Warning message
Cisco Utilization calculation question
Nov 22nd, 2013
Hello Community,
Can someone please look at the following calculation used by a company called ManageEngine to calculate the utilization on a link and let me know how how I would use the calculation to calculate the utilization from the output taken from the interface on our router
Speed = (Volume in bits / time in seconds). Which is (Volume * 8 / 60) Reported in bits per second (bps).
Utilization = (current speed/ link speed) * 100. Current speed is calculated as above.
The following is the output from our interface. I would like someone to show me how to use the above calculation to get the the utilization:
UK01252-DM01-Paddington20E
T#show int tunn 0
Tunnel0 is up, line protocol is up
  Hardware is Tunnel
  Description: ** mGRE/NHRP tunnel **
  Internet address is 172.17.141.42/24
  MTU 17912 bytes, BW 2048 Kbit/sec, DLY 50000 usec,
     reliability 255/255, txload 34/255, rxload 92/255
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 217.xx.xx.xx (FastEthernet0)
  Tunnel protocol/transport multi-GRE/IP
    Key 0x30D41, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255
  Tunnel transport MTU 1472 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "vpnprofile")
  Last input 00:00:00, output never, output hang never
  Input queue: 0/256/0/0 (size/max/drops/flushes); Total output drops: 429
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 744000 bits/sec, 115 packets/sec
  5 minute output rate 278000 bits/sec, 101 packets/sec
     536461271 packets input, 50720742 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     430873111 packets output, 597245969 bytes, 0 underruns
     0 unknown protocol drops
Cisco would calculate the utilization as
txload => 34/255 = 13%
rxload => 92/255 = 36%
I don't know how ManageEngines' formula would give me the same result.
Your help will be greatly appreciated.
Cheers
Carlton
