
thank you in advance
Correct Answer by Karthick Murugan about 3 years 8 months ago
If you are goal is to upgrade the stack. Copy the image from the tftp server to all the flashes.
copy tftp:///image-name.bin flash1:image-name.bin
copy tftp:///image-name.bin flash2:image-name.bin
copy tftp:///image-name.bin flash3:image-name.bin
change the boot sequence
conf ter
boot system siwtch all flash:
end
wr mem
reload
Thanks & Regards,
Karthick Murugan
CCIE#39285
Overall Rating: 5 (1 ratings)
Correct Answer
Karthick Murugan Fri, 11/22/2013 - 08:22
  • Cisco Employee,
conf ter
end
wr mem
reload
Thanks & Regards,
Karthick Murugan
CCIE#39285
jeffreywatson Fri, 11/22/2013 - 09:23
Thank you
Since two of the swtiches have different images do I put different boot statemetns in each switch ?
is there no way to do with the archive command.
someone said we could use this ?
archive download-sw /overwrite tftp:/3750e image.tar  tftp:/3750G image.tar
Leo Laohoo Fri, 11/22/2013 - 15:30
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
There are several ways to upgrade the IOS of a 3750.  What Karthick has posted is an old-school method and would work if you only have the BIN file.
If you have the TAR file, the best (and most effective) method is this command:
archive download-sw /destination 1 /destination 2 /destination 3 tftp:///filename.tar
You can add the following options:
/overwrite - Delete the OLD IOS subdirectory.  If your old IOS is a BIN file in the boot directory, then this file will be left intact.  If you have more than one old IOS subdirectory, only one subdirectory will be deleted.
/no-set-boot - Do not set the boot statement.  By default, boot statement is always changed by this script.
