Warning message
Dual Monitor over Clientless SSL VPN
Nov 22nd, 2013
               We have a 5540 configured as a clientless SSL VPN. For asset's, I'm enabling auto-start of smart tunnel. This access is for employees working from home who have dual monitors which can be used. The tunnel's establish, then we launch mstsc.exe, select 'use all available monitors', and then try and connect. Connection is successful, but only one monitor is working at a time. Is there a value in the bookmark that needs to created? Does it need to use Java similar to the Juniper SA's?
Thank you.
Joe
